Results 1 to 7 of 7
Thread: Any other way to get the Work Shop Code other than by the window stickers on the dealers lot?
  1. Member kraftaroni's Avatar
    Jan 31st, 2005
    Torrance CA
    95/MK3/VR6/Golf 82/Jetta 2 door/ 2002 a4 avant quattro 5sp, 1.8t 2.1 I.E. stroker kit,arp,gt3071r
    08-17-2012 11:11 AM #1
    Trying to Swap ECU's and have the PIN / SKC obtained from my Vag Tacho. I need the WSC but this car is a 2002 and is from the east coast. I dont know what dealer it came from. Any way to obtain the WSC from the dealer or a scan? I have a registered Ross tech for the Swap!
  2. Member Theresias's Avatar
    Feb 11th, 2004
    Magdeburg, Germany
    '10 Skoda Octavia vRS Combi / '67 Ford Mustang Conv.
    08-17-2012 12:02 PM #2
    You don't need the WSC if you got the PIN via VAGtacho.
  3. Member kraftaroni's Avatar
    Jan 31st, 2005
    Torrance CA
    08-17-2012 12:35 PM #3
    It says you do Via the Ross tech website. On step 6 of this link. Are you able to somehow bypass this step?
    http://www.ross-tech.com/vag-com/car...-swapping.html
  4. Member Theresias's Avatar
    Feb 11th, 2004
    Magdeburg, Germany
    08-17-2012 12:44 PM #4
    That page is outdated and refers to the 7-digit SKC which hasn't been available for years. The updated page can be found here...
    http://wiki.ross-tech.com/wiki/index...I_ECU_Swapping
  5. 08-17-2012 01:15 PM #5
    What's the likelihood that the VAG-Tacho in CA is a clone?
    I would suspect high.
    I'm also surprised this was assisted with, being no auto-scan was posted.
    Oh I know why.
    Wizard trickery?
    So much for continuity.
    Jack Shapiro E.P.E. VAS>ASE Extern VST-3/1 LAB (TECH INQUIRIES ARE TO BE IN WRITING )
    7076062 NYS DMV SAE>NASTF>VW-Audi GEKO Authorized
    European Parts Emporium/Performance --- Immobilizer Solutions LLC --------
    Postadresse: 1001 State Route 17K Montgomery New York 12549 USA
    vwemporium@aol.com -845-457-9808 TEL 9AM-5PM --------TAKE CONTROL OF WHAT YOU OWN!!!!!!
  6. Member kraftaroni's Avatar
    Jan 31st, 2005
    Torrance CA
    08-17-2012 01:56 PM #6
    Awesome. I don't know why I ended up jumping to the old process. Now I just need to figure out my radio code I guess. Thanks a bunch..
  7. 08-17-2012 02:04 PM #7
    That's easy.
    Since we are answering questions without scans posted today.
    Wizard holiday I guess.
    Write down your 14 digit Z# on your physical radio or get from your scan with VCDS supported 0x56 ID screen or sometimes in blocks.
    Request at your local dealer with valid ID and VIN #. Most do it for free, some charge a fee.
    Don't forget to check the service book or trunk area, maybe you get lucky with a sloppy PDI lottery ticket containing the pin.
