Originally Posted by
burn_your_money
Does it make a difference if the cold start is pulled out or not?
Have you double checked the timing to make sure the crank gear isn't slipping?
It could be an issue with the pump. Do you know it's history?
Is the stop solenoid loosing power? You could hook a test light up in the cabin to verify this.
You could try turning the residual fuel screw in (the one that the throttle arm rests on at idle) and see if that helps.
Does it stall if you rev it up in the driveway and let the RPMs drop?
Do you have air bubbles in the fuel lines?
