Wheels/tires and suspension details
Wheels are 5Zigen FN01RC 17x10 with a +35 offset
Spacers are 25mm converting 5X100 to 5X114.3
Tires are 295x17 Hoosier A6
H&R RSS coilovers revalved to Madmax specs
700/1300 lbs linear springs
Modified front bar (elongated mounting arms to cut the rate)
Stock rear bar
Custom ball joint relocating plates (BJ extenders) with caster offset allowing over -5 degrees of camber
Custom adapters spacing the wheel/tire combo and also allowing a more available 5x114.3 bolt pattern (finding wheels wide enough and with the right offset in 5X100 is impossible)
Madmax rear adjustable control arms
Front swaybar modification (reducing the bar's rate)
Rear swaybar modification (increasing the stock rear bar rate and making it adjustable)
Race wheel/tire fitment and weight (43.4 lbs)
OEM fat 5 with small 245 tires weight comparison (47.0 lbs)
MCPI Delrin forward control arm bushing
Front wheels at full droop with view of fender rolling
Outer front control arm view of the ball joint relocating plates
Front coilover and inner wheel/tire clearance
Rear view at full droop
[/URL]
[/URL]
[/URL]
PM the details, good sir.
My black TT is getting more attention these days and I'll be up and running hopefully this spring so looking into future plans.
