VWVortex.com - Twitchy on the highway...
    Results 1 to 23 of 23
    Thread: Twitchy on the highway...
    1. 08-12-2012 01:02 AM #1
      Don't really know how to elaborate that well but this has happened twice now going >70 mph, the front tires seem to catch in a highway groove and then just let go abruptly. It's the first time it's happened to me in any vehicle I've owned and it's putting me at some unease. Pretty scary really, and I don't feel comfortable driving > 70 on all but straight lines. Is it an alignment issue? Or are the oem bridgestones really terrible.
      Has anyone else had this issue?
    2. 08-12-2012 01:10 AM #2
      I have the Hankook and they are the same. Its the tires. Maybe the bridgestones have similar characteristics consider the low to mid quality OEMs installed.
    3. 08-12-2012 01:12 AM #3
      So your car around curves at times abruptly turns you in the opposite direction of the curve?
    4. 08-12-2012 01:22 AM #4
      it catches the grooves of the highway and tends to pull that way. It can be because the my tires were at 45 psi making them a lot harder lending to riding them. I deflated them to 35 and do not ride as much. Check your tire pressure.
      So yes, it goes where the groove or lines go.
    5. 08-12-2012 08:28 AM #5
      It's called tramlining. Hankooks are sensitive to this more so if the tires are not broken in properly.
      Breakin in tires
      http://www.tirerack.com/tires/tirete...e.jsp?techid=5
      Tramlining
      http://www.tirerack.com/tires/tirete....jsp?techid=47
    6. 08-12-2012 08:46 AM #6
      Thank you for the terminology. I know this can happen, but the force with which it's happening is unsettling. I guess I'll check the pressures @ home and hope that is the reason.
      May 10th, 2003
      Issaquah, WA
      2012 VW Passat TDI SEL, 2012 VW Touareg TDI Lux
      08-12-2012 12:20 PM #7
      Having driven heavy all-wheel drive cars for 10 years and then going back to a lighter front wheel drive car with low profile tires I share your concern. I only experience it on deeply rutted highway but it can cause a back and forth motion that wakes you right up. I find that if you move to the left or right hand side of the lane that you are in and out of the ruts that it helps.
      Current: 2012 Passat TDI SEL / 2012 Touareg TDI Lux
      Past VW: 2005 Touareg 3.2 / 1996 GTI-VR6
      Past Other: 2007 Audi Q7 4.2 / 2007 BMW 328xi / 2006 Porsche Cayenne / 2003 Audi A6 3.0Q / 2001 Audi A4 2.8Q / 1998 Jeep Wrangler Sahara / 1991 Honda Accord EX / 1989 Toyota Supra
    8. 08-12-2012 01:05 PM #8
      Quote Originally Posted by markitzero View Post
      This car is a direct replacement for my 2008 VW jetta wolfsburg. That car didn't have this issue and it was just as light or lighter.
    9. Junior Member Dysprosius's Avatar
      Jul 16th, 2012
      Addison, Tx
      2012 Passat SE
      08-12-2012 01:30 PM #9
      This, besides my G35. I have often wondered if stiffening the steering wheel would help to compensate for this. I really miss how tight my A4's steering wheel was.
      Past Valiant Steeds: 2001 Audi AWE A4, 2004 Infiniti G35
    10. Member
      Jan 13th, 2012
      Mannheim, Germany
      2012 Passat TDI SEL, 2009 Corvette, 2005 BMW X3, 1990 Camaro RS 5.0
      08-13-2012 11:01 AM #10
      As much as I hate the noise these tires produce I must say that they are very stable at speed up to 110 mph. I live in Germany and I have not had any problems with them at all at high speeds. I am alway driving this car around 90 to 100 mph.
      U.S.Army
    11. Member
      May 28th, 2009
      Ft. Worth, TX
      2009 JSW TDI; 2014 Passat TDI SEL;2014 Toyota Avalon Hybrid; 2013 Ford Cmax Hybrid; 2015 Nissan Leaf
      08-13-2012 11:10 AM #11
      Quote Originally Posted by tonymey View Post
      Which tires? Bridgestone or Hankooks?
      I have found the hankooks very sensitive to PSI. The difference between 36 and 40 is quite noticeable at highway speeds...the higher the pressure, the twitchier the tires.
    12. 08-13-2012 08:50 PM #12
      For the most part, are the highways smooth in Germany? I ave zero issues on smooth highwys. I just got back fom lunch with another passat driver, and he complained of the same thing.
    13. Member brsexton's Avatar
      Mar 30th, 2012
      VA
      2012 Passat SE 2.5
      08-13-2012 09:00 PM #13
      I had this issue as well. I found out my tires had between 45-50 PSI all the way around. So much for dealer PDI. Anyway, I put them to the specs on the door sticker and it drives and rides so much better. Besides the noise with the Hankooks, I haven't had that touchy pulling issue since.
    14. Member
      Jan 13th, 2012
      Mannheim, Germany
      08-14-2012 02:35 AM #14
      I have the H-Kooks, and I keep the PSI at 33 as recommended by the door decal. The Autobahns are not always smooth, just like in the States, some bad some good.
      U.S.Army
    15. 09-01-2012 12:02 PM #15
      So after letting out about 3 psi's on all corners from 38 to 35, the tramlining has become way less noticeable. The car is however very uninspiring in the handling department.
    16. 09-01-2012 12:19 PM #16
      All part of the decision by VW to tailor the car for the "typical" North American driver. Sadly, that has taken some of that crispness of the handling. But I must say that I've had a chance or two to approach the car's limits on back country roads in the last couple of days and those limits are further out than you might think on a first impression of the car at normal speeds.
      Yours
      Vern
    17. Member turboDSG's Avatar
      Feb 1st, 2009
      Carlsbad, CA
      GLI Gen 3
      09-01-2012 02:22 PM #17
      we had a casual debate about tire PSI in another thread and I kept saying some people on here were insane having that much PSI for daily driving. This thread further shows that by the fact that just some groves in the road cause such a reaction at higher speeds.
      I'll reiterate this one more time.. a 10% increase in PSI over what is recommended by the manufacturer on the door can cause up to a 20% reduction in forward traction and 20 increase in braking distance.
      For the people in here mentioning close to 45+ PSI please consider how dangerous that can be given that calculation.
      2014 GLI Autobahn DSG | Unitronic Stage 1 | Neuspeed P-flo Intake | Maniacs Paddle Shifter Extensions | Carbon Fiber Wrap Interior Trim | deAutoKey HIDs & LEDs | Yellow Laminex Fogs | 35% Tint | 3M Gloss Black Roof | VCDS in North San Diego County Coast |
    18. Member
      May 23rd, 2008
      Richmond, VA
      2013/VW/Passat TDI SEL
      09-01-2012 07:44 PM #18
      Quote Originally Posted by turboDSG View Post
      Well said and well put! I have always found the increased pressure disconcerting! Mine were at 40 from the dealer, didn't realize it until a week later, and took them down to 35, much better! Still loud, but not twitchy! Wet traction leaves a little to be desired.
      This thread makes me wonder whether the people complaining about the Hankook's really just need to check their pressure. Most of the time, decreasing pressure will improve handling, and road manners.
      -Loki
      Sent from my iPad using Tapatalk HD
    19. 09-02-2012 12:07 AM #19
      Just got mine yesterday and it had a very noticeable vibration/shimy in the steering wheel. I read this thread and checked my tires. They were all between 45-50psi. I lowered them to 35psi. Much better now. Thanks
    20. Member turboDSG's Avatar
      Feb 1st, 2009
      Carlsbad, CA
      GLI Gen 3
      09-02-2012 01:28 AM #20
      Does everyone having such sky high psi have a TDI? Almost makes me think they are doing this to get impressive Mpg figures.. That would be very stupid.
    21. Member
      Mar 2nd, 2011
      CT
      2008.5 Passat VR6 4Motion/Sport Sedan
      09-02-2012 06:23 AM #21
      It might have to do with shipping...maybe less chance of flat spots on the tires when tied down?
      Regardless though, dealer prep should be taking care of this. 50 PSI is ridiculous for that car on the road.
    22. Member
      May 10th, 2003
      Issaquah, WA
      09-15-2012 11:27 AM #22
      It's the shipping pressure that isn't being lowered during PDI. The Toaureg that I bought 3 weeks ago was the same way... 48 psi all the way around.
    23. Member JJS119's Avatar
      Aug 26th, 2008
      Brooklyn, New York
      13 Eos, 05 Outback, 86 LeBaron, 84 Subaru GL, 83 300D
      09-16-2012 11:54 AM #23
      I have the Hancook's and use the recommend tire pressure on the door according to VW. I have a nice ride, is rock solid at 110 MPH, but are somewhat noisy and I have experience tramlining with them. Owning a repair shop, owning and driving SO many different cars, from Rolls Royce's to the biggest pieces of sh*t that should not even be on the road, that I don't even notice when the car is tramlining. I do know when I burn out these Hancook's which I am trying to do, I am buying a set of Michelin's or Continental's.
      Quote Originally Posted by Captain 'Murica! View Post
      I'd rather have AIDS than a diesel station wagon.
