VWVortex.com - Part Out: 1996 Jetta GT Auto White | CT
    Page 1 of 2 12 LastLast
    Results 1 to 25 of 32
    Thread: Part Out: 1996 Jetta GT Auto White | CT
      Dec 1st, 2011
      Higganum Connecticut
      08-17-2012 04:07 PM #1
      UPDATED WEEKLY
      1996 White Jetta GT | 2.0 | 161,620 Miles | Running & Driving | Parts Located In Derby, CT |
      - Engine & transmission are very clean and run/shift smoothly
      - Timing belt changed on 10/6/2011 @ 156,025
      - Detailed pictures avail upon request
      - Sunroof works
      - Full part out, let me know what you need
      - Text in Red indicates parts are sold or scrapped
      Prices DO NOT include shipping or PayPal fees
      All prices are OBO
      You can contact me either by posting in here, sending me a PM, or texting me at (203) 954-9584
      SOLD:
      Headliner
      Oh Sh!t Handles
      Sunroof Switch
      Tilt Clamshell
      Cluster
      Interior Trim Set
      MAF Sensor
      Exterior Pieces
      - Seat Set $120
      - Rear bumper cover (White) - $30
      - Front bumper cover (White) - $30
      - Rear plate tub - $10
      - Upper radiator core support (for 2.0) $30
      - Front bumper rebar - $20
      - Sunroof, complete working assembly with glass - $100
      - Fenders (White) - $45 ea
      - Lower radiator core support (for 2.0) $30
      - Heated windshield washer nozzles - $20
      - Door handles - $10 ea
      - Mirrors (White) - $7 ea
      - Doors (White) - $50 ea or $175 for all
      - Trunk lid (White) $30
      - Wiper arms - $10 ea
      - Wiper motor with linkage - $30
      - Rear bumper rebar - $20
      - Door Latches - $10 ea
      - Fuel door - $5
      - Rear window glass with defrost - $30
      - Door window glass - $20 ea
      - Antenna base and cable - $30
      - Roof rain gutters - $10 ea
      Lighting
      - Headlights - $40 ea
      - Headlight harness (with no fogs) - $20
      - Headlight switch (with no fogs) $10
      Interior
      - Interior Trim Set (Beige)
      - Black faced instrument cluster with 161,620 miles - $50
      - Beige door cards / panels - $20 ea or $60 for the set
      - Turn signal stalk $15
      - Drivers knee bar cover $10
      - Tilt Clamshell - $30
      - Airbag module - $40
      - Ignition switch with lock cylinder, steering column and key $50
      - Rear speaker shelf carpet (Beige) - $20
      - Front center gear shift console- $30
      - Door speakers - $5 ea
      - Dash tweeters - $5 ea
      - Heater core $20
      - Trunk seal - $10
      - Airbag harness - $20
      - HVAC box, heater core, A/C core - $40
      - Climate control knob assembly - $20
      - Front seat guide rail covers - $5 ea
      - Beige dash shell – $20
      - Passengers airbag - $20
      - Passenger airbag cover - $20
      - Fuse block - $20
      - Brown cabin carpet - $15
      - Headliner - $5
      - Sunroof motor - $20
      - Sunroof motor cover - $5
      - Central locking door lock pump - $5
      - Switches $5 - $15 ea
      - Dash Button Blanks - $2.00
      - Dome Light/sunroof controls - $20
      - Dash Vents $10 ea
      - Center Dash Vents/Radio Surround - $15
      - AC control panel cover - $10
      - Dash Cluster Surround - $5
      - Interior door handles - $5 ea
      - Cig lighter with ash tray surround - $15
      - Wiper stalk with MFA $25
      - Grab Handle Trim x 4 - $10
      - Sun visors (grey) - $10 ea
      - Mirror triangle trim - $5 ea
      - Rear view mirror $10
      - Ash tray - $10
      - Pillar panels - $10 ea
      - Alarm modules (white, black, and silver) - $10
      - Owners manual - $10
      - Doorway kick panels - $10 ea
      - Door seals - $10 ea
      - Seat belts - $10 ea
      - Relays $10 ea
      - Trunk carpet - $20
      - VW trunk bag with jack and tools $20
      Engine / Transmisson
      - A/C hard lines - $30
      - A/C condenser - $40
      - Ignition coil (obd1) $20
      - Muffler with all exhaust piping $80
      - Exhaust manifold - $40
      - Distributor with cap - $30
      - Spark plug ignition wire set $20
      - Fuel pump with sending unit - $50
      - Windshield washer reservoir - $20
      - Cat converter - $40
      - Coolant overflow tank with lid $10
      - ECU (for 2.0 OBD1) - $50
      - Fuel rail with injectors $30
      - Engine bay harness (2.0 OBD1) - $100
      - Water pump pulley $10
      - Carbon canister with all tubing and valves - $30
      - Alternator - $30
      - Throttle body (2.0) - $40
      - Power steering pump - $30
      - Radiator - $30
      - Rad. fan shroud - $30
      - Coolant hoses - MAKE OFFER
      - Downpipe - $30
      - Oil pan (2.0) $40
      - Front motor mount $20
      - Passengers side motor mount $20
      - Manual shifter box complete with shifter mechanism $40
      - MAF (mass air flow) sensor for 2.0 - $40
      - Stock intake - $40
      - Secondary air injection pump - $30
      - 2.0 OBD1 intake manifold - $25
      - Drivers CV axle complete (for 2.0 Auto) - $40
      - Passengers CV axle complete (for 2.0 Auto) - $40
      - Throttle cable (2.0) - $10
      - Clutch cable (2.0) - $15
      - Heater fan control module - $20
      - Gas tank (for 2.0) - $40
      - Rad. Cover trim - $10
      - A/C compressor - $40
      Suspension/Steering/Brakes
      - 4 lug rear beam complete with rear disc brakes $100
      - Power steering rack $60
      - Power steering pump $30
      - Front disc brake calipers $20 each
      - Power steering lines - $30
      - Power steering reservoir $20
      - Brake booster with master cylinder, and reservoir (2.0) - $50
      - 4 lug spare donut tire - $20
      - Control arms - $30 ea or $100 for entire front suspension
      Dec 1st, 2011
      08-19-2012 12:22 PM #2
      Up
      Dec 1st, 2011
      08-25-2012 08:28 PM #3
    4. 09-16-2012 12:07 AM #4
      so, could I use the "4 lug rear beam complete with rear disc brakes $100" and that would be everything I need to convert from drum brakes?
    5. 09-17-2012 10:01 AM #5
      Got wheels?
    6. Member
      Dec 1st, 2011
      09-18-2012 08:56 AM #6
      Shes got steelies with caps on her all tires hold air ill check tread
    7. Member wetbar's Avatar
      Mar 17th, 2010
      groton,ct
      70 mulhollen look bug, '04 jetta(totalled),2000 jetta 2.0 supecharged,2005 (9m)GLI,2002 gti.
      09-23-2012 09:34 AM #7
      how much for just a the shell/rolling chassis???
      you're gayer than Lance Bass in a pink bunny suit snuggling Richard Simmons on top of a rainbow in San Franciso for drug money looking for a BJ and hanging out with Rick Moranis if you get rid of that car.
      Dec 1st, 2011
      09-29-2012 10:23 AM #8
      Quote Originally Posted by wetbar View Post
      Already have a buyer, thank you for your interest tho if it falls through ill pm you.
      Dec 1st, 2011
      10-08-2012 02:38 PM #9
    10. Member
      Dec 1st, 2011
      10-09-2012 11:16 AM #10
    11. Member
      Dec 1st, 2011
      10-10-2012 06:51 PM #11
      Up
      Dec 1st, 2011
      10-12-2012 10:20 AM #12
    13. Member
      Dec 1st, 2011
      10-15-2012 02:07 PM #13
    14. Member
      Dec 1st, 2011
      10-16-2012 05:18 PM #14
    15. Member
      Dec 1st, 2011
      10-17-2012 07:35 PM #15
    16. Member
      Dec 1st, 2011
      10-18-2012 07:14 PM #16
    17. Member
      Dec 1st, 2011
      10-19-2012 11:22 AM #17
    18. Member
      Dec 1st, 2011
      10-20-2012 09:44 AM #18
    19. Member
      Dec 1st, 2011
      10-29-2012 11:57 AM #19
    20. Member
      Dec 1st, 2011
      11-02-2012 10:25 PM #20
    21. Member
      Dec 1st, 2011
      11-03-2012 07:13 PM #21
      List updated!
    22. n00b
      Mar 30th, 2012
      Harrisburg PA
      97 Jetta Green
      11-29-2012 07:13 PM #22
      I have a 99 Jetta and need the pump inside the tank. I live in PA and would need it shipped here. Call me if you still have it 717-686-1756.
      Thanks,
      Monte
    23. Member
      Dec 1st, 2011
      12-20-2012 08:47 PM #23
      Quote Originally Posted by Kindleoff View Post
      Thanks,
      Monte
      PM'ed
    24. Member duttydubwoy's Avatar
      Aug 26th, 2003
      Long Island
      86'Golf 4 dr R.I.P,92'GTivr(Sold)97'GTiwhiteVr(R.I.P), 02.5'GTi24v(current)
      12-22-2012 02:55 AM #24
      Fenders still available?
      IG: @RySoThankful
    25. Member
      Dec 1st, 2011
      12-22-2012 10:06 AM #25
      Quote Originally Posted by duttydubwoy View Post
      just the pass side
