Results 1 to 18 of 18
Thread: Strange noise from my engine? VIDEO INCLUDED
  1. Member RonJon749's Avatar
    Apr 23rd, 2008
    Connecticut
    2009 GTI
    08-11-2012 03:34 PM #1
    Hello all.
    So a few weeks ago I noticed this strange noise coming from my MKV GTI 2.0TSI motor. Today, I'm finally noticing that it would make the noise intermittently. Then as I was documenting the noise, it began to do it constantly. Does anyone know what this is from? Maybe what caused this?
    A side note, I put in a Neuspeed P-Flo Intake (Which you will see) but this sound was happening prior to the intake, so the car was bone stock.
    Any insight? Videos here
    Thanks again guys.
    Lowered 2009 Platinum Grey VW GTI. 6-Speed. A Few Mods. Wheels Pending.
  2. Member MasterNele03's Avatar
    May 27th, 2008
    West Palm Beach, FL
    2000 C/W Jetta VRWookie, 2005 Volvo XC90, 2010 CW GTI, 2008 Yamaha R6
    08-11-2012 10:25 PM #2
    Water pump is trash, if your still under warranty get it replaced. There is still the chance that it could do this again as there has not been a sure fix from VW to fix the problem for good.
    Drive it like you stole it!!!
    XBL GT: MasterNele 03
    Need a crank/cam locking tool for your 2.5T (Volvo), PM me.
  3. 08-12-2012 09:38 AM #3
    Quote Originally Posted by MasterNele03 View Post
    X2
  4. Member RonJon749's Avatar
    Apr 23rd, 2008
    Connecticut
    2009 GTI
    08-12-2012 10:09 AM #4
    Yes I am still under warrantee, which is good. Is this only with the MKV models? or the 2009 TSI's?
  5. 08-12-2012 12:30 PM #5
    Quote Originally Posted by RonJon749 View Post
    Common in 2010+ 2.0TSI engines.
  6. Member ViRtUaLheretic's Avatar
    Aug 16th, 2008
    Kansas City
    2009 GTI
    08-12-2012 03:30 PM #6
    Quote Originally Posted by feplazas View Post
    Common in 2008.5+ 2.0TSI engines.
    fixed
    :APR -stage 2 :BSH -Intake,Mounts,RSB,TB Pipe :Whiteline -A.L.K.,Endlinks
    :Devils Own -DVC-30+Direct Port Injection :BC Racing -BR Coilovers :Flik-FTD :OSIR
    :Neuspeed -Insert,Brake Lines:Eurojet -Ceramic Coated DP :DEFI :Unibrace :Tyrolsport :Bildon :Hawk
    TSI FAQ: http://forums.vwvortex.com/showthread.php?4042736
  7. Member RonJon749's Avatar
    Apr 23rd, 2008
    Connecticut
    2009 GTI
    08-12-2012 03:35 PM #7
    I did a quick search on this and saw on a few other forums... apparently VW released a NEW pump, (post-problem oriented pump) that fixes the issue? Or at least the people who noticed the newer pump did not notice the problems returning.
    It's a shame that this is a well known "common" problem.
    What would these pumps go for out of warrantee?
  8. 08-12-2012 04:09 PM #8
    Quote Originally Posted by ViRtUaLheretic View Post
    fixed
  9. 08-12-2012 04:11 PM #9
    BA and AN revs have not been superseeded. Where did you read that?
  10. Member RonJon749's Avatar
    Apr 23rd, 2008
    Connecticut
    2009 GTI
    08-12-2012 04:49 PM #10
    I saw it over on the GTIMKV forums. could be billsh*t, but that's what I read. What are the chances that the problem will happen again?
  11. 08-12-2012 05:53 PM #11
    It is very likely to happen again
  12. Member RonJon749's Avatar
    Apr 23rd, 2008
    Connecticut
    2009 GTI
    08-12-2012 06:44 PM #12
    You'd think VW would do something to remedy this. What does a waterpump go for retail for when im out of warrantee?
  13. 08-12-2012 06:57 PM #13
    VW is supposedly working on a permanent fix. No word on ETA. A water pump is +/- USD300.
  14. Member RonJon749's Avatar
    Apr 23rd, 2008
    Connecticut
    2009 GTI
    08-12-2012 07:11 PM #14
    [Sarcasm] That sounds like a reasonable price, just like everything from the dealer! [/Sarcasm]
  15. 08-12-2012 07:16 PM #15
    No, no. Wp is usd300 if you buy it from an online retailer, not from the stealership!
  16. Member RonJon749's Avatar
    Apr 23rd, 2008
    Connecticut
    2009 GTI
    08-12-2012 09:32 PM #16
    So I actually found a thread here on Vortex. Click Me! see in the OG Post it says...
    "The dealerships in our area have seen a lot of failures and had lots of new pumps in stock.
    The pumps have been superseded by a new part number with a new bearing: 06H 121 026 AF"
    Wouldn't that mean that the old pumps were replaced with newer revised ones? Again, I don't know too much about that part of the car
  17. 08-12-2012 10:16 PM #17
    Very old thread. AF rev was superseded by BA rev.
  18. Member RonJon749's Avatar
    Apr 23rd, 2008
    Connecticut
    2009 GTI
    08-13-2012 07:34 AM #18
    AH gotchya, I didn't even catch that. well let's hope for a fix. In the mean time ill replace it while I'm still under warrantee.
