VWVortex.com - Traded my Honda Shadow for this...
    Page 1 of 3 123 LastLast
    Results 1 to 25 of 70
    Thread: Traded my Honda Shadow for this...
      Oct 31st, 2011
      Louisville, KY
      2014 Focus ST and lots of bicycles
      08-14-2012 08:40 AM #1
      Got bored with my cruiser, and I've been dying to build a cafe bike for a while. While this isn't exactly a good candidate, I did get offered this bike as a straight-up trade for my Shadow.
      It is big, it is heavy, it has plenty of power. Still learning about the bike, but the plan for now is to ride it until the winter and then tear it down and make some cafe-inspired changes to the bike.
      It does have the 2nd gear issue, though I can avoid having it pop out of gear if I baby it through second and use third to accelerate as necessary.
      Even with the many issues the bike has, I feel like it was a good trade-up for me and I am stoked to have another project in the garage.
    2. Member turbinepowered's Avatar
      Mar 18th, 2007
      Lubeland (KY)
      '86 Interceptor 700, '82 Quantum Coupe, Hyundai Elantra GT Daily
      08-14-2012 08:55 AM #2
      Nice. Is that a 1000cc? I'm on a phone screen, can't read the badging.
      I have an 83 CB650 Nighthawk that is my own current project, grafting a monoshock rest end and disc brake from a Sabre onto it, along with some other things. Looks good!
      There is an area of a normal brain that lets the owner know the object works and needs to be left alone. Not all of us have it. It is like being colorblind.
    3. Senior Member PowerDubs's Avatar
      Jul 22nd, 2001
      NWNJ
      08-14-2012 09:15 AM #3
      Not a good candidate? It's damn good as is.
      If anything, I'd just change out the gauges for a more traditional round setup, same with the mirrors and a larger round headlight. About the most extreme thing I might consider would be to loose the chrome rear fender / taillight...maybe. Ohh..and loose the cheezy foam handgrips.
      The seat and tail section are great already though. I'd stop there. I like more UJM than all out cafe, as I like to actually ride instead of pose. IE, don't go nuts with clubman bars or rearsets. The Supertrap is cool already also.
      Enjoy.
      -Josh
      1-12-5-8-3-10-6-7-2-11-4-9
    4. Member
      Oct 31st, 2011
      Louisville, KY
      08-14-2012 09:37 AM #4
      Quote Originally Posted by turbinepowered View Post
      1100. Crappy iPhone pics on my end don't help.
      Quote Originally Posted by PowerDubs View Post
      I'm pretty happy with the bike, just needs some bits here and there.
      The cruiser version has round lights, gauges, turn signals. They are all compatible (a little bit of wiring to make the gas gauge work), so I'll be scouring eBay for cheap ones.
      Yup. The rear section of the bike looks like it will look great by simply unbolting and removing the rear fender, the frame is perfect already.
      And yes, I hate the grips.
      Oct 31st, 2011
      Louisville, KY
      08-14-2012 09:42 AM #5
      Immediate plans:
      -New rear tire
      -flush brake systems
      -align front forks
      -fix horn so I can get it inspected/registered
      -clean air filters
      -bar end mirrors
      Long-term plans:
      -rear sets
      -remove/fix/replace second gear, whichever is most appropriate when I get inside the trans
      -pull/clean carbs
      -clean up tail section
      -handgrips
      -install progressive springs so I can ditch the pressurized front forks (previous owner had 90psi in them)
      -probably change up the handlebars, jury is still out on that one
      -probably wrap the exhaust
      I enjoy riding it, but it is so, so different from my 490cc cruiser I just got rid of. It will turn in and lean over, but it is a chore. Having more than ample power in any gear is great, though.
    6. Member LT1M21Stingray's Avatar
      Sep 13th, 2006
      Foothills of the Adirondacks.
      SR71 C30 t53a/b
      08-14-2012 10:03 AM #6
      Enjoy.
      I'd carve the foam flat, and I'd get the seat recovered.
      Quote Originally Posted by Tavarish
      The car's best safety feature includes ejecting you in the moment of impact and wishing you the best of luck.
    7. Member Knock Sensor's Avatar
      Jan 29th, 2009
      MA
      2005 Accord LX, 1980 Yamaha XS850(sold), 2002 Honda VTR1000, 2011 Triumph Speed Triple
      08-14-2012 03:23 PM #7
      Thats a big heavy bitch, but the motor is a gem. I've had the two little brothers to that bike, an xs750 and 850.
      To cafe it, I'd ditch the whole seat/fender/tail light completely and go with a fiberglass seat/aftermarket setup. New gauges to get a more low profile look. Clubman bars, you'd be surprised what clip ons/clubmans can do to how the bike feels and handles. Smaller led blinkers, new rubber, paint that front fender and maybe trim it down a bit. Bar end mirrors. Take off the passenger pegs/supports and make a bracket for your exhaust, though you'll probably cover that with rear sets.
      I'd completely rebuild second gear, seemed like all the big yamahas of this time period had 2nd gear issues if you beat on them. And any suspension upgrade will make it better, be it swapping to a different set of forks or rebuilding the guts, don't forget the rear either.
      Otherwise it should run great for thousands of miles. Stay on top of your electronics, carbs, and I'd change all the fluids out (engine oil, middle tranny oil, and final drive).
      edit: When I cafed my bikes I also removed everything that wasn't necessary. The box of random parts adds up.
      It ain't easy being an overweight, uneducated, Sunfire driving whoop whooping clown.
    8. Member turbinepowered's Avatar
      Mar 18th, 2007
      Lubeland (KY)
      08-14-2012 05:12 PM #8
      Ditto bolded. I also like the black exhaust headers. Planning to do that to the Nighthawk, which is also being done semi-Cafe/UJM.
      Quote Originally Posted by GoRacers View Post
      Gotcha.
      Oct 31st, 2011
      Louisville, KY
      08-14-2012 09:17 PM #9
      Quote Originally Posted by Knock Sensor View Post
      No joke. Thing weighs a ton. Just turning it around in the garage is a pain. The engine is a blast, though. Torque anywhere, great noise, very responsive and quick to rev up. I can't wait to see how it rides after a carb cleaning.
      I've found plenty of info on the 2nd gear issue and fix methods, so I feel more than ready to deal with that this winter.
      I'll probably go with the progressive springs for the forks. Already has a fork brace installed.
      From the looks of some of the wiring looms, this bike will have electrical gremlins at some point.
      Tires ordered and being installed Thursday
      Grips and bar end mirrors ordered, installed this weekend hopefully
      Need to figure out what to do about the stripped screw on the brake fluid reservoir cap. It turns, but doesn't back out any. I may just find a used MC on eBay and replace it, rather than risk downtime because I botched a drill/remove/tap job in the plastic MC reservoir. Front brake works okay, just have to really squeeze hard.
      Loving the bike, though.
    10. Senior Member PowerDubs's Avatar
      Jul 22nd, 2001
      NWNJ
      08-14-2012 09:35 PM #10
      Epoxy a cheap screwdriver, nail, piece of metal, whatever... to the screw and pull up on it as you unscrew it.
      Same concept is sticking a flat blade under the head of a stripped bolt to help it out but this way you won't tear up your mc cover.
      - Josh
      -Josh
    11. Member
      Oct 31st, 2011
      Louisville, KY
      08-15-2012 07:46 AM #11
      Carbs are coming off sooner than I hoped.Probably this weekend.
      Lost a cylinder for the entire freeway portion of my commute. Afterward, bike acted normal from the exit ramp to work, though. It doesn't like constant cruising at low rpms (3000-3500); feels like one cylinder stops getting fuel. Usually I can downshift to jump the rpms and get it back, but today it wouldn't.
      Thankfully, it does 60mph very easily on 3 of 4 cylinders.
    12. Member Knock Sensor's Avatar
      Jan 29th, 2009
      MA
      08-15-2012 10:51 AM #12
      If you have one of those sonic wave tool cleaners, those work great for cleaning carbs. Double check all the rubber cv pieces and make sure the floats aren't pinhole leaking.
      Can't wait to see any updates.
    13. Member
      Oct 31st, 2011
      Louisville, KY
      08-15-2012 05:19 PM #13
      Yeah, carb tear-down, cleaning, and syncing this weekend. Guaranteed shutdown of one of the cylinders any time I ask it for a constant 3-4000 rpm means that freeway riding sucks.
      Maybe I'll snap some pics during the process. Also plan on installing grips&mirrors, if they show up in time.
      I guess this is my build thread now?
    14. Member turbinepowered's Avatar
      Mar 18th, 2007
      Lubeland (KY)
      08-15-2012 05:47 PM #14
      I'm in. No more iPhone pics though.
    15. Member
      Oct 31st, 2011
      Louisville, KY
      08-16-2012 08:24 PM #15
      Rotated the bars about 10 degrees back for more comfort with the middle foot controls.
      Horn is toast, need to rig up a new one to pass inspection soon. Carb sync gauge acquired from coworker, happening this weekend.
    16. Senior Member PowerDubs's Avatar
      Jul 22nd, 2001
      NWNJ
      08-16-2012 09:01 PM #16
      How much does it weigh?
      If you decide to yank the seat and rear section, I'll take em.
      -Josh
    17. 08-17-2012 07:20 AM #17
      Rotated the bars about 10 back for more comfort with the middle foot controls.
      One thing you might consider is registering it as an antique or classic. I don't know the regulations of running one in Kentucky on those tags but I use them and never get hassled. Not that you shouldn't fix the horn, you should but at least here you don't have to mess with the inspection part on a bike registered this way.
      Very cool bike at that.
    18. Member
      Oct 31st, 2011
      Louisville, KY
      08-17-2012 07:48 AM #18
      Quote Originally Posted by pknopp View Post
      It may be worth looking into. I know for a car/truck, I could never get away with doing the classic registration due to the mileage restrictions.
      Either way, I use my horn very liberally with the idiots on the road here, so it gets fixed regardless.
    19. Member
      Oct 31st, 2011
      Louisville, KY
      08-17-2012 07:52 AM #19
      630 lbs curb weight. It is definitely heavy, but you get somewhat used to it and just learn to use a lot more force when turning in, etc.
      I don't have too radical of plans for the rear, probably just remove the fender and tuck the brake/indicator lights up underneath the current tail section somehow. The g/f has also started asking about riding with me a lot more often now, so the seat may stay, as well.
      But if I do remove it, you got first dibs.
    20. Member
      Oct 31st, 2011
      Louisville, KY
      08-17-2012 10:46 PM #20
      Girl's night out means I got to start the carb teardown early....
      Got the front brakes flushed. Much firmer lever now. Can finally get the front suspension to dive, just riding across the garage.
      New horn installed and wired. Completely overboard on the wiring, but it looks OEM so I am happy with it.
      On to the big ticket items...
      First off, let's start with this:
      To all of you people out there that overtighten EVERYTHING: stop doing that. I spent 45 minutes drilling out a stripped out bolt from the previous owner. The reservoir still needs to be replaced, because the bolt stripped out inside the PLASTIC housing.
      Torque specs. Look them up. Stop tightening everything you touch to "tight as I can get it."
      Rant over.
      Lots of parts in a 4-cylinder engine's carb setup...
      Found a hole in cylinder 3's diaphragm, and worn spots on every diaphragm...
      And again, STOP TIGHTENING EVERYTHING AS HARD AS YOU CAN.
      All in all, carbs look decent. All jets all look clean and clear. Torn diaphragms and lots of rust/buildup are the only problems I found tearing down the carbs. 1100xs is a convenient bike to sync, it looks like it can be sync'd and tuned with the tank unbolted and moved 3 inches toward the handlebars.
      More tomorrow.
    21. Member turbinepowered's Avatar
      Mar 18th, 2007
      Lubeland (KY)
      08-18-2012 12:30 AM #21
      Would these diaphragms work for you? Says they're new, they're probably JBM repops.
    22. Member
      Oct 31st, 2011
      Louisville, KY
      08-18-2012 08:07 AM #22
      I saw those on eBay, but the model years listed in the ad had me worried. The 78/79 bikes used different carbs than the 80+ bikes, so I don't think the parts are interchangeable.
      I came to post about the JBM diaphragms. Looks like I'll be ordering them. Searching DTT for their name showed positive results, so it sounds like they are decent quality parts.
      Definitely a damper on my weekend. Was hoping to have a strong-running bike by this evening, instead I am waiting on parts.
      Got conned into shopping with the lady friend instead.
    23. Member turbinepowered's Avatar
      Mar 18th, 2007
      Lubeland (KY)
      08-18-2012 05:28 PM #23
      I have a set of JBM diaphragms on my own bike ('93 CB750). They went on easily, good quality, and work great.
    24. Member
      Oct 31st, 2011
      Louisville, KY
      08-20-2012 01:05 PM #24
      Good to hear.
      Ordered them Saturday at ~10 a.m., they arrived today.
    25. Member
      Oct 31st, 2011
      Louisville, KY
      08-21-2012 08:42 AM #25
      Small progress last night. Put on the new grips and mirrors. Really happy with the look, especially for the price ($40 total, with shipping). Bike is BEGGING for round lights and gauges.
      Before:
      After:
      Hoping to get the carbs cleaned and put back together tonight, tuned tomorrow night.
