Page 3 of 6 FirstFirst 1 2 3 4 5 6 LastLast
Results 71 to 105 of 183
Thread: OEM LED tail lights in hand! Help requested!
    Oct 25th, 2011
    Fairfield County, CT
    2011 Jetta S
    08-23-2012 11:15 AM #71
    Quote Originally Posted by gt4ever View Post
    Darn.. should have waited for a later model
    You could do it yourself or pay the dealer to install (god only knows what they would charge). Or like I said I am making flipside a plug and play harness and can do the same for anyone else, just PM me for details.
  2. Member gt4ever's Avatar
    Jun 9th, 2012
    2012 1.4 tsi comfortline (Euro)
    08-23-2012 11:22 AM #72
    Quote Originally Posted by Verebs1 View Post
    Rather pay the dealer and let them do it professionally though.
    I guess the best thing I can do now is to replace the drl to led :p
    By any chance you know where can I find genuine jetta optional accessories like body kits etc?
    Oct 25th, 2011
    2011 Jetta S
    08-23-2012 11:39 AM #73
    There is a body kit thread.
    Also You dont need to pay the dealer to make you a harness and then plug it in lol. You wouldnt pay someone to make you breakfast and start your car too... or would you???
  4. Member clutchrider's Avatar
    Dec 10th, 2010
    Connecticut
    2012 GLI
    08-23-2012 12:01 PM #74
    So your making a harness to plug n' play these? Is that w/ or w/o the need for computer work? We definitely need to meetup.
    Oct 25th, 2011
    2011 Jetta S
    08-23-2012 12:11 PM #75
    Quote Originally Posted by clutchrider View Post
    Im not 100% on that as I havent got a pair to try and the parts arent all here but when they arrive and I ship them im sure flipside will tell me. If any VCDS is required it should be easy to turn off the bulb monitoring.
  6. Member
    Oct 25th, 2011
    2011 Jetta S
    08-24-2012 09:11 AM #76
    BTW found this /Fail today
    No LED tails LOL
  7. Member jettsy's Avatar
    Mar 28th, 2011
    Orlando, FL
    2011 Jetta
    08-24-2012 09:38 AM #77
    looks like gli tails...
    btw thats a terrible ad
    SteveMKVI JettaMy Car Activate Full MFD MK6 Jetta DIY
    Oct 25th, 2011
    2011 Jetta S
    08-24-2012 09:40 AM #78
    Quote Originally Posted by jettsy View Post
    Yeah Agreed BTW did you read the comments LMAO
    Oct 25th, 2011
    2011 Jetta S
    08-24-2012 11:24 AM #79
    Quote Originally Posted by OEM VAG PARTS View Post
    We installed the lights in this Jetta GLI in Mexico left some videos
    Test!
    http://youtu.be/iOxM32jfyiI
    Installed!
    http://youtu.be/7L2HTusjkIM
    Had a question about how you wired the outer tail lights as in your friends video they are correct. VW Surf wired his wrong.
  10. Junior Member
    Dec 4th, 2011
    Rio de Janeiro
    08-24-2012 03:38 PM #80
  11. Junior Member
    Dec 4th, 2011
    Rio de Janeiro
    08-24-2012 07:38 PM #81
    Need some coding help if anyone can chime in..
    http://forums.vwvortex.com/showthrea...a-Tsi-Highline
  12. Junior Member
    Dec 4th, 2011
    Rio de Janeiro
    08-25-2012 08:54 AM #82
    Finally got everything working perfectly. It required code 53 and byte 18. No errors and all lights working as they should.
  13. Member
    Apr 22nd, 2009
    NJ
    '12 Jetta GLI
    08-25-2012 09:34 AM #83
    Noted
    Post up more photos!
  14. Junior Member
    Dec 4th, 2011
    Rio de Janeiro
    08-25-2012 05:31 PM #84
    More pics and a video..
  15. Member EuRoGTI86's Avatar
    Sep 27th, 2008
    LongIsland, NY
    2012 Volkswagen Jetta S, 2010 Kawasaki KLR650
    08-25-2012 08:34 PM #85
    R.I.P. Allen A.K.A. vr6inside98. 89'-11' I LOVE YOU MAN
    Tri state area. VAG-COM (VCDS) Scans/Mods available (HEX+CAN)/Suspension install available/Fender rolling available. Send me a PM for pricing!
    Instagram- @mr_toffee
  16. Member
    Oct 19th, 2011
    brunswick oh
    bagged stage 3+ 2012 gli, k04 2010 jetta wolfsburg, 2010 tdi cup edition, 2009 jetta tdi
    08-28-2012 08:59 AM #86
    I just purchased a set of the tails off oemvagparts now I need to figure out how to wire them up like flipside99
  17. Junior Member
    Dec 4th, 2011
    Rio de Janeiro
    08-28-2012 10:05 AM #87
    Quote Originally Posted by bmain0407 View Post
    Contact Verebs1, he's making adapters.
  18. Member
    Oct 25th, 2011
    2011 Jetta S
    09-02-2012 10:40 AM #88
    These are Flipside's
    (The end connectors are missing because he already has them)
    BTW these support rear fog if you have lights with it.
    These
  19. Member
    Aug 14th, 2012
    TEXAS
    2013 VW GLI AUTOBAHN
    09-04-2012 01:58 AM #89
    Success! Flipside's byte 18 coding (53) works perfectly if all you add are the led tails and have an 086 CECM. Thanks to flipside and JETTA BRAZIL's excellent writeup on his blog. Made for a super simple install. Pics incoming.
    '13 GLI Autobahn
  20. Member
    Aug 14th, 2012
    TEXAS
    09-06-2012 05:53 PM #90
    Quote Originally Posted by JuanERdz View Post
    '13 GLI Autobahn
    Spoke too soon. After looking carefully, it seems my brake lights are a little dim. the turn signals are fine (nice and bright). Will experiment with more coding. Mine does not have rear fog from the factory so that might explain why the code does not work for me. With my default 00, I only got errors for left and right tail light. None for brake or turn signals. Code 53 gives no errors but not enough brightness.
  21. Junior Member
    Dec 4th, 2011
    Rio de Janeiro
    09-30-2012 11:28 AM #91
    Well.. we might be using the wrong code, although I think the brightness is fine... we're most certainly wired wrong.
    This appears to be the only video so far of what the LED tails are supposed to look like from the factory. (Go to 1:55)
    I can't be sure without seeing the turn signals on, but it appears to be much closer to OEM VAG PARTS who posted this before:
    Now this is the confusing part.. The outer lights only have 3 pins in the plug. According to the bottom video there are 3 separate lights (Parking, brake and signal) which would mean 4 pins (1 for each light plug ground)..So either there's 2 versions of these lights floating around or mine are broken.
  22. Member
    Feb 4th, 2011
    Pee Dee Ecks
    09-30-2012 12:04 PM #92
    Quote Originally Posted by flipside99 View Post
    I'm guessing there is a US version and a EU version. VW has been moving to using all red brake/running/directional lights so the EU version likely has a turn signal element for amber turn signals that is missing from the US version.
    Opinion plug: I think red turn signals looks like ass. Especially where they use a single bulb/element for both. Looks cheap and looks like a copout to be cheap.
  23. Junior Member
    Dec 4th, 2011
    Rio de Janeiro
    09-30-2012 12:43 PM #93
    I agree, but.. The Hybrid is only for the NAM market, so why would there be 2 versions of the tail lights?
  24. Member
    Oct 25th, 2011
    2011 Jetta S
    09-30-2012 03:09 PM #94
    There is a euro hybrid
  25. Member
    Aug 14th, 2012
    TEXAS
    09-30-2012 03:09 PM #95
    I believe they are beggining to offer these as options in the EU. So thats probably why. I havent had time to experiment any further but I do think we are wired right because that is how the stock lights work and that is how similar lights on Golf and EOS work as well.
    '13 GLI Autobahn
  26. Member
    Aug 14th, 2012
    TEXAS
    09-30-2012 03:12 PM #96
    I see what you mean with the video. But then where are the turn signals? Would it be like most american cars that use the same bulb for brake and turn? I think how we wired them looks much better.
    '13 GLI Autobahn
  27. Junior Member
    Jan 14th, 2009
    2012 GLI Autobahn 6MT
    10-11-2012 12:49 AM #97
    So if 53 worked for byte 18, then what was it before? Any more thoughts on the brightness of them?
    2012 GLI TR 6MT
    APR ECU / APR DP+AWE Track / Carbonio / FK Konigs
  28. Member
    Oct 25th, 2011
    2011 Jetta S
    10-11-2012 01:38 AM #98
    The turn signals are where I told you they were, in the clear lens on the outer lamps just like the Passat has.
    Similar to this
  29. Junior Member
    Dec 4th, 2011
    Rio de Janeiro
    10-11-2012 07:21 AM #99
    While I thought that was the case from the mexican's video, there's no wire for them.
  30. Member
    Oct 25th, 2011
    2011 Jetta S
    10-11-2012 09:54 AM #100
    thats so strange, I need to get my hands on a pair of these and check them out.
  31. Junior Member
    Dec 4th, 2011
    Rio de Janeiro
    10-11-2012 09:58 AM #101
    As you can see in this picture from earlier in the thread, only 3 pins.. ground, parking/brake, signal, there would need to be a 4th pin for the signals to be in the clear part.
  32. Member
    Oct 25th, 2011
    2011 Jetta S
    10-11-2012 10:00 AM #102
    Right but three wires doent mean three bulbs, as I think they multipurposed one wire. Were you ever able to take that thing apart? It should be possible as there is a light bulb in there in some set of the LED tails as the parts list shows it.
  33. Junior Member
    Dec 4th, 2011
    Rio de Janeiro
    10-11-2012 10:02 AM #103
    A bulb? and not LED?
  34. Junior Member
    Dec 4th, 2011
    Rio de Janeiro
    10-11-2012 10:05 AM #104
    ok, I'm tearing this bitch apart after lunch.. It's driving me nuts.
  35. Member
    Oct 25th, 2011
    2011 Jetta S
    10-11-2012 10:17 AM #105
    Yeah the parts diagram shows a regular bulb with the LED tail light, there is only one part # set in the catalog for them where as the inner lights have multiple sets (one for NAR, one for EUR, and one for UK). The Item #6 is the back-up light which we already know is also a regular bulb.
