Results 1 to 7 of 7
Thread: Tsb
    Jul 2nd, 2009
    Sparks Nevada
    88 16v GTI
    08-16-2012 10:34 PM #1
    2009 gti needs a software update for a Tsb. The t.p.m.s. light is on I would like to turn off system or just the light. I have a vagcom! How do I do these things?
  2. 08-17-2012 09:49 AM #2
    You start by reading the sticky "Please Read This Before Posting..." and you follow its directions.
  3. 08-17-2012 01:31 PM #3
    Respectfully even with a scan.
    We don't assist here with such a type of request for TPMS sensor removal, because this is illegal.
    Jack Shapiro E.P.E. VAS>ASE Extern VST-3/1 LAB (TECH INQUIRIES ARE TO BE IN WRITING )
    7076062 NYS DMV SAE>NASTF>VW-Audi GEKO Authorized
    European Parts Emporium/Performance --- Immobilizer Solutions LLC --------
    Postadresse: 1001 State Route 17K Montgomery New York 12549 USA
    vwemporium@aol.com -845-457-9808 TEL 9AM-5PM --------TAKE CONTROL OF WHAT YOU OWN!!!!!!
  4. 08-19-2012 10:57 AM #4
    Quote Originally Posted by Jack@European Parts View Post
    It is only manditory on 2012+ models and those who have done wheel swaps or run winter tires on separate wheels and tires (in wheel sensors) have done this regularly. I know MKV Jetta/Golfs used in wheel sensors instesd of ABS TPMS.
    Mar 6th, 2002
    Morris Plains/Parsippany, NJ
    1998 GTI 2.0
    08-19-2012 10:57 PM #5
    Technically some form of TPMS is required on all cars <8700gvw manufactured as of September 2007 for the US market. But unlike emission laws, the legalities after it leaves the dealer lot are a bit fuzzy.
    AFAIK, It is illegal for a shop to disable the system, but it is perfectly legal for a shop to install aftermarket wheels, remove sensors, etc, as long as they leave the light blazing on the dash. It is also not illegal for a backyard DIY-er to disable the system on their own vehicle.
    I thought VW went back to indirect (wheel-speed sensor) TPMS last year? If so, any matching set of tires should not illuminate the warning provided equal pressure. Uneven tires (for example one new tire and 3 worn tires) might turn the light on though.
    I also recall a method for recoding older models from direct (in-tire sensor) TPMS to indirect TPMS, which would be perfectly legal. We would need a scan to offer any help to the OP though.
    1998 GTI 2.0
    1993 Jeep ZJ 4.0
    World Automotive
  6. Member NedRager's Avatar
    May 15th, 2005
    USAF Germany
    '06 A4 2.0TQ 6M Avant '86 Scirocco '83 Golf CL
    08-21-2012 03:02 PM #6
    The system can be turned completely off. Your car, your choice, your resonsibility.
    PM sent.
  7. 08-21-2012 10:30 PM #7
    I stand corrected. The EU was 2012 for TPMS and the U.S. was 2007.
