VWVortex.com - FS: 03 Jetta 2.0 Automatic
    Results 1 to 5 of 5
    Thread: FS: 03 Jetta 2.0 Automatic
    1. Semi-n00b FrauleinVW's Avatar
      Apr 4th, 2011
      California
      2003 VW Jetta 2.0L
      08-14-2012 02:18 PM #1
      2003 MKIV Jetta GL 2.0 automatic w/113k miles (still in use so miles +), $5300 OBO
      Not parting out, not shipping, no trades, no personal checks, lowballers take a hike, etc.
      Royal Navy Pearl
      Clean Title in hand - passed smog
      Nevada car -> CA no rust.
      No accidents
      No damage
      Has intermittent P0420 code (catalytic convertor) but has passed smog, and is current for the next 80 or so days to be transferred clear, you then have 2 years to sort that issue until smog is due. Have a new car already and will not repair this issue, VW would not replace the unit at 102k miles (stated TSB for fix to 100k miles, they offered 1k towards a new car instead of fixing), leaving VW. The HUGE LIST and photos are below.
      Exterior/Running
      Glass headlight lenses with rockblocker film
      timing belt done at 90k miles
      new timing belt tensioner roller
      new metal impeller water pump
      new thermostat
      oil every 5k
      sparkplugs 15k ago
      accessory belt changed
      accessory belt tensioner
      new camshaft seal
      new crankshaft seal
      airfilter changed every 3rd oil change
      new fuel pump unit and sender float
      fuel filter
      front and rear O2 sensors 14k ago
      Brake fluid flush
      coolant flush and fill with Pentosin ++
      Maf cleaned every 10k miles
      New wiper blades
      Brand new replacement control arms with all new OEM bushings
      all new bolts
      new lower balljoints and bolts
      new upper strut mount
      new upper strut bearing
      new spring perches
      new strut tops
      Bilstein Touring Struts
      H&R OE Sport Springs
      new Brembo brake rotors PBR Metal Master brake pads 20k miles ago
      Rear beam replaced with low miles (35k) 20th anniversary GTI unit, with new beam bushings
      new rear hubs
      Bilstein Touring Shocks
      new mounts and bolts
      H&R 25mm swaybar
      17x7 VW EXOR Wheels with Kumho Ecsta tires with very good tread left
      Some clearcoat peeling on the front bumper from a rock hit (2")
      small key drag line down drivers side fender and doors (touch-up paint, clear and polishing compound
      included)
      Interior
      Tinted all around with front window strip
      black interior
      black door panels
      Floor mats (one clip missing)
      Seats in excellent shape
      Extras- depending on offer
      Car Cover
      BNIB Tie Rod Inner Tie Rod Ends, Outer Tie Rod Ends(1 L and 1 R set)
      Stock Springs
      Euro light switch
      MP3 hookup (not installed, aftermarket Blitz unit)
      Shorty antenna
      new heart valve, fan temp sensor and some heater lines NIB
      BNIB camshaft seal
      BNIB crankshaft seal
      replacement lower grill panel inserts
      20th AE GTI ashtray
      Home made radio removal tools (for the Blitz hookup)
      possibly more, have to look.
      More Photos Here
      PM for info or email byejetta(at)gmail.com, Located in the Azusa area.
    2. Semi-n00b FrauleinVW's Avatar
      Apr 4th, 2011
      California
      2003 VW Jetta 2.0L
      08-18-2012 02:15 PM #2
      Weekend Bump
    3. Semi-n00b FrauleinVW's Avatar
      Apr 4th, 2011
      California
      2003 VW Jetta 2.0L
      08-21-2012 12:33 PM #3
      UPDATE!
      Car has passed smog and is current for the next 80 or so days to be transferred clear, you then have 2 years to sort that issue until smog is due.
    4. Semi-n00b FrauleinVW's Avatar
      Apr 4th, 2011
      California
      2003 VW Jetta 2.0L
      08-24-2012 07:29 PM #4
      Friday bump, OBO everyone.
    5. Semi-n00b FrauleinVW's Avatar
      Apr 4th, 2011
      California
      2003 VW Jetta 2.0L
      08-27-2012 05:25 PM #5
      monday bump
