I'm in for this as well, there are a few tunes that differ from the AWW to AWP, then hardware wise they're identical.
But i think the only one that can answer this question is uni them selves.
#1
what needs to be changed to get the 230hp out of a stage2 2001 jetta AWW 1.8t. the unitronic website says stage 2 is only 206hp but the 2002 jetta is 230hp they bolth have K03s turbos and the same wastegate?
I'm Phat cause I'm force fed.
#2
#3
Honestly i have always thought the AWW comes with the k03 while the AWP comes with k03s. PLUS THE VVT. but i dont think tuners such as apr, unitronic, eurodyne, revo or giac play with that stuff with tune for stock turbo.
-God created turbo lag to give the v8's a brief moment of hope-
#workingclass
#4
Is the AWW wideband?
My Build
FS: New in box, primer'd 20AE body kit (front+rear valences and side skirts) -- PM me for details
FS: Fiberglass 20AE replica spoiler. No scratches. Reflex Silver.
#5
yesthey prob get mixed up because non wolfsburg 2001's have the k03. wolfsburgs got the k03s and wideband. not sure if the 2001 non-wolfy's are wideband i think they are narrowband, that's what i've seen around. i do know if you chip a aww w/ k03s you will get the power as awp. maybe a little less if you have narrow band and k03
My Thread Fk AK Coilovers, Full 3" Exhaust, Custom FMIC, Forge Evo14 BOV, Forge Unos MBC, Forge Throttle Body Hose, GodSpeed Aluminum Radiator, Prothane Dog Bone Mount, BFI STG 1 Eng/Trans Mounts, Sachs VR6 Clutch Kit, TT Short Shifter, Siemens 630s, Walbro 255, DBB Garrett 50 Trim Turbo Kit, Eurodyne 630cc MAFLESSPAGPARTS FTW -- STEVEBILT.COM -- Integrated Engineering -- FourSeasonTuning.com Don't Buy Anything From *ChunkyPeanuts*
#6
#7
#workingclass
#8
Aww has k03s.
#9
yea, the aww ko3s has no silencer on itmine did not. i need to be a little more clear on my 1st post too. AFAIK all 01 wolfy got the aww wideband setup. all aww got the k03s, most if not all without the silencer. also, AFAIK any other 2001 or lower model year 1.8t golf/jetta was narrowband with AWD engine and ko3.
#10
#11
See, Now we're all getting into the confusion...
the AWW is identical to the AWP, Hardware/compression/etc minus the small detail of the silencer on the output of the cold side of the K03S.
so whats the deal?
On a side note, my AWP tune works awesome with my AWW.
#12
#13
I was always under the impression the aww was wideband and immo 2, whereas all the other wideband cars were immo3.
Thanks for the clarification that the aww had a k03s, thought the same as the other poster with the silencer thing.
#14
#15
#workingclass
#17
#18
I have a 2001 Wolfsburg. Question - What does "Wideband" mean? I see this a lot but can't find anything explaining what it is. Thanks.
#19
#20
It's in reference to the type of front (pre cat) oxygen sensor
For gasoline, the perfect ratio of air to gas is 14.7 to 1. If you are below that number you're running 'rich'. If you're above that number you're running lean.
It's a very important measurement in a fuel injected engine as it is used in the calculation of how much fuel to spray, how much to retard timing, and how much to open the throttle body.
A 'narrowband' sensor has a narrow range of readings. It tells the computer, "I'm rich" or it tells the computer "I'm lean". If the computer wants to run at say, 13 to 1 AFR it will use that plus other measurements in order to estimate the air to fuel ratio. Often, a temperature sensor will be added to narrowband equipped engines in the exhaust manifold (pre turbo) as there is a strong correlation of exhaust gas temperature to calculating the afr for a given engine configuration. Also, narrowband sensors output generally 0-1 volts, in a digital style output ( high or low)
Narrowband sensors have been around a long time (~35 years)
Wideband sensors have only been around since the mid 90s. They output the air to fuel ratio directly. No multiple sensors. No weird calculations. They react fast and are accurate. Awesome technology, thank you Bosch! They generally output 0-5 Volts with an analog style output
My Build
#21
