NOID Light shows pulse
Voltage is 5v with Ignition ON at injector
Car just cranks and cranks, Took the injectors out and cranked it and nothing is firing...
Fuel pump will only prime when I jump the relay.. My question is will the injectors fire with the relay jumped?
As of right now I have spark, I have compression, I have crank.. I have no fuel, This is not a swap car and the last motor that was in it worked perfectly electronically.. I have checked ground also...
Any ideas??
Any ideas??
