Results 1 to 8 of 8
Thread: head bolt torque issues - is this normal?
  1. Junior Member
    Feb 18th, 2010
    New Brunswick
    '84 Westfalia, '90 Cabriolet
    08-15-2012 05:47 PM #1
    I think I should have posted this in this forum instead of the cabriolet forum. I was wondering if anyone experienced the same issues of the head bolts "yielding" or "letting go" during the 90 degree additional turn after the 43 ft/ lb./ torque. They did not strip but they lost some torque as I suspect they started to stretch. Here is my question with more information in the Cabriolet forum.
    http://forums.vwvortex.com/showthrea...2#post78586352
    Thanks
    Jun 14th, 2001
    Music City USA
    79 Scirocco 82 Rabbit Truck 85 Golf D 87 GTI 97 Passat TDI 03 TT
    08-15-2012 10:42 PM #2
    yes
    Mar 31st, 2008
    PNW - Oregon
    08-16-2012 02:45 PM #3
    stretch bolts are supposed to stretch when you tighten them..
  4. Semi-n00b wholeass84's Avatar
    Nov 9th, 2009
    new jersey
    mk3 gti vr6
    08-16-2012 04:00 PM #4
    I dont know about any one else but never reuse headbolts its about 10$ for the bolt set at the dealer
  5. Junior Member
    Feb 18th, 2010
    New Brunswick
    08-16-2012 04:22 PM #5
    Sounds intuitive that they are supposed to stretch...I know, but I've never worked with them before and it just felt weird when they started to stretch. I was looking for people who had experience with them and not just opinions. Some with experience said they never felt them stretch, which got me thinking that I somehow messed up or got a bad set of bolts, or something was messed up with my case. Thanks
  6. 08-17-2012 10:45 PM #6
    It is important to understand this is a precision process.
    My limited experience with the TTY (Torque-To-Yield) headbolts is that I feel the my applied torque level out at the very end of the final turn sequence.
    The feeling you have is that the bolt is getting ready to snap, so that makes you uneasy, since it goes against your instinct. However, this is normal behavior for a stretch bolt.
    How do you make sure you will get to the bolts to this point, not before and not beyond where they begin to weaken?
    First, the headbolt holes need to be chased with a thread restorer. That is ideal. It you don't have a thread restorer, then you can use a bottoming tap. If you don't have a bottoming tap, then take a regular tap and cut off the tapered end with a silicon carbide cutting wheel on a dremel tool.
    Clean the debris from the holes with compressed air.
    If you do not chase the bolt holes, friction will cause the bolts to be under-torqued, and since the stretch part is at the very end of the sequence (I want to say about the last 10 degrees), you may not even get to the stretch phase.
    Normally, the headbolts are lightly pre-oiled. Do NOT use anything else on the bolts or holes. The sequence is calibrated for the lubricant on the bolts. If the bolts are bone dry, use a light-grade machine oil, certainly no anti-seize.
    Your torque wrench must be checked for calibration. You might be able to find a tool dealer or shop that has a tester. Learn how to use your torque wrench properly and don't loan it to anyone. Back off the setting collar to the lower end of the scale before putting it into storage.
    Use a long-handled breaker bar for the final degree turns. You need that leverage to help with the control and to keep your rotator cuff from being pulled. 2 feet would be a good length.
    The advantage of the TTY bolt is even clamping pressure which cannot be obtained with non-stretch bolts.
    The only bolt better than a TTY is a stud. It is stronger, has even clamping pressure, and is reuseable. TTY bolts are one-use only. The disadvantage is the extra cost over TTY bolts.
    Aug 14th, 2005
    Germany
    08-18-2012 01:14 PM #7
    Quote Originally Posted by 84Westfalia View Post
    . . . bolts "yielding" or "letting go" during the 90 degree additional turn after the 43 ft/ lb./ torque. They did not strip but they lost some torque as I suspect they started to stretch.
    Not going to cover ground already passed over, I hope, but without knowing exactly what you felt I would use a new bolt. Yes they are supposed to stretch but one siganl that a bolt is stretched too far is a bad feeling you get when trying to turn it more than already turned. Most builders will tell you that if it seems to require more turning then the other bolts or it just seems to not be torquing anymore, you are at risk of breaking the bolt. The next step for a bolt after the elastic phase is snap.
    Although it is not stated in any repair manual that I can remember, except for the diesel engine which uses a larger bolt and the same torque data, they should not be reused. Maybe one time is OK if they feel right when using it, but even one time I think is pushing your luck.
  8. Member Mtl-Marc's Avatar
    Sep 13th, 2006
    Montreal, QC
    Sciroccos
    08-30-2012 10:59 AM #8
    Quote Originally Posted by wholeass84 View Post
    This, or get ARP studs which can be reused.
    Sent using smoke signals.
