VWVortex.com - need some tranny help
    Results 1 to 15 of 15
    Thread: need some tranny help
    1. Member vwturbofox's Avatar
      Jul 31st, 2010
      washington,everett
      1989 vw fox gl turbo, Holset hx35w on meth:)new project 1968 bug and o 86 gti
      08-12-2012 01:47 PM #1
      last night i had to be towed home. i blew up my tranny 2nd gear blew had all the other gears but didn't wan't to hurt the motor trying to limp home cause it was clunking bad
      my question is does anyone know of a super strong tranny that i can get to handle 350hp 400torque
    2. Member kerensky's Avatar
      Mar 5th, 2001
      Norman, OK
      '89 Fox GLS, '89 Fox wagon, '73 914, '72 'vert.
      08-12-2012 04:34 PM #2
      Just collect PSA's and swap 'em out every 6 months or so.
      Seriously, about the only real option I'd know of would be to use a Quattro drivetrain. Might be possible to block off the driveshaft and just use it as a FWD gearbox...
    3. Member vwturbofox's Avatar
      Jul 31st, 2010
      washington,everett
      08-12-2012 05:00 PM #3
      i also heard you can get a passat tranny and modify it in but i don't nkow how hard it is to get it in
      right know if i can't get a tranny i will put the motor and all the goodies in a rabbit i know i can get good trannys for them and just sell the fox im tired of blowing up trannys this is the fifth one costing me alot of money
    4. Member denver_fox's Avatar
      Oct 15th, 2011
      Denver, Colorado
      93 SLC---93 2dr---88 wagon---79 Jimmy
      08-12-2012 05:14 PM #4
      Quote Originally Posted by vwturbofox View Post
      Don't be a biznatch! Keep the fox.
      Are the 4000s or a quantumTD tranny's stronger? I know they have more ideal gearing(in my mind anyway)
      Apr 16th, 2006
      Brokelyn, NY
      90 fox, 85 gli
      08-12-2012 05:44 PM #5
      What were the problems with using a FWD B5 tranny? I know the mount location is different, but it shouldn't be too hard to fabricate something. You might need to hammer out the tunnel a bit to fit it.
      It's a hydraulic setup, so you'd need to figure that out. Custom axles. Modified linkage maybe.
      But that should handle 300whp fine I imagine.
      I really suck at smog.
    6. Member vwturbofox's Avatar
      Jul 31st, 2010
      washington,everett
      08-13-2012 01:12 AM #6
      Quote Originally Posted by ziddey View Post
      B5 tranny? never heard of it any pict or links so i can look at one and wat kind of cars are they out of
      Apr 16th, 2006
      Brokelyn, NY
      90 fox, 85 gli
      08-13-2012 08:44 PM #7
      b5 as in b5 passat/audi a4. There was a thread about it one time but I can't find it.
    8. Member vwturbofox's Avatar
      Jul 31st, 2010
      washington,everett
      08-14-2012 03:48 PM #8
      i talked to AA transaxle he told me to go with a audi 5000 tranny or a 944 tranny any thoughts
      Oct 1st, 2007
      Ontario, Canada
      '90 VW Fox Turbo, '93 Grand Cherokee V8
      08-14-2012 05:55 PM #9
      As far as I know both these transmissions won't bolt up to your engine, so unless you want to get into having a custom adapter plate made and all the issues that come with it, the B5 transmission still seems like a better option! After all, custom mount, massaging the tunnel and adapting a hydraulic clutch pedal isn't that much work considering how far you've gone on the motor (I know)
    10. Member vwturbofox's Avatar
      Jul 31st, 2010
      washington,everett
      08-15-2012 09:33 AM #10
      i think i will go with the b5 tranny just cause i know there are alot of them out there.
      i just hope i can get it done quick cause i miss driving the fox had to drive my slow ass truck with only 75hp i miss my 350hp fox
    11. 08-15-2012 10:40 AM #11
      several years ago I asked about the audi a4 FWD tranny. Some years they came as a cable models and was told by several it couldnt work. I will try to did up those emails why they told me no. Short of custom axles and mounts, I didnt see why but was told it was way more to it than that. My reason for trying is they are pretty cheap now, proven to hold power, and have good aftermarket and you can easily find LSDs for them (no more looking to Brazil).
    12. Member vwturbofox's Avatar
      Jul 31st, 2010
      washington,everett
      08-17-2012 02:52 AM #12
      Quote Originally Posted by Mr Roo View Post
      do you know what year the cable models are thanks
    13. Junior Member mr.kyle.henderson's Avatar
      May 15th, 2012
      Cali
      1991 1.8L Volkswagen Fox, coupe.
      09-01-2012 08:08 PM #13
      IDK if it will or will not work but I do know that the Audi 5000 transmission is LEGIT. I drove one of those like you wouldnt belive up and down mount baldy road for months and the transmission handled like a dream
      "Next time you have to go to work, why don't you try using a Volkswagen?"
      "The day you are done with it, Is the day you trade it for another."
    14. Member QuantumSyncro's Avatar
      Apr 28th, 2000
      Des Moines, IA
      97 Jetta TDI, 1990 Passat TDI wagon, 92 300SD turbo
      09-01-2012 10:26 PM #14
      Quote Originally Posted by mr.kyle.henderson View Post
      It won't, the mountings for the 5 banger are different than the 4. The only cross-over I know of is the 88/89 Audi 80 quattro trans (don't remember code) that has mountings for both 4 and 5 cyl.
      The 9Q is a pretty stout transmission though for FWD, they used it on the turbo D cars and the NA diesel cars with AC.
      steve
      The words you're using, they don't mean what you think they mean.
    15. Member themagellan's Avatar
      Mar 30th, 2007
      East
      1991 Audi 200 20vt Quattro
      09-02-2012 11:58 PM #15
      I have a Audi 4000 Transmission/Motor sitting in my garage.
      That being said, why don't you find a 4speed and put that in there. From what I've seen/read they are a lot stronger, and with 300+Whp it might be nicer since you'll be sitting in boost a lot longer.
      Other options to consider:
      Get a weaker clutch or get weaker tires... This way when something needs to break it isn't your gears it's something that is a friction based material.
