Results 1 to 16 of 16
Thread: Coolant leak middle of engine this time
  1. 08-15-2012 05:20 PM #1
    Okay so I changed my water pump bc of a leak and everything was fine for a couple days. My gf was getting her hair done when she noticed coolant leaking again. This time it looks to be coming from almost right in the middle of the engine on the front. Is this the crack pipe? I had her pour water in while i was underneath and thats what I saw. I will try to get a pic up tomorrow.
    Also I did get g12 and am running that now. I flushed out the coolant from radiator, does it need to be flushed out of anywhere else? Like heater core?
    And one last question.. on the DIY for the crack pipe, he replaces the thermostat, thermo cover, thermo housing, ecu temp sensor, ac switch, and 2 sensor o ring. Is all this necessary? I planned on replacing the thrmostat and housing seal but why everything else?? He never really says
    Thanks guys
    Crack pipe right?
  2. Semi-n00b
    Apr 21st, 2009
    Pittsburgh
    '01 Jetta GLX
    08-15-2012 05:44 PM #2
    yup, crack pipe. If you have not changed the sensor, I definately would. It's a cheap part that is a pain to get at. You can get the complete thermostat housing kit that has the o rings and new plugs and everything from GAP for less than 150, depending if you get the plastic pipe, or the metal. I just did this about a month ago. I replaced everything, and went with the metal pipe because it is a pain to do and I did not want to do it again. The housings are known to fail, that is why there is the kit. Easier to do it all at once.
  3. Semi-n00b
    Apr 21st, 2009
    Pittsburgh
    '01 Jetta GLX
    08-15-2012 05:45 PM #3
    yup, crack pipe. If you have not changed the sensor, I definately would. It's a cheap part that can be a pain to get at. You can get the complete thermostat housing kit that has the o rings and new plugs and everything from GAP for less than 150, depending if you get the plastic pipe, or the metal. I just did this about a month ago. I replaced everything, and went with the metal pipe because it is a pain to do and I did not want to do it again. The housings are known to fail, that is why there is the kit. Easier to do it all at once.
  4. Member
    Jul 13th, 2001
    Oakland, CA
    08-15-2012 06:23 PM #4
    Quote Originally Posted by cornfused View Post
    If you started with G11, you should've flushed all of the coolant in the entire system, perhaps running straight distilled water for a bit to ensure that no G11 was left in the system.
    Kenji
  5. Member masterqaz's Avatar
    Oct 4th, 2007
    Oakville Ont
    94 JTI Vrt 60-1 .58ar exh obd2 440 racefile 20psi/meth
    08-15-2012 07:41 PM #5
    Seems very common the last couple weeks
    Forced convection.... Now we grillin.
    Some times she goes, some times she doesn't.... Way of the road
    Rem 870 super mag in max 4 camo for sale. Pm me
  6. 08-15-2012 08:51 PM #6
    Quote Originally Posted by Kenji View Post
    I had prestone in it :/
  7. 08-16-2012 05:43 PM #7
    So which thermostat should I get 70c or 80c and who is GAP?? Gruven? They dont have any kit
  8. Member kevinivek's Avatar
    Oct 18th, 2007
    Monterey, CA
    1992 GTI VR6
    08-16-2012 05:56 PM #8
    Gap=German auto Parts
    Gruven is another online shop.
    I bought my kit from MJMtuning.com
    4-8-15-16-23-42
  9. 08-16-2012 06:06 PM #9
    Well I ordered the kit from MJM with the 80c thermostat
    how do I flush coolant from the heater core?
  10. Member izzo's Avatar
    Mar 19th, 2004
    Manassas
    '89 Golf
    08-16-2012 08:08 PM #10
    Good luck with MJM.
    TO flush the heater core remove both hoses from the flanges, but be VERY careful not to break the plastic.
    Age and heat takes its toll on them and they become very brittle.
    Put a garden hose on one of them and let the water run through for a while.
    Quote Originally Posted by Laser04
    WU-Tang Clan ain't nothing to f*** with
    Quote Originally Posted by jnm2.0t View Post
    Most of the VW tools hang out in the MKIV forum
  11. 08-17-2012 02:45 PM #11
    Quote Originally Posted by izzo View Post
    Good luck with MJM.
    Thanks man, and why do you say good luck with mjm? Bad experience?
  12. Member GTIVRon's Avatar
    Jul 24th, 2009
    Keller, Texas
    92 Corrado SLC, '12 Golf R
    08-17-2012 03:08 PM #12
    Check your card statement. U bet the money is already gone. Send them an email and see how long it takes to get it. If you ordered it today I'm guessing it might ship by the 31st.
    Sent from my SAMSUNG-SGH-I747 using Xparent Red Tapatalk 2
    2002.5 Jetta 1.8T - TOTALED (dodging deer)
    2002.5 24v GTI - TOTALED (rear-ended by a Jeep)
    1992 Corrado SLC - The toy & DD
    2012 Golf R - The weekender
  13. Member kevinivek's Avatar
    Oct 18th, 2007
    Monterey, CA
    1992 GTI VR6
    08-17-2012 04:31 PM #13
    Quote Originally Posted by GTIVRon View Post
    I've always had quick shipping from MJM.
    4-8-15-16-23-42
  14. Member GTIVRon's Avatar
    Jul 24th, 2009
    Keller, Texas
    08-17-2012 10:33 PM #14
    Quote Originally Posted by kevinivek View Post
    Took them a full week just to tell TT to ship the cams I ordered from them that they said were in stock. Then they gave me a piss poor attitude when I told them to cancel the order because I needed my car back and wasn't going to wait another 2 weeks.
    That was about a year ago. About a month ago I contacted them regarding suspension for my Corrado. Twice. Even called after a full week of not hearing anything. They said they still hadn't gotten through all their e-mails, asked for my name and e-mail address and said they'd get back to me within one business day. I'm STILL waiting for a reply. Meanwhile.. I ordered from elsewhere and installed my suspension already.
    MJM sucks ass.
  15. Member izzo's Avatar
    Mar 19th, 2004
    Manassas
    '89 Golf
    08-19-2012 09:11 PM #15
    The bigger percentage of users here have had bad experience with them.
    Just search "MJM", and not only in the 12v forum; you will find plenty of food for thought -
    that is if the mods haven't deleted the threads (mind you, MJM are an advertiser here).
  16. 09-04-2012 12:31 PM #16
    MJM did okay, I paid for the express shipping and it wasnt express but at least it got here
