Results 1 to 2 of 2
Thread: MKIV Seats in the MKI Cabby
  1. Junior Member
    Jun 23rd, 2012
    Ohio
    1984 VW Rabbit Convertible
    08-16-2012 10:16 PM #1
    I know that Cabby Info says that MKIV seats "can" fit in our MKI Cabbys with "modification" but what exactly does that mean?
    I am looking an an 06 Jetta interior (especially front seats) and I'd like to update my Cabby. Is this possible? What modifications need to be made?
    Also, do Sparco seats fit? Is there matching fabric for the rear seats?
    Thanks!
  2. Member Kevin Rowley's Avatar
    Sep 6th, 1999
    Georgia
    1987 Cabriolet
    08-17-2012 08:54 AM #2
    First of all, an '06 Jetta is a MkV, not a MkIV. The two styles are significantly different.
    The problem with fitting any VW seats other than those from a MkI or MkII is that the legs for the seats on later cars are a different width than the rails fitted to the earlier cars. Some people have had success heating them and bending them into place. Others have transplanted everything except the base from the new seats to the old seat bases. It takes a certain amount of creativity to make it work.
    Keep in mind that from the factory, Jetta seats do not fold forward. Access to your back seat will be very limited if you choose to use those seats unless you figure out a way to make them fold.
    Sparco seats will fit in a Cabriolet if you use the VW specific seat mounting brackets. I don't know if matching fabric is available, but my guess would be yes.
    2004 Volvo C70 LPT
    2002 Volvo V70 XC
    1987 Cabriolet Bestseller
