Results 1 to 8 of 8
Thread: Cant re-install dipstick tube
    Dec 17th, 2004
    Colorado Springs
    08-13-2012 02:40 AM #1
    so, I pulled out my dipstick tube to fix a leak, and now i can't get it to go in and seat all the way. its hitting something before the o-ring starts to even seal.
    anyone know how the tube needs to bend? what am i hitting inside?
    86 1.6 n/a
  2. Member ragnar's vw's Avatar
    Oct 3rd, 2004
    Puyallup, WA
    '63 bug,'84 rabbit diesel
    08-14-2012 10:35 PM #2
    spit on it...
    I didn't do much today, but i'am going to give it hell tomorrow.
    Sep 20th, 2010
    Salem, Oregon
    1977 VW Scirocco 1.8/Weber carbs, 1986 VW Golf Diesel, 1978 Rabbit 1.6
    08-14-2012 11:00 PM #3
    Drop the pan...it's quick and easy......and check it out. The dipstick tube actually rotates a bit while it goes in/out, and it's easier to see what's going on with the pan off.
  4. Member
    Dec 17th, 2004
    Colorado Springs
    08-15-2012 09:38 AM #4
    before i pull the oil pan, i have a spare block torn down, ill put the oil pump back on and see if i can get the dipstick bent right to slide into place.
    Jul 14th, 2011
    outside philadelphia
    '86 mk2 D/ '86 mk2 D '98 TDI
    08-17-2012 12:14 PM #5
    dipstick tube bends real easy, and wont go back in same way as it was, use tube from other block if you have one, while your taking it out you need to be real careful cause it can get a little jammed and then the bend changes real easy. gl.
    Type I's
    the "little" D
    also 962 -0 to 60 in 4 years-
    why??more than 1 wire to shut her off?? a blasphemy!
  6. Member
    Mar 31st, 2008
    PNW - Oregon
    08-17-2012 01:34 PM #6
    Quote Originally Posted by air-cooled or diesel View Post
    the portion that actually installs into the engine, isnt even bent, its 100% straight..
    but you already knew that, since you are such a VW guru..
    thanks for that post captain obvious!
    Dec 17th, 2004
    Colorado Springs
    08-17-2012 06:18 PM #7
    it turned out the dipstick was too long. it was hitting the bottom of the oil pan. took off the pan, and it sticks out past the oil pickup. cut about an inch off and alls good.
    Jul 14th, 2011
    08-31-2012 01:53 PM #8
    Quote Originally Posted by Glegor View Post
    if i recall correctly, its bend slightly toward rear, some bend thats not stock isnt a prob.
    azz
    Type I's
    the "little" D
