Results 1 to 6 of 6
Thread: Class Action Bluetooth settlement module coding
  1. 08-14-2012 12:42 AM #1
    I received the class action bluetooth module and was trying to see if it could be coded to display the phone/call info in the MFD between the tach and speedo. When I open the long coding on the module there is no info for the module and no descriptors for the bits.
    I did notice from the factory, it has the same long coding as the 9w7 module and also that switching bit 4 from 00 to 01 disables A2DP as it does on the 9w7 module. Can you guys provide any other suggestions to get this working?
    2010 Jetta Sportwagen
    Sunday,12,August,2012,10:40:03:46007
    VCDS Version: Release 11.11.3 (x64)
    Data version: 20120401
    Chassis Type: 1K0
    Scan: 01 03 08 09 15 16 17 19 1C 25 2E 42 44 46 52 56 62 65 72 77
    VIN: 3VWPL8AJ5AM647243
    01-Engine -- Status: OK 0000
    04-Steering Angle -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    19-CAN Gateway -- Status: OK 0000
    1C-Position Sensing -- Status: OK 0000
    2E-Media Player 3 -- Status: OK 0000
    42-Door Elect, Driver -- Status: OK 0000
    46-Central Conv. -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    56-Radio -- Status: Malfunction 0010
    62-Door, Rear Left -- Status: OK 0000
    65-Tire Pressure -- Status: OK 0000
    77-Telephone -- Status: OK 0000
    Address 01: Engine (CJA) Labels: 03L-906-022-CBE.clb
    Part No SW: 03L 906 019 CL HW: 03L 906 022 TS
    Component: R4 2,0L EDC G000SG 7966
    Revision: 12H02--- Serial number:
    Coding: 0050072
    Shop #: WSC 25016 444 13939
    VCID: 77D337BC06D6651
    No fault code found.
    Readiness: 0 0 0 0 0
    Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
    Part No SW: 1K0 907 379 AH HW: 1K0 907 379 AH
    Component: ESP MK60EC1 H30 0107
    Revision: 00H30001
    Coding: 114B600C49260001880D06E8921C0042300000
    Shop #: WSC 00066 000 00000
    VCID: 78D13480CBC86A9
    Address 08: Auto HVAC (J301) Labels: 3C8-907-336.clb
    Part No SW: 3C8 907 336 AJ HW: 3C8 907 336 AJ
    Component: Climatic H14 0305
    Revision: 00009001
    Coding: 0000001002
    Shop #: WSC 00066 000 00184
    ASAM Dataset: EV_Climatic A01005
    ROD: EV_Climatic_VW36.rod
    VCID: 75CF3DB4D4DA171
    Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
    Part No SW: 5K0 937 085 G HW: 5K0 937 085 G
    Component: BCM PQ35 B++ 111 0128
    Revision: BI111001
    Coding: 2D380E3A902F3EC480080001400000C401000086535D856064 8020000000
    VCID: 3753F7BC8656A51
    Subsystem 1 - Part No: 1K1 955 119 F Labels: 1KX-955-119.CLB
    Component: Wischer 16120 21 0512
    Coding: 009795
    Address 15: Airbags (J234) Labels: 5K0-959-655.clb
    Part No SW: 5K0 959 655 B HW: 5K0 959 655 B
    Component: AirbagVW10G 019 0706
    Serial number: 003C4D07MWEL
    Coding: 00003045
    ASAM Dataset: EV_AirbaVW10SMEVW360 A01012
    ROD: EV_AirbaVW10SMEVW360_VW36.rod
    VCID: 3957F184B842B31
    Seat occupied recognition:
    Subsystem 1 - Part No SW: 1KM 959 339 HW: 1KM 959 339
    Component: BF-Gewichtss. 007 0001
    Serial number: ---0000R--0004YMB000
    Crash sensor for side airbag; driver side:
    Subsystem 2 - Part No SW: 1KM 955 557 HW: 1KM 955 557
    Component: S.Sens.Fahr.V H01 ----
    Serial number: 3572MSME6841534CZZZ-
    Crash sensor for side airbag; passenger side:
    Subsystem 3 - Part No SW: 1KM 955 557 HW: 1KM 955 557
    Component: S.Sens.Beif.V H01 ----
    Serial number: 3582MSME264D244DZZZ%
    Crash sensor for side airbag; rear driver side:
    Component: S.Sens.Fahr.H --- ----
    Serial number: 3511HSME4A58231EZZZS
    Crash sensor for side airbag; rear passenger side:
    Component: S.Sens.Beif.H --- ----
    Serial number: 3521HSME5858231EZZZS
    Crash sensor for front airbag; driver side:
    Component: F.Sens.Fahr --- ----
    Serial number: 35527SME0C42591EZZZN
    Crash sensor for front airbag; passenger side:
    Component: F.Sens.Beif --- ----
    Serial number: 35627SME504A731EZZZL
    Address 16: Steering wheel Labels: 1K0-953-549-MY9.lbl
    Part No SW: 1K0 953 549 CF HW: 1K0 953 549 CF
    Component: J0527 056 0111
    Coding: 0000732
    VCID: 78D134800BC86A9
    Subsystem 1 - Part No: 5K0 959 542 Labels: 3C8-959-537.CLB
    Component: E221__MFL-TAS H05 0010
    Coding: 00000130
    Shop #: WSC 00000
    Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
    Part No SW: 5K0 920 970 Q HW: 5K0 920 970 Q
    Component: KOMBI H03 0305
    Serial number: 00000000000000
    Coding: 270F00
    Shop #: WSC 00066 000 00149
    ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04052
    ROD: EV_Kombi_UDS_VDD_RM09_VW36.rod
    VCID: 3C59E890B770869
    Address 19: CAN Gateway Labels: 1K0-907-530.lbl
    Part No SW: 1K0 907 530 AD HW: 1K0 907 951
    Component: J533 Gateway H07 0111
    Revision: H07 01 Serial number: 281009F2000934
    Coding: E9807F07001612002002
    VCID: 69F761C44062C31
    Address 1C: Position Sensing Labels: 1Kx-919-xxx-1C.lbl
    Part No SW: 5N0 919 879 HW: 5N0 919 879
    Component: Kompass 001 0001
    Revision: 00001000 Serial number: 1225223T6HVT04
    Coding: 0000002
    VCID: FEDDA298A9ECD49
    Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
    Part No SW: 5K0 953 234 HW: 5K0 953 234
    Component: IMMO H03 0305
    Serial number:
    Coding: 000000
    Shop #: WSC 00000 000 00000
    ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03005
    ROD: EV_Immo_UDS_VDD_RM09_VW36.rod
    VCID: EAF59EC80D64489
    Address 2E: Media Player 3 (J650) Labels: 5N0-035-342.lbl
    Part No SW: 5N0 035 342 B HW: 5N0 035 342 B
    Component: SG EXT.PLAYER H13 0090
    Revision: A1001003 Serial number: 7667652855
    Coding: 010000
    VCID: 266D2AF851FC2C9
    Address 42: Door Elect, Driver (J386) Labels: 3C0-959-70X-GEN4.clb
    Part No SW: 3C0 959 701 B HW: 3C0 959 793
    Component: TUER-SG FT 002 0307
    Revision: 13101005 Serial number: 0000164927
    Coding: 0004B5
    Shop #: WSC 01383 790 50316
    ASAM Dataset: EV_DCU42BroseDriveSide A03004
    ROD: EV_DCU42BroseDriveSide_VW36.rod
    VCID: 277327FC5EF6351
    Slave Driver:
    Subsystem 1 - Part No SW: 1K0 959 703 AH HW: 1K0 959 795 T Labels: 3C0-959-70X-GEN4.CLB
    Component: J388__TSG-HL 006 1401
    Serial number: 00000004575736
    Coding: 000490
    Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
    Part No: 1K0 909 144 H
    Component: EPS_ZFLS Kl. 70 2901
    Revision: 00H17000
    Shop #: WSC 02069 000 90108
    VCID: 2F43CFDCBE066D1
    Address 52: Door Elect, Pass. (J387) Labels: 3C0-959-70X-GEN4.clb
    Part No SW: 3C0 959 702 B HW: 3C0 959 792
    Component: TUER-SG BT 002 0307
    Revision: 15101005 Serial number: 0000158379
    Coding: 0004B4
    ASAM Dataset: EV_DCU52BrosePasseSide A03004
    ROD: EV_DCU52BrosePasseSide_VW36.rod
    VCID: 287124C053E83A9
    Slave Passenger:
    Subsystem 1 - Part No SW: 1K0 959 704 AH HW: 1K0 959 794 T Labels: 3C0-959-70X-GEN4.CLB
    Component: J389__TSG-HR 006 1401
    Serial number: 00000004470431
    Coding: 000490
    Address 56: Radio (J503) Labels: 5M0-035-1xx-56.clb
    Part No SW: 1K0 035 180 AC HW: 1K0 035 180 AC
    Component: Radio Prem-8 H10 0035
    Revision: -----20S Serial number: VWZ4Z7J3050344
    Coding: 0100040004
    Shop #: WSC 00066 123 12345
    VCID: 61E779E478528B1
    5 Faults Found:
    00874 - Treble Speaker Front Left (R20)
    011 - Open Circuit
    Freeze Frame:
    Fault Status: 01101011
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 151
    Mileage: 84897 km
    Time Indication: 0
    Date: 2030.14.03
    Time: 10:34:33
    00875 - Treble Speaker Front Right (R22)
    011 - Open Circuit
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 151
    Mileage: 84897 km
    Time Indication: 0
    Date: 2030.14.03
    Time: 10:34:33
    00877 - Treble Speaker Rear Right (R16)
    011 - Open Circuit
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 151
    Mileage: 84897 km
    Time Indication: 0
    Date: 2030.14.03
    Time: 10:34:33
    00870 - Bass Speaker Front Left (R21)
    011 - Open Circuit
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 151
    Mileage: 84897 km
    Time Indication: 0
    Date: 2030.14.03
    Time: 10:34:35
    00871 - Bass Speaker Front Right (R23)
    011 - Open Circuit
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 151
    Mileage: 84897 km
    Time Indication: 0
    Date: 2030.14.03
    Time: 10:34:35
    Address 65: Tire Pressure (J502) Labels: 1K0-937-08x-65.clb
    Component: RDK 111 0821
    Coding: 018705
    Address 77: Telephone (J412) Labels: None
    Part No SW: USA 051 473 HW: USA 051 473
    Component: TELEFON H15 3510
    Revision: 1B001001 Serial number: 00007662959421
    Coding: 0A10040000010100
    Shop #: WSC 25155 444 12400
    ASAM Dataset: EV_UHVNA 002720
    ROD: EV_UHVNA_VW36.rod
    VCID: 1D1F05140CAAEF1
    End ---------------------------------------------------------------------
  2. 08-14-2012 09:29 AM #2
    I tried doing a channel map and got a csv file when doing adaptation but did not get anything when I doing measuring blocks, it just reads the controller and closes the controller screen so you are back at the channel map window. Also tried doing it through the autoscan with debug level set to 2 and didnt get anything either.
    I can email the csv file if needed.
  3. 08-20-2012 12:05 PM #3
    anyone have any info on this?
  4. Forum Sponsor Dana @ Ross-Tech's Avatar
    Sep 15th, 2009
    Apollo, PA
    02 Gti, 12 Tiggy SEL
    08-21-2012 08:13 AM #4
    Try the redirect file posted here with release 11.11.4:
    http://forums.vwvortex.com/showthrea...1#post78608411
    Let us know what you find when experimenting with that coding.
    Dana Marie
    P.S. No Scan = No Soup
  5. 09-14-2012 12:40 PM #5
    The settlement module is from a 3rd party. VWoA does not support it, it will not work with your steering wheel controls or MFD like the 9W7 will.
  6. 09-25-2012 12:49 AM #6
    Yeah, I had it installed 8/21 and couldn't believe there was no display. Service manager thought it was wrong too and ordered another one.
    Back on 9/14 for the replacement and finally one of the service techs chimes in with the bad news.
    I'm sure VW was pissed to lose the lawsuit and has done the absolute minimum to satisfy the judgment. I can't say I can blame them for being mad but, to purposely cripple functions of the car seems a little low.
