VWVortex.com - 09 Routan, 4.0 L, Oil Capacity
    Results 1 to 5 of 5
    Thread: 09 Routan, 4.0 L, Oil Capacity
    1. 08-17-2012 04:18 PM #1
      My wife recently purchased an 09 Routan with 25K. Its ready for its first oil change and it didn't come with an owner's manual. I can't seem to readily find the oil capacity on-line. 4.0 L engine. Thanks in advance for your help.
      Jun 23rd, 2011
      Roswell, GA
      2005 Passat GLS TDI, 2009 Routan SEL
      08-17-2012 04:36 PM #2
      I think it's 5.5 qts. And the 5+ qt. jugs don't quite get it there. You'll definitely need a 6th quart to fill it to the "full" line.
      Jun 14th, 2009
      Northport, ME
      Nocturne Black 2009 VW Routan SEL/RSE, Cinnamon 2010 Lincoln MKX AWD
      08-17-2012 04:54 PM #3
      ZAMBEE is correct. Fill it with one of the 5+ Qt jugs, run it for a few minutes to fill the filter, then shut it off and let it sit for half an hour [three days if its winter in Canada] or so to let all the oil drain into the pan, then check it again and top it off.
      I've gotten home from the dealer after an oil change, checked it the next morning and found it half a quart low - they obviously don't run it and check it again.
    4. Member VWroutanvanman's Avatar
      Feb 12th, 2011
      Florida
      2010 Routan Norge SE w/RSE
      08-17-2012 11:03 PM #4
      You can download a Dodge van owners manual for free from the Dodge website, and on page 477, it lists the fluid capacities for the 3.3L, 3.8L and the 4.0L engines. For the 4.0, 5.5 qts (5.2L) of SAE 10W-30 is the correct capacity and weight of oil. The 3.3 and the 3.8 use 5 qts of SAE 5W-20. There is also info on using synthetics in the manual.
    5. 08-19-2012 09:10 AM #5
      Thanks a bunch. I'm going to change the oil this morning (and download the Dodge manual).
