Closed Thread
Page 9 of 11 FirstFirst ... 5 6 7 8 9 10 11 LastLast
Results 281 to 315 of 356
Thread: Aonarch's Carpool Lane Hero!
  1. Senior Member Aonarch's Avatar
    Dec 4th, 2006
    10-08-2012 03:24 PM #281
    Quote Originally Posted by nikhsub1 View Post
    I'm using the ballasts but I'm using 6K morimoto bulbs... no issues so far. Is 11 even enough at 70MPH?
    I hit the overdrive button.
    Cross fingers that the Morimoto's fix the issue.
    I got a right side bulb out error today as well. Very annoying I was hoping for a trouble free setup.
  2. Member nikhsub1's Avatar
    Apr 17th, 2008
    Los Angeles
    2011 JSW TDI 6MT
    10-08-2012 04:49 PM #282
    Quote Originally Posted by Aonarch View Post
    Do you want my complete long coding for the central elec unit? You can then compare and even try what I've got... I'll hook this bish up to the VAG if you want it, it's no problem
  3. 10-08-2012 05:28 PM #283
    The car looks great man, I look forward to hearing your opinion of the APR tune
  4. Senior Member Aonarch's Avatar
    Dec 4th, 2006
    10-08-2012 07:12 PM #284
    Nah it is alright! I'm going to go swap the ballasts out now see if that fixes it.
  5. Senior Member Aonarch's Avatar
    Dec 4th, 2006
    10-08-2012 08:09 PM #285
    Swapped out the ballast no fix.
    Did some coding, now low beams work, but the brights do not.
  6. Senior Member Aonarch's Avatar
    Dec 4th, 2006
    10-08-2012 11:51 PM #286
  7. Senior Member 98DUB's Avatar
    Feb 21st, 2003
    Lowlife, WA
    MKIII VR6
    10-09-2012 01:00 AM #287
    When are the painted side markers shipping out?
  8. Senior Member Aonarch's Avatar
    Dec 4th, 2006
    10-09-2012 11:36 AM #288
    Quote Originally Posted by 98DUB View Post
    Not sure. I haven't heard back from the guy one when his new paint booth will be ready. He said it should be soon, so hopefully next week.
  9. Senior Member 98DUB's Avatar
    Feb 21st, 2003
    Lowlife, WA
    MKIII VR6
    10-09-2012 12:01 PM #289
    Oh wow, didn't know you actually were getting some. Nice! That will make the front end complete IMO
  10. Senior Member Aonarch's Avatar
    Dec 4th, 2006
    10-09-2012 12:03 PM #290
    I'd rather have tinted than amber, but ultimately color matched is the best.
    The only reason I haven't gotten any yet is I want to do it right the first time. So finding the best painter is important to me.
  11. Senior Member 98DUB's Avatar
    Feb 21st, 2003
    Lowlife, WA
    MKIII VR6
    10-09-2012 12:32 PM #291
  12. Member nikhsub1's Avatar
    Apr 17th, 2008
    Los Angeles
    2011 JSW TDI 6MT
    10-09-2012 03:31 PM #292
    Do the brights work if you flash and hold the stalk? Or not work at all? If they work but won't stay engaged, you need to check a box in the last byte - says something like, intermittent high beams enabled or something. When you read it you would think that if checked it would do the opposite of what it does.
  13. Senior Member Aonarch's Avatar
    Dec 4th, 2006
    10-09-2012 04:20 PM #293
    Yeah I checked that byte.
    They do not work at all. No flash to pass, or permanent on.
    I saw an option for shutter installed. I am going to play around with that tonight.
  14. Member nikhsub1's Avatar
    Apr 17th, 2008
    Los Angeles
    2011 JSW TDI 6MT
    10-09-2012 06:56 PM #294
    It's coding... if you check HID with shutters installed, they won't work at all so I bet you have that checked somewhere.
  15. Senior Member Aonarch's Avatar
    Dec 4th, 2006
    10-09-2012 07:14 PM #295
    I am 99% sure none of those are checked!
    So the only coding I need is DRL's off and the momentary whatever right?
  16. Member nikhsub1's Avatar
    Apr 17th, 2008
    Los Angeles
    2011 JSW TDI 6MT
    10-09-2012 07:57 PM #296
    Ima go get my full long code.... you are officially killing me
    2F380E3A902F3EC4008800016000000003005586531D056064 0020200040
    Copy your entire long code and save it, paste mine above in and save changes in VAG. Voila, lights should now work
  17. Senior Member Aonarch's Avatar
    Dec 4th, 2006
    10-09-2012 08:15 PM #297
    Thanks will do.
  18. Member nikhsub1's Avatar
    Apr 17th, 2008
    Los Angeles
    2011 JSW TDI 6MT
    10-10-2012 07:10 PM #298
    Well WTF did it work?
    Revo Tune / afe Intake / Neuspeed Turbo Exit Pipe / Mufflerectomy / ST Coils / Golf R Steering Wheel & Shifter / DG Short Shift Kit / RNS-510 / MKV R32 Brakes Front & Rear / Euro Golf R HIDs / Nurburgrings / S53 Whispbars
  19. Senior Member Aonarch's Avatar
    Dec 4th, 2006
    10-10-2012 07:30 PM #299
    Left my windows laptop at work! Will try soon!
  20. Member nikhsub1's Avatar
    Apr 17th, 2008
    Los Angeles
    2011 JSW TDI 6MT
    10-10-2012 08:28 PM #300
  21. Senior Member Aonarch's Avatar
    Dec 4th, 2006
    10-11-2012 05:56 PM #301
  22. Member VR6's Avatar
    Jul 21st, 2000
    United States
    2012 Subaru Outback | 2013 VW JSW (Awaiting Delivery!)
    10-11-2012 08:12 PM #302
    Previous VW's: 2000 GTI (Sold), 2004 Volkswagen R32 (Sold), 2003 Volkswagen Passat Wagon 4MO (Sold), 2006 Jetta (Sold)
  23. Senior Member Aonarch's Avatar
    Dec 4th, 2006
    10-11-2012 09:49 PM #303
    Quote Originally Posted by VR6 View Post
  24. Member Seventhundersrx's Avatar
    Feb 26th, 2006
    VA
    2011 Golf TDI
    10-12-2012 01:04 PM #304
    As stated earlier, I am done with modding for now, besides Saturday's APR tune. In the future I will get a R line steering wheel, bags, and a DPF delete.
    You may want to think about not going APR if you're doing the DPF delete, as their software does not support it like Malone's does. FYI. Car looks great though!
  25. Senior Member Aonarch's Avatar
    Dec 4th, 2006
    10-12-2012 01:15 PM #305
    Quote Originally Posted by Seventhundersrx View Post
    PM Sent.
  26. Member CRJSW's Avatar
    Aug 7th, 2011
    Abingdon VA/Clarksburg WV
    10 JSW TDi
    10-12-2012 02:42 PM #306
    So you going to get the Flash done at 129euro? I may think about coming down that way we can compare the Malone STG.2 straight pipe with the APR. I have a 6MT also.
    If not Ill just put her up on jack stands and start to paint my calipers and maybe go in and do the dampener outlet delete.
    And Heck Ive paid for 3 tunes on my car already and the Malone is not my favorite but the only one I could run straight with.
    2010 Sportwagen_ 92 Corrado G60
  27. Senior Member Aonarch's Avatar
    Dec 4th, 2006
    10-12-2012 02:50 PM #307
    Going to APR HQ tomorrow for the flash.
    Probably sticking with that, until I get further info on the TDI Cup Car goodies.
  28. Senior Member 98DUB's Avatar
    Feb 21st, 2003
    Lowlife, WA
    MKIII VR6
    10-12-2012 03:00 PM #308
    Fix your lights yet?
  29. Member
    Jan 31st, 2012
    Southern California
    2012 GTI (6speed + sunroof / nav)
    10-12-2012 03:16 PM #309
    Aonarch, please stop posting so you don't force me into buying a second car
  30. Senior Member Aonarch's Avatar
    Dec 4th, 2006
    10-12-2012 07:02 PM #310
    I just got my Miromoto's in so tackling it Sunday.
    Quote Originally Posted by Ryyyyyy View Post
  31. Senior Member Aonarch's Avatar
    Dec 4th, 2006
    10-14-2012 12:49 AM #311
    Went to APR HQ today for the BBQ and got a stage I tune while there. So initial thoughts; WTF?! I can't tell at all. What a freaking rip off! Then I go, wait a minute maybe it is in stock mode. Switch to performance mode, VROOOM WOOOAH! SWEET! It feels smooth and pulls super strong. I have put 200 highway miles on it since the tune, but tomorrow I will go to the twisties and mess around, but so far I love it. The horsepower bump is extremely valuable, while the torque bump is crack. It had "enough" torque before, now it HAS torque.
    DPF delete is nice, sure, but for 99% of people a simple stage I tune is enough. Next up is DPF delete, turbo, and injectors.
  32. Member Jedidub's Avatar
    Oct 6th, 2010
    Earth
    Magic carpets powered by unicorn turds
    10-14-2012 01:30 AM #312
    Car looks badass man
    It's ok if you disagree with me, I can't force you to be right.
    2010 JSW TDI
    2011 CC R-line
    2012 Beetle turbo
  33. Member VR6's Avatar
    Jul 21st, 2000
    United States
    10-14-2012 08:49 AM #313
    Love the gas station picture of your ride! Lots of white VW's in the pics. I think I spy two white JSW's too including yours.
    What are the HP/Torque number increases by doing the APR Stage 1 tune?
  34. Member
    Mar 5th, 2011
    Gurnee IL
    2010 Jetta TDI soon 2013 JSW TDI- 6sp.manual
    10-14-2012 09:30 AM #314
    How much was the APR tune?
  35. Senior Member Aonarch's Avatar
    Dec 4th, 2006
    10-14-2012 12:36 PM #315
    Quote Originally Posted by Jedidub View Post
    Thanks!
    What I love is APR dynos the car, tunes it, and then re-dynos it. They actually show legitimate gains not just OMG UP to 1000horses?!!
    Yeah there were two white JSW TDIs there, including an APR sleeper.
    Quote Originally Posted by JAXKXX View Post
    $500 + sales tax. IIRC $544.
    Regarding the tune:
    At first I was upset. I took the car for a test drive and I felt no improvement. I was about to ask for a refund, but then... I thought wait a minute, maybe they left it in stock mode? So I play around with the stalk and set it to performance mode. MUCH BETTER! The horsepower increase is not a lot, but IMO it makes the car much more livable. Before 140hp was just not enough. I also have a 2.5L Golf with 170hp and it has a perfect amount of power for a daily driver. Now I am on 2.5L level, so I am happy. But wait there is more... Torque. Sweet jesus. Does it have torque!
    So now the car is faster than ever needed for a commuter car, which I absolutely love. Better passing power, better power for towing/ hauling, and more fun.
    MPG, I will be comparing my MPG before and after since I use fuelly.com and I will be testing the fuel consumption based on the same M-F commute. I did notice the MFD on the 200 mile drive home indicated better fuel consumption.
    So honestly I do expect the fuel economy to increase rather than decrease, based on an increase in efficiency.
    I would highly recommend the tune to everyone at the price point it is at. Think about this, an intake is $250-300 and it doesn't do squat, meanwhile a full remap is $500 and it has proven gains.
Closed Thread
