Page 1 of 4 1 2 3 4 LastLast
Results 1 to 35 of 121
Thread: Worst 4-cylinder engines
  1. Member mm3's Avatar
    Oct 10th, 2010
    Houston and NYC
    MkIV Jolf GTI
    08-11-2012 05:09 PM #1
    V6 motors, V8 motors, now let's do 4 cylinders.
    Guess who...
  2. Member Justin_Eshelman's Avatar
    Dec 3rd, 2010
    South Alabama
    82' VW Caddy, RIP-2003 20th Anniversary GTI #0024
    08-11-2012 05:12 PM #2
    “A turbo: exhaust gasses go into the turbocharger and spin it, witchcraft happens and you go faster.”
  3. Member subgraphic's Avatar
    Sep 14th, 2003
    Sunny San Diego
    '63 VW Bug, 328i, Jeep Commander, Vector W8
    08-11-2012 05:16 PM #3
    Iron duke
    Have a on me...
  4. Member mm3's Avatar
    Oct 10th, 2010
    Houston and NYC
    MkIV Jolf GTI
    08-11-2012 05:23 PM #4
    Quote Originally Posted by Justin_Eshelman View Post
    False.
  5. Member David802's Avatar
    Feb 22nd, 2011
    SLuT
    01 Jetta VR6, 71 Type 1.
    08-11-2012 05:25 PM #5
    Quote Originally Posted by mm3 View Post
    False.
    It neva loses. Didn't say anything about neva breaking.
  6. Member IridiumB6's Avatar
    Nov 29th, 2010
    Toronto, Canada
    2006 Passat 2.0T, 2006 Jetta 2.5, 2008 Volvo XC90 3.2
    08-11-2012 05:29 PM #6
    Quote Originally Posted by David802 View Post
    I prefer the term.."high maintenance"
  7. Member David802's Avatar
    Feb 22nd, 2011
    SLuT
    08-11-2012 05:32 PM #7
    Quote Originally Posted by IridiumB6 View Post
    Isn't that what Volkswagen means in English?
  8. Member jddaigle's Avatar
    May 30th, 2003
    Denver, CO
    2008 Passat Wagon VR6 4motion, 2001 VW Jetta 1.8T
    08-11-2012 05:39 PM #8
    Of all the problems people like to talk about MkIVs having, problems with the engine itself are a pretty small proportion. I don't think that problems with e ignition system (coils) or the water pump count as "engine" problems. Cracked rings, weak head gaskets, weak rods, etc., now those would be engine problems.
    - Jeff
  9. Member David802's Avatar
    Feb 22nd, 2011
    SLuT
    08-11-2012 05:42 PM #9
    Quote Originally Posted by jddaigle View Post
    I was joking... Jump next time.
  10. 08-11-2012 05:44 PM #10
    Uh no. Those still count as engine problems.
  11. Member Live-Wire's Avatar
    Jun 9th, 2005
    Guelph Ontario
    2008 BMW 335i
    08-11-2012 05:57 PM #11
    Quote Originally Posted by surefooted View Post
    They sure do. The 1.8T popped into my head when I read the title. Also doesn't help that it would sludge up due to oil spec/capacity until VW changed those... It only has a good rep because it is tunable; cheap power... and decently reliable once as you repair all the OEM stuff with good stuff.
    On the other hand, the 2.Slow while agonizingly out of date is not a 'worst' engine due to how robust it is... slow yes, not great on fuel, but durable as hell.
  12. Member HerrGolf's Avatar
    Nov 30th, 2002
    Columbus, Jugoslavija
    2000 Civic D16Y7
    08-11-2012 06:05 PM #12
    Ford 2.3 HSC as found in Tempo/Topaz (also in 2.5 form for Taurus). The worst aspect of a lackluster car, they sounded terrible, were slow revving and lacking in power. Apparently, it was easier for Ford to chop a third of the Falcon's engine off rather than reconfigure the Pinto engine for transverse duty.
    Makes the Chrysler 2.2/2.5 seem superior (which it was in comparison).
  13. Geriatric Member BRealistic's Avatar
    Dec 16th, 2005
    Tennessee
    88 F150, 04 RX8
    08-11-2012 06:07 PM #13
    Weren't the early Quad Four engines troublesome and sounded like a meat grinder?
    But they did deliver on the power and economy promises.
    It's easy to make power from a four banger when you don't have to worry about introducing extra rotating mass to keep the mill from shaking itself to death.
    The 190 hp 1990 Quad Four Beretta was a surplussing potent car (for the price back then).
    They reduced the power on later years to try and help the terrible NVH levels.
    Who cares how much power an engine makes at XXXX rpm if the engine acts like it is destroying itself when run there.
  14. 08-11-2012 06:29 PM #14
    With out a doubt, its the GM 2300 (Chevy Vega). It's a testimony to how much damage you can do with a little knowledge. Next, I would say the GM Iron Duke.
  15. Member pontiac's Avatar
    Aug 3rd, 2009
    Nova Scotia, Canada
    08-11-2012 07:29 PM #15
    I don't think they sounded too bad...reliability wasn't one of their strengths though.
  16. Member classicjetta's Avatar
    Aug 23rd, 2005
    Columbus, Ohio
    2006 Volkswagen Jetta 2004 Ford Escape
    08-11-2012 07:33 PM #16
    I dunno about the Iron Duke being on this list, I mean that's what the USPS uses.
    The Ford Pinto engine is pretty mediocre though.
  17. 08-11-2012 07:39 PM #17
    The GM pushrod 2.2 that they used in the Crapalier for a couple of decades was pretty miserable. Noisy, no power, mediocre fuel consumption, and head gasket leaks were common.
  18. Member jimb's Avatar
    May 29th, 2000
    St. Louis, MO
    '12 A4, '12 Highlander, '06 Passat
    08-11-2012 07:44 PM #18
    The Chrysler 2.2 liter used int the K-Cars were known for blown headgaskets among other things.
  19. 08-11-2012 07:58 PM #19
    Quote Originally Posted by classicjetta View Post
    You can find them on a ton of smaller boats too.
    1975 Honda CB400F Super Sport
    1986 BMW 535i
    1984 BMW 745i turbo - FOR SALE
    2002 Passat 1.8t
    1990 Saab 9000 turbo
  20. Member Eightysixturbo's Avatar
    Jul 18th, 2011
    NJ
    2005 MCS "Hyper Blue", 2006 330ci "Silver Grey"
    08-11-2012 08:04 PM #20
    pardon my 'merican
  21. Member
    Jan 25th, 2005
    2003 GTI 24V VR6
    08-11-2012 08:08 PM #21
  22. Member Hurt's Avatar
    May 3rd, 2011
    Boston, MA
    1998 Jetta GT, 1998 GTI 2.0, 2012 GLI, 2012 GTI
    08-11-2012 08:25 PM #22
    The 2.0 SOHC 16v motor used in the Dodge/Plymouth neons from 95-99. They eat headgaskets like cookiemonster eats cookies..
    If you want to make your 2.0 8v faster, read the thread below!
    http://forums.vwvortex.com/showthrea...owerful-2.0-8v.
  23. Member 1985Jetta's Avatar
    Mar 11th, 2012
    SC
    See sig
    08-11-2012 08:29 PM #23
    The 2.0 Split Port in Focuses. Known for dropping valve seats.
    2 Skylarks, 3 Suburbans, G30, diesel C30, 3 Malibus, 3 Cutlasses, Caballero, Trofeo, Caprice, Torino, TR6, Ninja ZX-10, Concours, Odyssey, E39, GC, GP, mk2, Dakota 5.9 R/T, E38, 2 Mavericks, Mark VIII, Ion, C10, Reaction 150, W210, Titan. PS: I use my ignore list.
    Texcraft | The turd thread. | My mk2 Build |
    Quote Originally Posted by kwik!gti View Post
    I own a rare and collectible Civic.
  24. Member mhjett's Avatar
    Oct 16th, 2000
    Northern Virginia
    2008 VW Jetta SE
    08-11-2012 08:47 PM #24
    My dad had a '91 Grand Am with the high-output Quad Four - it sounded like a bunch of rocks in a blender and felt like it too, but he never had any reliability issues that I can remember (over 30k-some miles).
    1995 VW Jetta GLX VR6 [07.2003 - 03.2012]
  25. Member Señor Peligro's Avatar
    Aug 6th, 2009
    Sort of Fancy
    Honduh VTAK
    08-11-2012 08:51 PM #25
    Baahahahahaha
    I love you people
    "My car only needed a tow 6 times in 4 months, but since it was nothing major it's no big deal. The car is reliable."
    Now go get your shinebox
  26. Member
    Jun 15th, 2010
    Northeast
    08 335i
    08-11-2012 08:53 PM #26
    B21A in the 90 - 91 Honda Prelude Si. I am too lazy atm to look up pictures, but they are absolutely horrible. It's shocking I still drive Honda's after owning that car, literally a giant turd. I checked the oil after every gas fill up.. From my understanding it was the worst Honda engine ever made, by a LOOONG shot.
    Oil burning, piston ring eating POS. After 120K the engine was completely shot.
    past = AP1 S2000
    present = 08 335i sport
  27. Member crisvr6's Avatar
    Jun 14th, 2007
    swiss basel
    3ltr vr6
    08-11-2012 08:59 PM #27
  28. Member GPHawaii808's Avatar
    Jul 5th, 2006
    Hawaii
    Oldsmobile Intrigue
    08-11-2012 09:03 PM #28
    Whatever craptastic engine that the 2004-2006 Mitsubishi Lancer's came with. No power and terrible mileage.
    Kent McKenzie - eCommerce/BDC Manager
    Windward Dodge Chrysler Jeep & Windward Hyundai
    North American Grand Prix (NAGP) - Sim Racing League
    http://northamericangp.com/index.php...tpage&Itemid=1
  29. Member
    Jul 3rd, 2006
    Toronto, ON
    2011 jetta tdi
    08-11-2012 09:17 PM #29
    Quote Originally Posted by VR6Now View Post
    that engine would run for ever. sound like crap and loud but run forever. And you could fire in the cylinder head bolts in with an impact gun and good to go.
  30. Member Cubster's Avatar
    Nov 26th, 2002
    Fort Worth, Texas
    08-11-2012 09:21 PM #30
    Quote Originally Posted by crisvr6 View Post
    Again....that motor is bulletproof.....it's the car around it and the blower that are the problem.
  31. Geriatric Member BRealistic's Avatar
    Dec 16th, 2005
    Tennessee
    88 F150, 04 RX8
    08-11-2012 09:23 PM #31
    Quote Originally Posted by unintended acceleration View Post
    The fibrous cylinder wall engine?
    IIRC- you could just throw new rings in and go.
    The cylinder walls were so strong they never seat the rings.
    So while they "ate rings", the engine was far from shot.
  32. Member David802's Avatar
    Feb 22nd, 2011
    SLuT
    08-11-2012 09:27 PM #32
    Quote Originally Posted by Cubster View Post
    Last time I checked, the blower was part of the engine...
  33. Member bustedbucket's Avatar
    Mar 22nd, 2010
    Dat two one fifth
    Jaggernaut & egg of robin
    08-11-2012 10:08 PM #33
    In terms of a real turd, the pont-a-mousson 4 for the facel vega facellia comes to mind. Holed pistons in very short order.
    And speaking of vega, there was the cosworth vega known for unstellar reliability. They sound great though!
    As for personal experience, whatever was in the '88-'89 excel was pretty terrible(mitsu orion?). No zip and poor reliability. Dailied one of those until it gave up the ghost in pretty dramatic fashion.
    Worst sounding car i've dailied was a '90 escort with the 1.9. Reliability wasn't too bad, just a pretty gutless and very rough engine.
    '86 Jaguar xj-s 5.3HE coupe, cobalt blue metallic/blue
    '08 Hyundai Accent SE hatch, ice blue/gray
    Bisixually disposed, lucas charged and coventry clothed
  34. Member
    Jun 15th, 2010
    Northeast
    08 335i
    08-11-2012 10:23 PM #34
    From what I recall, there was no compression in one of the cylinders. It was something to do with the cylinder walls and the cylinder having 0 compression.. I didn't have the money to pay someone to 100% diagnose the problem and replace anything but from what I recall the kid I sold it to knew a local mechanic, who said a cylinder was done, 0 compression. I don't know enough about what happened to say for sure, and I don't think you can either Who knows what happened after that, maybe you have experience with these engines, I moved on and didn't really care.
    I sold the car for 500 bucks and moved on to an EF Civic hatchback and put a B16 engine in it from hmotorsonline. Best move ever at the time and had a complete blast but I will never forget that POS 91 Prelude.
    I don't recall the rest of the details and you may on to something. I was 21 years old, in college, and broke at the time to go back and try to fix a car thtat would hardly run and literally sputter when it was running. Felt like it had 50 HP... For a Honda, it was absolutely horrible and a terrible experience. I bought it expecting a sporty little ride to get me through college. It was before I even had a computer so I couldn't research these things prior to buying it and when it was gone I had already swapped the b16a into my EF so I didn't really care to look back...
    I feel old now.
    past = AP1 S2000
  35. Member alleghenyman's Avatar
    Nov 20th, 2003
    Pittsburgh
    2010 Kizashi, 2008 Fit Sport; 2000 Toyota 4Runner; 2012 Fiat 500 Sport, 1975 MGB, 1975 Honda CBR
    08-11-2012 10:30 PM #35
    The quad four was a remarkable engine for its era. I recall the issue being that it didn't have balance shafts in 190 HP trim. When they added balance shafts it went down to 150 HP. But hardly a dolt of an engine.
    Completely unrelated to your post: I love MKIV hate-buttbois. Decent factory performance, 33 mpg on the highway, 50% power gains from boost on stock internals, an engine that outlasts the turbo, transmission, and electrical system of the car its in - none of you know what you're talking about. Its like all the forum jokes from ten years ago about a few bad coil packs and plastic water pumps were a formative part of your puberty and you still smack off to the memories.
    "You see, I am for the great loves and the great hates."
    -Enzo Ferrari
