Is that hoe the levers sit without them being adjusted? If you take the cable off do the levers retract? If they stay down chances are you will need new calipers. If they pop up into place where they belong its most likely cables. I beleive you can use MK2 or 3 calipers unless they are the larger brakes. Cables most likely for MK2.
