Results 1 to 9 of 9
Thread: OBX ITB's..... Help.
  1. Member simon-says's Avatar
    Oct 20th, 2007
    Portland,Oregon
    1978 Miami Blue 16v Rabbit on side drafts, 1980 Jetta Coupe,1988 Vanagon Wolfs., 2003 TDI Golf, and,
    08-14-2012 11:50 PM #1
    I'll make this short and sweet.
    I have idleing problems with these ITB's.
    2500rpm's fully closed.
    Megasquirt 3
    9A block
    X-Flow head
    11.5:1 comp.
    278 cam
    1mm oversized valves
    JE FSR pistons
    Any help would be appreciated. Thanks.
    VW&AUDI Performance Maintenance Repair.
    http://doublejmotorwerks.com/
    Northwest Premiere UnitedMotorsport Software Dealer
    APR Dealer. TDTuning Dealer. VAG-COM.
  2. Member SirSpectre's Avatar
    Mar 20th, 2011
    Milwaukee, WI
    Megasquirt 3x Powered 98 Jetta GT 2.0
    08-15-2012 08:04 PM #2
    You'd get a better response in the SEM, ITB/ Carb forum. BUT Yes. You will have idle problems with ITBs. Its just the way it is. ITBs are SSSSSUUUUPPPPPERRRR hard to get to idle well.
    Which tuning method are you using? Alpha-N or MAP? At any rate, try running it a little rich at idle. Warm it up and see if it gets better when not cold.
    98 Jetta 2.0 w/ Megasquirt 3/3x fully sequential
    ABA 16vT build thread
  3. Member Hurt's Avatar
    May 3rd, 2011
    Boston, MA
    1998 Jetta GT, 1998 GTI 2.0, 2012 GLI, 2012 GTI
    08-15-2012 08:48 PM #3
    278 cam? Do you mean 288? Or 298?
    ITB's are a PITA to tune. I'd look into your software if you can. Maybe have an expert take a look, maybe they can fix it?
    If you want to make your 2.0 8v faster, read the thread below!
    http://forums.vwvortex.com/showthrea...owerful-2.0-8v.
  4. Member simon-says's Avatar
    Oct 20th, 2007
    Portland,Oregon
    08-16-2012 12:22 AM #4
    Quote Originally Posted by SirSpectre View Post
    I'm running the MS3X full seq. I am running the blend ITB setting. Today I went back and re did the tb settings and got it to idle a little lower.(1350rpms from 2700rpms). I am running it a little more richer to help it from getting soo hot so quickly.
    Thanks for the reply.
    Quote Originally Posted by Hurt View Post
    Yes the cam is a TT276* sorry had to remember. The software is definitely the next move.
    Thanks for your reply as well.
  5. Member Hurt's Avatar
    May 3rd, 2011
    Boston, MA
    08-16-2012 07:42 PM #5
    Quote Originally Posted by simon-says View Post
    If this car isn't driven daily, go with a 288* or even a 298*. You won't regret it!
    No problem, I'm always willing to put my $0.02 in!
  6. 08-18-2012 03:18 AM #6
    lower it!!!!!
  7. Member simon-says's Avatar
    Oct 20th, 2007
    Portland,Oregon
    08-20-2012 11:05 PM #7
    Okay so,
    I have done about 3hrs. of research and a friend has also helped out. And we came up with this.
    DOW CORNING MOLYKOTE 321.
    This is used by FORD and Mitsubishi on their throttle bodies. They say to never clean them! If you do clean them, then you need to reapply this stuff to the butterfly/bore. Let it dry and crack open the butterfly, adjust your idle stop screw. Enjoy your low idle setting.
    I will install the manifold in the morning along with the new phenolic spacer. (helps keep the fuel rail cool) I bet with the stop screw out all the way, it wont start. Screw in the stop screw until it idles.
    :beer
  8. 08-20-2012 11:35 PM #8
    did you lower it, cause you should
    Oct 4th, 2002
    Belgium, Europe
    09-13-2012 02:13 PM #9
    mine leaked everywhere.. everywhere..
    removed the butterflies and welded everyhole shut, using 1 big TB
    Secretary / co-founder - Corrado Club Belgium
    http://www.corrado-database.nl/index...corrado&id=855
