Results 1 to 3 of 3
Thread: brake job mystery!
  1. Junior Member
    Jun 14th, 2011
    Andover MA
    '97 passat tdi & '98 1.8TQS
    08-15-2012 10:16 PM #1
    hey all, I cant believe I'm here asking for help after ****ing up a simple brake job. Alright so heres the low down, I just threw new calipers & carriers, pads and rotors on my 98 a4(quattro).
    She's developed a metal on metal knocking on the front passenger side that sounds as if the rotor is flopping around. It increases in frequency and volume as I accelerate and goes away when I get on the brakes. also happens more frequently when I turn to the right.
    ...and don't say its a bearing or arm. I jacked her up and checked for wheel wobble, play in the control arms and yes I installed it on the correct side
    I appreciate any help guys this ****'s got me stumped
    97 Passat tdi
  2. Member THP8VGTI's Avatar
    Dec 29th, 2002
    southern nh
    91 mk2 gti 16v, 94 Jetta VR
    08-16-2012 09:05 PM #2
    Just asking but did you lubricate all points that need to be. I have seen new calipers with no grease on slide pins before. Any missing hardware that went unnoticed? If reman calipers it is possible that brackets could be worn where pads sit
    Aug 10th, 2001
    Long Beach, CA
    07 CW GTI
    08-16-2012 11:08 PM #3
    Check the clips that hold the pads in place. If the pads are a sloppy fit and the clips won't hold them, you'll get some knocking.
    John
    I'd stop drinking beer, but I'm no quitter.
