VWVortex.com - 03 passat 1.8t smell
    Results 1 to 4 of 4
    Thread: 03 passat 1.8t smell
    1. Member xxkoadyxx's Avatar
      Mar 18th, 2010
      Nova Scotia.. P.C
      93 golf TDI (sold..), 2003 passat 1.8T daily(sold), 95 cutleas (sold), 2013 jetta tdi (newcar)
      08-12-2012 09:43 AM #1
      hello, i have a 1.8t passat. it has 230k on the body and under a little over 90k on new motor that was swapped in. The engine light is on, says P0420, Catalyst System Efficiency Below Threshold (Bank 1)
      my question is, what causes the car to smell? it did have bad sparkplugs and 7 engine codes on, but sense changing the spark plugs, only the p0420 comes on and says its pending a p0118.. I have so far got a max of 540kms on one tank
      thanks guys! im not use to all this computerized stuff
      Vw mk6 Jetta TDI bagged! Daily
      Vw mk3 4dr golf stg 3 malone TDI- sold
      Vw b5.5 passat 1.8t- sold
      95 cutlass supreme- sold
      @stanceeast
    2. Member sdavis872's Avatar
      Aug 20th, 2009
      Omaha, NE
      2003 VW Passat W8 6 speed
      08-12-2012 04:43 PM #2
      Quote Originally Posted by xxkoadyxx View Post
      Maybe a bat cat? Say it's efficiency is not up to par and if there's a smell like it's not working, then maybe it's shot... just a thought. Really depends what it smells like.
      \\_\__\___http://lowdownlabs.com/ ___/__/_//
      Passat W8 Sport 6 speed manual
      BC Racing Coilovers | Avant Garde M550 19x9.5 | Delinte Thunder D7 245 35 19 | COAM
      SpeedTuning USA Stage 2 | B6 S4 calipers | S5 rotors | Stop Tech Pads
    3. Member xxkoadyxx's Avatar
      Mar 18th, 2010
      Nova Scotia.. P.C
      08-12-2012 06:44 PM #3
      it smells like oil/gas , but iv been checking my oil and hasnt burned any and theres no smoke or gas leaks.
      @stanceeast
    4. Member nolesfan's Avatar
      Mar 9th, 2011
      Nutley, NJ
      2013.5 GLI Autobahn
      08-13-2012 10:23 AM #4
      The smell could be a cracked PCV component, such as breather tube (from oil filter housing).
