Results 1 to 21 of 21
Thread: Blown head gasket help!
  1. n00b kristamarie's Avatar
    Mar 1st, 2012
    Glendale, AZ
    95 VW GTI VR6
    08-14-2012 09:30 AM #1
    Saturday I was on my way to Mesa to rescue my fiance, because his car broke down, and I got as far as the loop 101 and pima fwy/90th st when my car dies. Got it checked out and there's definitely water in the oil, but the car still runs (boys did it against my wishes) and revs up fine, just blows white smoke. It's a 95 gti vr6 manual trans. I don't know where I can get the thermostat housing, since my workplace has it on back order and I need a place to get the head machined before replacing the gasket. HELP please!!
    live young and die free<3
  2. Member vortexpert.'s Avatar
    Sep 27th, 2009
    Avondale AZ
    98 GTI VR6 S/C, 98 GTI VR6, 02 2.0L 5 speed jetta wagon, Haro Mirra 540 Air
    08-14-2012 10:39 AM #2
    where is your work place?
    http://www.autohausaz.com/search/pro...mostat Housing
    autohaus has everything housing related.
    as for the head, is it warped? depending on the damage you may just be able to get a new gasket and be ok
  3. n00b kristamarie's Avatar
    Mar 1st, 2012
    Glendale, AZ
    95 VW GTI VR6
    08-14-2012 11:11 AM #3
    I work at O'Reilly Auto Parts, and I'm not sure if the head is warped or not yet, we haven't pulled it off to check.
  4. Member vortexpert.'s Avatar
    Sep 27th, 2009
    Avondale AZ
    08-14-2012 01:47 PM #4
    definitely have the head looked at, unless it got hot you should be ok with just cleaning and replacing the head gasket
    Sep 11th, 2009
    PHX
    08-14-2012 02:46 PM #5
    In 10 years I have seen exactly 3 VR's kill head gaskets and it was outside influence (driving while overheating)
    Oil mixed with coolant is more likely a bad oil cooler.. What's the engine oil look like?
  6. Member gtiguy12's Avatar
    May 22nd, 2006
    Phoenix, AZ
    08-14-2012 03:02 PM #6
    Bad oil cooler VR's typically don't blow white smoke, unless the crankcase is severely overfilled with coolant.
    Quote Originally Posted by VR6Vixen01 View Post
    In part, Jason has to run because it is faster than driving his car...
  7. Member vortexpert.'s Avatar
    Sep 27th, 2009
    Avondale AZ
    08-14-2012 04:55 PM #7
    Quote Originally Posted by kristamarie View Post
    thats what i read
  8. n00b kristamarie's Avatar
    Mar 1st, 2012
    Glendale, AZ
    95 VW GTI VR6
    08-14-2012 07:11 PM #8
    The oil is like a caramel color, and it's really runny. Which is how I know it has coolant in it. Apparently, it's missing the ect so that could have made the gauge not read that it was overheating...But I was just driving on the loop 101 and my coolant light popped on and I got off the highway right after that then the car just died and started steaming really bad. But my fiance said that the crankcase is filled with coolant. So you think it could just be the oil cooler? It'd be easier if that was the problem...I'm also leaking a lot of coolant out of the thermostat housing, which I'm replacing. It's also throwing coolant out of the exhaust, which is what's causing us to believe it is the head gasket.
  9. Member gtiguy12's Avatar
    May 22nd, 2006
    Phoenix, AZ
    08-14-2012 08:04 PM #9
    That car was never missing a CTS. Coolant temperature sensors read funny when there is no coolant in the system to read. Start with a cooling system pressure test to find out where the coolant is entering the engine from (either the oil cooler or the combustion chamber) then you will have a better idea of how to proceed with repairs.
  10. n00b kristamarie's Avatar
    Mar 1st, 2012
    Glendale, AZ
    95 VW GTI VR6
    08-14-2012 09:16 PM #10
    That's just what I was told, I didn't look at it. I may just get the head gasket, thermostat housing, timing chain and tensioner, and get the head resurfaced, just to be safe. I'll have the boys look at the car again and have them do the pressure test and stuff and have them take a look at the oil cooler since you all told me that could present a problem as well. But I had just checked my coolant and it was where it was supposed to be at, that's why I'm not understanding exactly what happened. =/
  11. Member MKIINIK's Avatar
    Nov 2nd, 2009
    Arizona
    2012 Golf R, 2012 TDI Jetta, 1966 VW Bug
    08-14-2012 10:44 PM #11
    That car definitely has a coolant temp sensor. It also has new tstat housing o rings and crack pipe. Sorry to hear she blew.
    2012 Golf R | GIAC | EVOMS | Autotech | H&R | BBS|
    ʎppǝɹℲ ɯɐǝ┴ Need Vinyl Cut? PM Me
    www.wheelsnob.com
    Get ur wheel on!
    Get ur gear on!
  12. n00b kristamarie's Avatar
    Mar 1st, 2012
    Glendale, AZ
    95 VW GTI VR6
    08-15-2012 10:12 PM #12
    Well its leaking out of the thermostat housing unfortunately :/ but ill get it figured out this car is my life<3
  13. Member MkII_Matt's Avatar
    Mar 29th, 2010
    Phoenix,AZ
    2.0t Star destroyer
    08-15-2012 10:43 PM #13
    did you call BAP for the thermostat housing?
    Instagram: The_matthew_osborne
    Quote Originally Posted by Ozzker View Post
    Official MK5 Boobies and Sax Thread.
    Some bolt on stuffs. Some moar lowz. Some software stuffs. Some rimz.
  14. Member Thrasher's Avatar
    Jul 18th, 2003
    Maricopa, AZ
    1987 Scirocco 16v, 1987 Golf GL 4dr
    08-16-2012 01:53 AM #14
    Unless you wanna be doing this job again next year, I'd advise against getting anything from your employer for this car shy of brake cleaner.
    Tornado Redneck - Team Infidel
    STOP PUTTING CORVETTE WHEELS ON VOLKSWAGENS
  15. n00b kristamarie's Avatar
    Mar 1st, 2012
    Glendale, AZ
    95 VW GTI VR6
    08-16-2012 03:27 AM #15
    I haven't called BAP yet, I was gonna do that sometime this week.
  16. Member vortexpert.'s Avatar
    Sep 27th, 2009
    Avondale AZ
    08-16-2012 10:38 AM #16
    just do a leak down test, there you will find if the head gasket is bad
  17. Member MKIINIK's Avatar
    Nov 2nd, 2009
    Arizona
    08-17-2012 11:09 AM #17
    Quote Originally Posted by vortexpert. View Post
    What London said.
    www.wheelsnob.com
    Get ur wheel on!
    Get ur gear on!
  18. Member justin123890's Avatar
    Feb 22nd, 2011
    phoenix
    2005 gli
    08-17-2012 11:39 PM #18
    Quote Originally Posted by Thrasher View Post
    Why is this?
    "Thats MY Purse! I dont Know YOU!"
  19. Member Thrasher's Avatar
    Jul 18th, 2003
    Maricopa, AZ
    08-18-2012 03:00 PM #19
    Quote Originally Posted by justin123890 View Post
    Why is this?
    Unless you dig super deep, the OE parts suppliers are hard to get, and the FLAP selection of remans/aftermarket is horrible.
    I know you work at O'Reily's (we've met, actually) but the quality just isnt here with most things.
  20. Member justin123890's Avatar
    Feb 22nd, 2011
    phoenix
    2005 gli
    08-18-2012 03:04 PM #20
    I wouldn't say most stuff. But some stuff yeah.
  21. Member vortexpert.'s Avatar
    Sep 27th, 2009
    Avondale AZ
    08-19-2012 02:01 AM #21
    some factory parts are **** in a box..
