Saturday,18,August,2012,18:36:28:63269
VCDS Version: Release 11.11.4 (x64)
Data version: 20120807
Chassis Type: 1J - VW Golf/Bora IV
Scan: 01 02 03 08 15 16 17 19 22 29 35 36 37 39 46 47 55 56 57 75
76
VIN: 9BWDE61J834060849 Mileage: 219790km/136571miles
Address 01: Engine Labels: 06A-906-032-AWP.lbl
Part No: 06A 906 032 LP
Component: 1.8L R4/5VT G 0005
Coding: 07500
Shop #: WSC 00001
VCID: 77F3EBF7553A61A010F
9BWDE61J834060849 VWZ7Z0C6909824
1 Fault Found:
16396 - Bank 1: Camshaft A (Intake)
P0012 - 35-10 - Advance Setpoint not Reached (Over-Retarded) - Intermittent
Readiness: 0000 0000
Address 03: ABS Brakes Labels: 1C0-907-37x-ASR.lbl
Part No: 1C0 907 379 K
Component: ASR FRONT MK60 0103
Coding: 0018945
Shop #: WSC 00001 785 00200
VCID: 32651AE3AED84488E71
No Faults Found
or DTCs not supported by controller
or a communication error occurred
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 1C0 909 605 F
Component: 08 AIRBAG VW61 0202 0001
Coding: 12344
Shop #: WSC 00001
VCID: 2753FBB7C51A312040F
3 Faults Found:
00532 - Supply Voltage B+
07-10 - Signal too Low - Intermittent
01299 - Diagnostic Interface for Data Bus (J533)
49-10 - No Communications - Intermittent
01217 - Side Airbag Igniter; Driver Side (N199)
32-10 - Resistance too High - Intermittent
Address 17: Instruments Labels: 1J0-920-xx5-17.lbl
Part No: 1J0 920 906 J
Component: KOMBI+WEGFAHRSP VDO V07
Coding: 07232
Shop #: WSC 00001
VCID: 2F631397EDEA696088F
4 Faults Found:
01336 - Data Bus for Comfort System
80-10 - Single-Wire Operation - Intermittent
01330 - Central Control Module for Central Convenience (J393)
01304 - Radio
49-00 - No Communications
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 00001
VCID: F0E150EBB054B698515
5 Faults Found:
01304 - Radio
01331 - Door Control Module; Driver Side (J386)
Address 46: Central Conv. Labels: 1C0-959-799.lbl
Part No: 1C0 959 799 C
Component: 8B Komfortgerát HLO 0003
Coding: 00064
Shop #: WSC 00001
VCID: 37732BF715BAA1A0D0F
Subsystem 1 - Part No: 1C1959801A
Component: 8B Tõrsteuer.FS KLO 0009
Subsystem 2 - Part No: 1C1959802A
Component: 8B Tõrsteuer.BF KLO 0009
17 Faults Found:
53-10 - Supply Voltage Too Low - Intermittent
01131 - Control Circuit for Turn Signals
25-10 - Unknown Switch Condition - Intermittent
01332 - Door Control Module; Passenger Side (J387)
00928 - Locking Module for Central Locking; Front Driver Side (F220)
54-10 - Incorrectly Equipped - Intermittent
00929 - Locking Module for Central Locking; Front Passenger Side (F221)
01134 - Alarm Horn (H12)
37-00 - Faulty
00932 - Electric Window Motor; Drivers Side (V147)
62-00 - No or Incorrect Adjustment
01031 - Central Locking Key Switch; Driver Side; Unlock
29-10 - Short to Ground - Intermittent
01030 - Central Locking Key Switch; Driver Side; Lock
27-00 - Implausible Signal
00913 - Window Regulator Switch; Front Right Driver (E81)
End ---------------------------------------------------------------------
