Results 1 to 8 of 8
Thread: anyone know how to repair a gas tank?
  1. Member first9t!'s Avatar
    Jul 13th, 2009
    South Hill, washington
    02 GTI 85 Slammed Volva
    08-17-2012 03:37 AM #1
    I guess when I installed my bags, I didnt realize that when I aired out my exhaust flange was being pushed into my gas tank, well just got home, and smelt gas. Put the car in the air and I have a pin size hole in the tank. Sucks I just put $50 in gas in it about a half hour ago. I have tomorrow off, so if anything I can drop the tank if I have to, but is there a way to patch it from the outside?
    Quote Originally Posted by Capt. Obvious View Post
    Do you not f*ck your girlfriend because you want her to be in better condition for her next boyfriend?
    Jan 31st, 2012
    Everett, WA
    B5.5, Range Rover Classic
    08-17-2012 04:44 AM #2
    Go buy a new one. If you find someone who is crazy enough to try for gods sake take it out of the car 1st.
  3. Member Jazzydub's Avatar
    Oct 13th, 2009
    Snohomish WA
    JB 20th 0440, 1987 Audi 4kq, 1998 Yukon, 1969 Datsun 2000
    08-17-2012 09:58 AM #3
    Pretty sure my neighbor has a mk4 gti gas tank sitting in his field he'd probably sell if you need another one although I'm sure it can be patched. It's just plastic.
  4. Member jiffyjetta's Avatar
    Mar 13th, 2010
    Beaverton, Or
    Scirocco 16v, A6 Bi-turbo, 89 GLI
    08-17-2012 03:27 PM #4
    If you want a repair instead of a replacement, I would use this stuff. Ive had good luck with it in the past. http://www.acehardware.com/product/i...03&cagpspn=pla
    -ASE Certified-
    Quote Originally Posted by brobs is back View Post
    I'm going to hook up the cables for my vr shifterbox to each of my nuts. Then I'll just cough to shift
  5. Member shortwave360's Avatar
    Jul 6th, 2008
    Seattle, WA
    MKV GTi FSI 6MT, mk2 scirocco 1.8 16v, mk2 jetta 8v, mk1 cabby 8v
    08-17-2012 03:37 PM #5
    If it's really just a pin hole... try and repair first. Be sure inspect your work often though as to avoid going up in flames. GL
  6. Member first9t!'s Avatar
    Jul 13th, 2009
    08-18-2012 04:58 AM #6
    tried the repair stuff today and some other stuff I read about. Worked for about 20 minutes. then started leaking again. Buddy is parting his mk4 out, so I am buying his tank tomorrow
  7. Member SGLoki's Avatar
    Dec 12th, 2004
    The Ham
    88 fox RIP 86 jetta RIP 81 rabbit RIP, 1984 GTI RIP, 03Ranger RIP, (03 Legacy, 03 Allroad, 86 Jetta)
    08-18-2012 11:14 PM #7
    Quote Originally Posted by first9t! View Post
    For reference if anyone else is searching, most gas tanks made of plastic are h.d.p.e (high density polyethylene) and can be patched with an appropriatehdpe epoxy after they are drained.
    If hdpe is soluble in a heavy petroleum distillate such as pure acetone, you can make your own by dissolving hdpe filings in the distillate, it will bond and harden when exposed to air....I make my own abs and pvc putty this way.
    1% defined: Lone wolf, no club. Duct tape it yourself. It is broken down 1% of the time, and work is always 1% completed.
    2% defined: I'm too old to drive broken sh*t and VW people are cool. DBVW!
    Quote Originally Posted by nsindel View Post
    May I introduce Senor SGLoki -
    the man, the myth, the slamdancer...
  8. Member SenorBrandon's Avatar
    Jan 4th, 2007
    Sheridan,OR
    88 Triple white cabby,87 16v gti,91 jetta auto, 96 jetta 2.0l, 97 jetta 2.0, 99.5 jetta 2.0
    08-19-2012 02:19 AM #8
    We used a tire plug patch kit to repair a fuel tank on my new beetle. It was only a temp until the new one came in monday but held all weekend.
