Results 1 to 11 of 11
Thread: Tire size
  1. Member T.Pego's Avatar
    Aug 29th, 2005
    NYC
    '02 Passat | '12 Cannondale | '09 Rollerblade | '84 Chevrolegs | LOOKING FOR A Mk2!
    08-11-2012 09:21 PM #1
    Just bought a 2002 and it needs tires. Found a set of 16" classix on a 2008 rabbit with 225/45 tires. Would these fit my passat?
    Sent from the mobile interwebz using my calling device
    Quote Originally Posted by DorkyJoao View Post
    you know i cant resist a nice fat juicy hotdog all up in my mouth....
    Mar 4th, 2012
    Ohio
    03 Passat AWM, previous B4 Passat, previous Mk3 GTI
    08-11-2012 10:57 PM #2
    Depends on if the bolt pattern is the same...
    The B5 and the B5.5 Passats bolt patterns are usually 5x112 if I'm not mistaking.
    I'm not entirely sure on the 08 Rabbit. I'd gather it's going to be different.
  3. Member uNLeaSHeD.'s Avatar
    Aug 28th, 2010
    A Ditch in Wisconsin
    Bagged B5.5, MKV Jetta
    08-11-2012 11:04 PM #3
    Quote Originally Posted by T.Pego View Post
    Yea they should, 225 is the width which sounds right, but 16s with 45 series tires might look a little small and funny looking make wheel gap look bigger then it already is but idk I have 18in wheels with 40 series on mine.
  4. Member
    Mar 4th, 2012
    Ohio
    08-12-2012 06:19 PM #4
    Opps my bad. I was thinking you found wheels, not tires haha. Sorry.
    But yes 225's do fit 16 inch wheels. Looks funky but it works
  5. Member T.Pego's Avatar
    Aug 29th, 2005
    NYC
    08-13-2012 10:37 AM #5
    Quote Originally Posted by IanInOhio View Post
    it is the same bolt pattern.
    Quote Originally Posted by uNLeaSHeD. View Post
    yea... thats what i was wondering, if the tires would be/look too small...
  6. Member
    Feb 15th, 2001
    01.5 A6 2.7T 6sp sport, 03 Passat wgn 2.8 5sp
    08-13-2012 12:05 PM #6
    Are you talking about wheels with tires on them - and are you sure they're not 17" classix which was the standard wheel that came on 2006 GTIs and had 225/45/17 tires - those will fit on a 2002 Passat - although the offset is a little low meaning there could be rubbing issues on the inside. I have 16" bionlines (07 Jetta) on my 03 Passat with 3mm spacers so I can use the original lug bolts for 30k miles with no issues
  7. Member T.Pego's Avatar
    Aug 29th, 2005
    NYC
    08-13-2012 12:35 PM #7
    yea, i mean with wheels and tires. I think you're right, that they're 17s. just looked at the thread again, and he didn't specify, but he's looking to possibly trade for 17s or 18s.
    said thread: http://forums.vwvortex.com/showthrea...25-45-South-NJ
    when you say rubbing issues on the inside because the offset is low.. you mean the inside of the wheel might graze along the brake calipers?
  8. Member E CODE's Avatar
    Feb 1st, 2005
    Toronto, Ontario
    Formerly London Dub B5.5 Passat V6 4mo Wagon, MK6 GTI 6MT
    08-13-2012 12:47 PM #8
    Quote Originally Posted by irishpaulmc View Post
    Mk5/6 offsets are usually HIGHER than what we need, which can casue rubbing issues if they are too high, but as you mention, a small spacer will clear it up.
    OP, those wheels will work, either straight up, or with a small spacer...
    Buy my clear GTI sidemarkers cheap!
    Will VagCom Mk5 and 6 in the GTA for donuts!
  9. Member T.Pego's Avatar
    Aug 29th, 2005
    NYC
    08-13-2012 01:18 PM #9
    Quote Originally Posted by E CODE View Post
    Positive? Cuz i'd be taking quite a ride to pick them up
  10. Member
    Feb 15th, 2001
    08-13-2012 09:22 PM #10
    Well I never said what offset was too low - ha ha - the Passat calls for an offset of 37 to 45 ish whereas the MK5s call for 50 to 55 or so - I believe the Classix are a 54 offset so OP I think you would need minimum 8mm spacers which means you will also need new lugs. Over $100 for spacers + lug bolts.
  11. Member T.Pego's Avatar
    Aug 29th, 2005
    NYC
    08-14-2012 08:39 AM #11
    thanks for the info. not going with those wheels then.
