Results 1 to 24 of 24
Thread: *EVERYONE NEEDS To Look At This Thread!*
    Oct 25th, 2011
    Fairfield County, CT
    2011 Jetta S
    08-16-2012 07:08 AM #1
    HERE is some basic information that everyone will ask for at least once on this forum and to prevent countless threads containing the same information, I have compiled it just for you right here!!
    **Please**
    Refrain (that means To hold oneself back or resist from doing, for you poo poo heads) from turning this into another one of these threads that gets locked because it's a hate filled bash-fest. Also if you are compelled to use any of the information found here please feel free but give credit where it is needed. Thank you.
    *Users who sign into their Google account will be able to comment directly on the posted content*
    If there is anything that you think should be added please drop me a line.
  2. Member monster20v's Avatar
    Mar 19th, 2005
    NYC
    '12 Jetta SE, '09 Acura MDX
    08-16-2012 07:21 AM #2
    Yes sticky this
  3. Member itskohler's Avatar
    Jan 7th, 2011
    Jacksonville, FL/Dallas, TX
    2012 Jetta, 2008 Jetta RIP
    08-16-2012 07:24 AM #3
    This needs to go in the FAQ.
  4. Member JettaVR6mk's Avatar
    Dec 28th, 2000
    Outside Philly
    2012 Jetta GLI Autobahn, 2005 Mazda 6s, 2000 Jetta GLX VR6
    08-16-2012 07:39 AM #4
    Great info, I suggest changing the title of the thread.
    2012 Platinum Grey Jetta GLI Autobahn with Nav
    2005 Blue Mazda Mazda6 s
    2000 Atlantic Blue Jetta VR6
    Oct 25th, 2011
    2011 Jetta S
    08-16-2012 07:43 AM #5
    Quote Originally Posted by JettaVR6mk View Post
    To what?
  6. Member itskohler's Avatar
    Jan 7th, 2011
    08-16-2012 07:48 AM #6
    Something that has to do with the thread content. All caps halfway through is a little over bearing.
    Oct 25th, 2011
    2011 Jetta S
    08-16-2012 07:52 AM #7
    Quote Originally Posted by itskohler View Post
    I remember now, You cant change the thread title.
  8. Member itskohler's Avatar
    Jan 7th, 2011
    08-16-2012 07:54 AM #8
    I saw the title of the post box change, oh well. Mods might be able to do it.
    Feb 3rd, 2011
    Chesapeake, VA
    '12 GLI Platinum Gray
    08-16-2012 08:10 AM #9
    The link to the fuse info DOES NOT apply to the GLI.
    '12 Jetta GLI Platinum Gray
  10. Member pattrick02's Avatar
    Jun 9th, 2009
    South Florida
    MK6 GLI | MK4 GLI | 4.4TT X5
    08-16-2012 08:15 AM #10
    this should be stickied, and add some info for GLI's..good stuff..THIS IS WHAT THIS FORUM NEEDS...people like this..
  11. Member
    Oct 25th, 2011
    2011 Jetta S
    08-16-2012 08:24 AM #11
    Quote Originally Posted by adamkramerusn View Post
    yes it does. If you are looking for GLI information, look under MY 2012 and please note the designation AW1 vs AW0. AW1 is highline aka GLI AW0 is everything else.
    Feb 3rd, 2011
    Chesapeake, VA
    08-16-2012 09:00 AM #12
    close but not the same.
  13. Member
    Oct 25th, 2011
    2011 Jetta S
    08-16-2012 09:05 AM #13
    Whats not the same it's an exact match. You Sir, are confused.
  14. Member
    Feb 3rd, 2011
    Chesapeake, VA
    08-16-2012 09:17 AM #14
    Quote Originally Posted by Verebs1 View Post
    yes, the fuse panels are the same but fuse values are not. Example: Fuse 22 should be either 20 or 7.5A according to your PDF, mine is 15A.
    Also, according to your roadmap, there are no fuses in ANY of the locations designated for lighting (headlights, DRLs, foglights, etc)
  15. Member
    Oct 25th, 2011
    2011 Jetta S
    08-16-2012 09:25 AM #15
    The only fuse that doesnt match 100% is 22 which could be because of a running change or because your vehicle is configured slightly differently its only 5A no big deal.
    The reason the lights arent on yours is because the GLI controld the lights through the CCM which you would know if you knew anything about your car. Please dont argue with me. Thanks.
  16. Member
    Feb 3rd, 2011
    Chesapeake, VA
    08-16-2012 09:36 AM #16
    Ok... deep breath At no point in this thread have I been condescending towards you. This is a forum, where people come to find/share information and LEARN. I was stating that your diagram did not match what I have in my car and noted a discrepancy.
    as I've only owned this car since May, will please explain to me what the CCM is exactly. I am VERY familiar with cars, but this is my first VW.
  17. Member jettsy's Avatar
    Mar 28th, 2011
    Orlando, FL
    2011 Jetta
    08-16-2012 09:43 AM #17
    Great work bud
    SteveMKVI JettaMy Car Activate Full MFD MK6 Jetta DIY
  18. Moderator Flyin18T's Avatar
    Jan 10th, 2001
    Long Island
    08-16-2012 09:48 AM #18
    Sticky-fied!
    Sent from my HTC_Amaze_4G using Tapatalk 2
    2012 MKVI Jetta GLI / 2008 Civic Si Sedan / 2007 Mazdaspeed 6 / 2004 MKIV Jetta GLI (1.8T) / 1996 MKIII Jetta GLX VR6
    https://twitter.com/Flyin18T
  19. Member
    Oct 25th, 2011
    2011 Jetta S
    08-16-2012 09:53 AM #19
    Sure no problem. The CCM is the module under the dash on the drivers side behind the fuse box. It controls the electrical and comfort features in the car. In the GLI the CCM is a highline module which in basic terms is like a digital clock where as the lowline CCM can be seen as a non-digital clock. The digital clock has the functions all controlled by the computer chip where as the analog clock used other separate "modules" or gears and stuff to do the same function. In terms of the CCM this means that the number of fuses and relays needed is less for the highline than the lowline. In this sense the Non-GLI is able to do many of the "highline" functions that the GLI can do, there is just more things than need to be done for them to work. Example: Rain Light Sensor, Traction Control, Puddle Lights, and more.
    Sometimes in these cars the fuse rating is less than that specified in the documented material because of a running change where they realized it did not need to be so high or that it needed to be bigger. Example the MY11 cars needed to have the fuse for the horn separated from the ECU because it was found that it was possible to blow and cause the car to become unstable while driving. Another possibility is that the fuse can accept many modules under it but maybe your car only has a few of them. In this case the fuse value may be less because it doesnt need to be that high for only half of what it was intended for.
    Only trying to pass along the correct answers and not confuse new users or others who are easily confused, thats all. No hard feelings.
  20. Member
    Oct 25th, 2011
    2011 Jetta S
    08-16-2012 10:22 AM #20
    Quote Originally Posted by jettsy View Post
    Great work bud
    Quote Originally Posted by Flyin18T View Post
    Sticky-fied!
    Thank You All.
    If anyone needs specific information about their car please PM me and let me know. There is a lot of information available on my site for FREE (link in my signature).
  21. Member pattrick02's Avatar
    Jun 9th, 2009
    South Florida
    08-20-2012 09:47 AM #21
    Steven, you are a genius. Keep up the awesome work.
  22. Member
    Oct 25th, 2011
    2011 Jetta S
    08-27-2012 01:05 PM #22
    I will be adding some more information in the coming week or so if anyone has anything they need specifically please let me know.
  23. Semi-n00b
    Sep 7th, 2011
    Angola, Indiana
    2001 VW Jetta TDI
    10-25-2012 08:01 PM #23
    thanks, this helped a lot considering none of the fuses are marked or in the owners manual!
  24. Member
    Feb 2nd, 2005
    BC/Philippines
    84' Dellorto'd GTi, 87' Rocc 16v, 82' Track Rabbit, 11' Jet Tdi
    10-26-2012 10:31 AM #24
    Thanks!! I've been searching for a fuse panel layout for a while, this is great. Boggles my mind VW didn't include one with the owners manual
