Results 1 to 8 of 8
Thread: FWD > 4Motion?
  1. Member niterider03's Avatar
    Apr 19th, 2004
    Germany/WA
    78 Rabbit 2.0
    08-16-2012 12:30 AM #1
    I searched and found nothing, can you swap 4motion from a B5 wagon into a fwd B5 wagon? Assuming you have a donor car...... time not an issue, money comes in time.
  2. Member Harold's Avatar
    Jul 31st, 2000
    New Hampshire
    2004 VW Passat 4Motion
    08-16-2012 01:28 AM #2
    Least amout of time and money= go buy the car with 4Motion. Easier to swap everything else over to the 4Motion.
    2004 Passat 4Mo, 1.8T, stick
    past: '96 Audi S6, forced to sell, F. U. nh emissions
    '87 VW Quantum syncro wagon, got me into quattro
    '85 VW GTI , 17 yrs and 280k miles, rusted away
  3. Member scotts13's Avatar
    Feb 15th, 2007
    Lehigh County, Pa.
    2004 GLS 1.8T
    08-16-2012 07:59 AM #3
    Quote Originally Posted by niterider03 View Post
    Short answer, NO.
    Long answer, anything is possible with enough time and money, but in this case you'd have to be a masochist. It's not just swapping components; you actually have to cut and re-weld the lower rear section of the unibody from the donor car to the recipient. It's been done (once, that I know of) but in the end you spend a lot of money and hundreds of hours to create something you could pick up at any used car lot.
    Better to spend your time on something new, like an amphibious Passat or a flying one.
  4. 08-16-2012 10:38 AM #4
    I have a fwd passat v6 stick and i always wanted a 4 motion but you cant ever find one and if you do its in really bad shape. I had a dream of making that one day too, but the process seems so long. Its probably really is easier to just get a 4 motion passat and just make everything nice inside out.
  5. Member sdavis872's Avatar
    Aug 20th, 2009
    Omaha, NE
    2003 VW Passat W8 6 speed
    08-16-2012 12:03 PM #5
    Just go buy one. If you really want one, it'll take some searching for. I bought my black on black w8 4motion 6 speed from a lady 8 hours away. There's less than 60 of those in North America, if I can just to happen to come across that, you should be able to find any other 4motion.
    \\_\__\___http://lowdownlabs.com/ ___/__/_//
    Passat W8 Sport 6 speed manual
    ST Coilovers | Miro 111 19x9.5 | Achilles ATR Sport 235 35 19 | COAM
    SpeedTuning USA Stage 2 | B6 S4 calipers | S5 rotors | Stop Tech Pads
  6. Member niterider03's Avatar
    Apr 19th, 2004
    Germany/WA
    78 Rabbit 2.0
    08-16-2012 12:34 PM #6
    I have a 1.8t not a v6fwd, i want a 1.8t 4motion but guess thats looking dim.
  7. Member ArcticFox's Avatar
    Nov 4th, 2005
    Rockaway, NJ
    08-16-2012 12:42 PM #7
    I have one and its big turbo
  8. Member scotts13's Avatar
    Feb 15th, 2007
    Lehigh County, Pa.
    2004 GLS 1.8T
    08-16-2012 02:13 PM #8
    There are a few out there. My local dealer had two, one a wagon, a couple of summers ago. If that's the config you want, and can't find one, it's much, MUCH easier to swap in the engine you want than the drivetrain.
