Results 1 to 15 of 15
Thread: im at a loss for words! need help -6 camber!
  1. Junior Member
    Feb 11th, 2011
    dallas
    1970 beetle, 1988 jetta gl
    08-12-2012 09:39 PM #1
    i just lowered my jetta racelands teardrops new control arms with the hybrid bushings took it to get an alignment and i have -6 degrees of camber on my front drivers side wheel and it wont adjust out
    bent steering knuckle or what?
    any other suggestions
  2. Member Greg_J's Avatar
    Oct 30th, 2005
    Grand Bend ON Canaduh
    Montana Green '92 GTI w/ OBD2 ABA swap - '03 Jetta Wagon TDI 6spd
    08-12-2012 09:48 PM #2
    you can adjust the camber on it... loosen the 2 bolts holding the coilover to the knuckle and pull it out. once you play with it you should be able to see whats up.
    also, take it to shop that knows how to align mk2's. its super easy to adjust the camber to your desire.
    Quote Originally Posted by ennui_delphian View Post
    Don't anger canadiun lesbian...
  3. Junior Member
    Feb 11th, 2011
    dallas
    08-12-2012 09:51 PM #3
    i did that lol it went from 6.1 to 6
    the pass side is fine. this side just wont i can get more negitive but i cant get any more positive out of it
    camber kit?
  4. Member s-rocc's Avatar
    Nov 26th, 2001
    reassembled in a garage, pa
    bunch of old german junk
    08-13-2012 12:23 AM #4
    where is your ball joint mounted? did you try sliding that in?
  5. Member Greg_J's Avatar
    Oct 30th, 2005
    08-13-2012 12:37 AM #5
    something is grossly wrong then..... with my coils i could angle between +2 camber and -5 camber just by adjusting the joint between knuckle and coils
  6. Member
    Aug 22nd, 2004
    clifton, Nj 07011
    08-13-2012 12:54 AM #6
    The ball joints should be centered in their slots. Maybe you can slide the whole subframe over. I think mark 3 upper bolts have a smaller diameter for more adjustment.
  7. 08-13-2012 01:26 AM #7
    ive never seen that much camber even pushing in the adjustment on the strut (in you case, the coilover) maybe somethings bent, maybe you mounted something wrong. id get that checked out asap
    Apr 21st, 2008
    MA
    Mk2 Diesel for sale
    08-13-2012 01:30 AM #8
    Quote Originally Posted by elementsoffury View Post
    Maybe you can slide the whole subframe over..
    I have a hunch this is the problem. The subframe is shifted to the driver side and thus it's moving the ballpoint further from the vehicle than it should be. (the lower munts are cocked making your range of adjustments wrong).
    At least this is my theory.
    USMC Graduated 1st RTBN C.CO. PLT 1028
  9. Junior Member
    Feb 11th, 2011
    dallas
    08-14-2012 11:10 PM #9
    i put smaller bolts on it and pulled it out some.
    the ball joint is all the way in
    didnt think you could shift the subframe
    it was hit on the drivers side so wouldnt you think it slid closer to the pass side?
    this is my first watercooled car ive been in aircooleds for years though.
    and its all mounted up right its only on the drivers side
    im going to get mk3 front brakes here soon and see if that solves the problem
    thanks for the ideas yall
  10. Member
    Aug 22nd, 2004
    clifton, Nj 07011
    08-15-2012 01:33 AM #10
    There's like .5 inch of adjustment possible on the subframe. Probably not enough to cause your issue. I moved mine over after I replaced it because I didn't like the wheels sticking out farther on one side.
    When you're swapping the brakes; look for symmetry in the front mounting locations. Like the subframe being bent / cracked. Upper shock towers looking off, stuff like that. Possible that the holes on the strut bottoms are in the wrong locations, but I've never heard of this before.
    Hopefully it's just a bent steering knuckle
  11. Member Seax_Smith's Avatar
    Jun 1st, 2007
    Not Present.
    Newest, 92 GTi half-swap plus
    08-15-2012 01:44 PM #11
    If it is not a botched install, you need camber bolts (and new camber bolt nuts).
    Dealer has them, I know there are 18mm'ss and think there are 17'mm's as well.
    Start with just replacing the top bolt and working the play you get.
    If that isn't enough, replace the top AND bottom bolt.
    If the car was fine before the instal and only one side is messed up after the install, I would seriously check the install.
    Keep the ball joints centered in the slots unless you like playing with axles/ CV joints.
    Thanks for calling. Your call is very important to me. If you would like to reach me by phone now, please hang up now. If you would like to reach me by phone later, please hang up later. If you would like to speak with a person, please press ten. ..... I'm sorry I do not understand one zero. Please hang up now or later if you cannot press ten.
  12. Junior Member
    Feb 11th, 2011
    dallas
    08-16-2012 12:04 AM #12
    that side had camber before i thought the aligment was just off
    mk3 brakes in the works as of right now along with g60 rear brakes
    thanks for the input this waterpumper is gunna be the death of me lol
  13. Geriatric Member VDub2625's Avatar
    Jan 3rd, 2003
    Fall River, MA
    90 Jetta GLI 16v, 99.5 Cabrio Highline
    08-16-2012 12:58 AM #13
    Edit nevermind
    A2Resource
  14. 03-24-2013 03:51 PM #14
    Was there a solution for this? I'm having the same problem.
  15. Member ChainNoise's Avatar
    Oct 31st, 2008
    South Jersey 08270
    98 GTi
    03-24-2013 05:50 PM #15
    looks like mk3 control arms on a mk2.
