Results 1 to 4 of 4
Thread: ash counter
  1. 08-15-2012 08:10 AM #1
    i have a 09 golf with the dpf removed but i need to reset the ash counter, but i need the block number, can anyone help please.
  2. Member Theresias's Avatar
    Feb 11th, 2004
    Magdeburg, Germany
    '10 Skoda Octavia vRS Combi / '67 Ford Mustang Conv.
    08-15-2012 03:12 PM #2
    If the DPF was truly/properly removed you wouldn't need that... Though, DPF removal is very likely illegal no matter where you are so please don't expect any help from us.
  3. 08-17-2012 04:40 AM #3
    The ash counter reset needed also to replace a new DPF.
    You can do a force regeneration, to reset it, but there is a direct command to ECU to reset the ash counter to avoid regenerating the new DPF.
    I use VAG COM VCDS.
    If any one can help, I need to know how to do it on a CR engine.
    Thanks
  4. 08-17-2012 01:22 PM #4
    Counter for particulate filter pile up, to commence with Regen when reached to self clean.
    Jack Shapiro E.P.E. VAS>ASE Extern VST-3/1 LAB (TECH INQUIRIES ARE TO BE IN WRITING )
    7076062 NYS DMV SAE>NASTF>VW-Audi GEKO Authorized
    European Parts Emporium/Performance --- Immobilizer Solutions LLC --------
    Postadresse: 1001 State Route 17K Montgomery New York 12549 USA
    vwemporium@aol.com -845-457-9808 TEL 9AM-5PM --------TAKE CONTROL OF WHAT YOU OWN!!!!!!
