Results 1 to 23 of 23
Thread: Installation Advice - HPA Hockey Puck + Haldex w/switch
  1. Junior Member
    May 6th, 2011
    08-17-2012 04:31 PM #1
    So I have a bunch of parts just laying around waiting to be installed. I am paralyzed, so installing them my self just isn't feasible. I took a ride to Garnett VW (use to be an APR distributor) and got some quotes today. Turns out a service tech there (who owns a new Golf R) just came back from working with the APR racing team and had pretty good knowledge about the parts I was inquiring about.
    My .:R is only sitting at 23,xxx miles and they suggest doing the Haldex fluid maintenance since "half the fluid will be lost on installation" - is this true?. The car has had the same fluid in it for 4 years now and at this rate will be in there for another 2-3 years before I hit 40k. I don't beat on the car (often), but def enjoy sprinted driving and taking it to the twisties we have near by. Do I say f*ck it and have the service done any ways (new fluid & new unit)?
    Here are the quotes on installation:
    HPA engine mount: $165.00
    Haldex w/switch: $127.50
    Neuspeed RSB: $ 127.50
    HPA Intake: $127.50
    Haldex service: $252.15
    Onto my dilemma - $127 each for RSB and intake is ridiculous so no go on them - I just need to source a hex kit and I'm sure I can supervise the intake instillation. I paid that much for the engine mount (GB price), is it worth paying $165 for it to go in too? The Haldex plus switch seems like a steal though.
    Any input will be valued.
    Wes
  2. Member mfbmike's Avatar
    Feb 5th, 2011
    305 Miami, FL
    2008 CW R32, 1983 CW Rabbit LS
    08-17-2012 04:53 PM #2
    I lost a trivial amount of haldex fluid when I did my haldex install. Unless your a total klutz, I don't see how it would call for a full haldex service after that. At the most, you can add a few drips if you feel you've lost too much.
    120 bucks to install an intake? Wish I was local to you. lol. Sway bar install is a tad more involved I suppose (but not really) so also, they're trying to give it to you raw.
    Running the switch for the haldex can be tricky, but again, not all that difficult. Truthfully, i'm glad I had someone who had installed the haldex and the switch in their car before to give me pointers and help me run the switch.
    tldr: stealership's trying to **** you.
    If I was local, I'd do the installs for less than half the price (if that) and you'd be able to have more fun doing it.
    I'm sure someone on this forum is local to you and wouldn't mind helping another R owner out.
    Holy Milltek.
    Tarmacs cut it close.
    Miami Vase
    Cams A Make Her Dance
  3. Member Mr_Peach's Avatar
    Sep 18th, 2007
    Woodinville, WA
    2008 VW R32 :: 2000 MBZ ML55 AMG :: 2006 Mini Cooper S :: 2003 Aprilia Atlantic 500 :: Yam. Morphous
    08-17-2012 04:57 PM #3
    I've done all of those DIY except the Haldex service.
    If they're routing the Haldex switch into your interior somewhere, I'd say $127.50 is a steal. The actual "install the Haldex" part is only a minor pain, the tough part is getting the wiring unclipped. If you're a VW tech who does it every day, probably not a big deal.
    I spilled about a teaspoon of Haldex juice when I put mine in 70,000 miles ago, and I didn't bother topping it up then. I've since had two 40K services done, professionally.
    Snaking the switch cable up around the fuel tank and into the interior took me hours, but admittedly a lot of that was "research", going back and forth from under the car back to the computer.
    I thought $165 seemed steep to install the HPA puck as I started typing this, but now I remember working up a sweat taking the OEM mount out. It's a destructive process. 2 hours is a "safe" estimate. Some will do it quickly, some will invent new curses.
    Quote Originally Posted by petef View Post
    ... you have no way of knowing whether the previous owner(s) was a civilized driver or a hoon like Peach.
    Quote Originally Posted by Dave Barry
    Wouldn't "Hoon Like Peach" be an awesome band name?
  4. Member mfbmike's Avatar
    Feb 5th, 2011
    305 Miami, FL
    08-17-2012 05:01 PM #4
    Quote Originally Posted by Mr_Peach View Post
    Lowering the fuel tank ftw.
    Holy Milltek.
    Miami Vase
  5. Member Mr_Peach's Avatar
    Sep 18th, 2007
    Woodinville, WA
    08-17-2012 05:05 PM #5
    Quote Originally Posted by mfbmike View Post
    That is indeed the trick. My problem (as I recall) was visualizing where to snake from and to. I kept getting turned around in my head depending on whether I was under the car or inside the car.
  6. Member mfbmike's Avatar
    Feb 5th, 2011
    305 Miami, FL
    08-17-2012 05:11 PM #6
    lol, yes. Snaking those wires and the switch through that rubber grommet was quite tricky indeed. Once you get the wires underneath the rear bench, it's (almost) smooth sailing from there, assuming you just leave the switch under your seat.
    We ran it all the way up to the front of the car, underneath the steering column and ultimately up to the center console, right above/in front of the dsg shifter, right next to the "esp off" button.
    Holy Milltek.
    Miami Vase
  7. Member 10Ten's Avatar
    Sep 29th, 2007
    Dave's not here.
    heavy understeer and snap oversteer. PQ35 perfect.
    08-17-2012 05:53 PM #7
    i agree with both Peach & mike. have a weekend!
    function
    form
  8. Junior Member
    May 6th, 2011
    08-17-2012 07:08 PM #8
    Thanks Mike. I'd rather give my money to another R owner before the dealership any day. Any one close to Delaware on here that wants to do a solid?
    I read on here that most you guys have done every thing your selves. My buddies aren't too mechanically inclined, and idk if I trust them to start hacking things up under the car to get the mount out. I don't mind paying a little extra for the peice of mind it's being done right. I just want your guys opinion to see if it's an outrageous number.
    Thanks for the input fellas! So in regards to the Haldex service, I should just wait to accumulate more miles, even if it takes another couple years to reach that 40k milestone?
  9. Member mfbmike's Avatar
    Feb 5th, 2011
    305 Miami, FL
    08-17-2012 07:17 PM #9
    Is there any reputable VW/Audi/Porsche/etc. tuner shops in your area? They may be able to give you a much better rate as they may be more accustomed to installing "aftermarket" parts on these cars.
    I can maybe validate the haldex + switch install and hpa mount considering your circumstances, maybe. But can hardly validate the need for a haldex service thereafter and the costs to install the intake and RSB.
    Good luck.
    Holy Milltek.
    Miami Vase
  10. Member Mr_Peach's Avatar
    Sep 18th, 2007
    Woodinville, WA
    08-17-2012 08:35 PM #10
    FWIW, I was not born with a wrench in my hand. Dad would sometimes attack the lawn mower with twine and duct tape, but he took his cars to the shop.
    Out on my own, the first "interesting" car I bought (a 1968 MBZ 250 SE) got me thinking that I couldn't afford her unless I turned some wrenches on my own. After that, I went through maybe 20 years thinking my time was more valuable than doing my own oil changes.
    Fast forward to the R32, and running with the wrong crowd (VWVortex). A lot of these mods make sense to me at the price point of DIY, so I draw off the knowledge here and learn how to step my game up some. I still make mistakes, but I'm enjoying the hands on experience.
    Not that I'm suggesting you cast aside the wheelchair (or whatever) and take on the HPA puck install yourself. Just adding some color to the DIY picture.
  11. Member AWDMKV's Avatar
    Sep 16th, 2008
    Poughkeepsie NY
    MKV .:R32 #849
    08-20-2012 04:33 PM #11
    Holy Crap.. I thought I was the only person in the .:R32 Community to be a PARA and drive a .:R32. Glad someone else in my condition is enjoying this awesome car as much as I am - THIS thing gave me my legs back.. UM dual tune is a must....
    If you can post up some pictures of your hand controls - I would like to see what type of setup your running.
    Jason
    "CANDY" .:R32 # 849 / TID ULTIMATE PADDLES / EURO VCDS TUNE / RNS-510 / SKODA BT KIT / HPA "THE PUCK" / UM TUNE / EVOMS INTAKE WITH COLD AIR FEED / MILLTEK NR EXHAUST / 19" KAHN RSS WHEELS / NITTO INVO'S 235/35/19 / S6 STATUS / FULL LEDS /
    JASON - I AM IN A WHEELCHAIR and I drive like a Crazy German missing the Autobahn]
  12. Member foreverblue's Avatar
    Mar 2nd, 2011
    Palisades Park, NJ
    08 .:R32 #2048
    08-20-2012 05:51 PM #12
    And you do drive like a Crazy German missing the Autobahn. BTW got your drive shaft replace yet?
    My Build Thread
    Quote Originally Posted by PSU View Post
    I also must say that Wei is one of the biggest bosses I have ever met.
    Quote Originally Posted by AWDMKV View Post
    Wei - he is a Funny Motha..
  13. Junior Member
    May 6th, 2011
    08-21-2012 11:10 AM #13
    Jason
    Will do Jason. I just gave her to Garnet VW to do the the Haldex and mount install. So once I get her back I'll post a few pictures of my hand controls. They are made by Sure Grip I believe (push in to brake and pull down to gas).,
  14. 08-21-2012 04:12 PM #14
    Im not sure how far we are from each other. Im just on the other side of Philly (19067). I could install the intake and mount for you. I could also probably install the sway bar to just not sure of how long that takes.
    2008 DBP
    VF Intake
    Borla Cat-Back
    VMR VB3's
    FK Silverline X Coilovers
  15. Member Mr_Peach's Avatar
    Sep 18th, 2007
    Woodinville, WA
    08-21-2012 04:26 PM #15
    Quote Originally Posted by Neuman04 View Post
    Neuspeed RSB install instructions:
    http://www.neuspeed.com/media/attach...25.02.25.4.pdf
    Having the right triple square bits is important. On ramps, it's a pretty easy job. First time through, I ended up messing with jacks, as doing Neuspeed endlinks (an additional option) seemed to mean taking the wheel off, and then you need to "load" the suspension again to get the RSB to line up.
    When I took the RSB out and reverted to OEM, one shot up the ramps was all it took.
  16. 08-21-2012 04:33 PM #16
    I have the striple sqaure bits... It cant be to bad.
    2008 DBP
    VF Intake
    Borla Cat-Back
    VMR VB3's
  17. Member Kmonstermash's Avatar
    Sep 30th, 2009
    Delaware
    MKV R32
    08-22-2012 06:43 AM #17
    Im located in the 302 as well. newark. come by secure self storage sometime. I also just got my R32.
    is your R red? I believe i seen you the other night outside hibachi grill with another vw.
    @Kmonstermash - Insta/twitter
  18. Member AWDMKV's Avatar
    Sep 16th, 2008
    Poughkeepsie NY
    MKV .:R32 #849
    08-22-2012 01:04 PM #18
    Quote Originally Posted by foreverblue View Post
    Wei haha..
    I am going down Friday Morning @ 8am to get it replaced.. Thanks to Dennis & Mike @ Linden VW. Good guys, great service..
  19. Junior Member
    May 6th, 2011
    08-22-2012 05:25 PM #19
    Quote Originally Posted by Kmonstermash View Post
    I do have a red R, but I wasn't at hibachi the other day. I graduated UD in the spring and havne't been back since . I have black denvers on her.. you work at the self storage right on 273?
    -AWDMKV sorry for the delay, I'll make a new thread about my hand controls tonight
  20. Member Kmonstermash's Avatar
    Sep 30th, 2009
    Delaware
    MKV R32
    08-23-2012 12:27 AM #20
    the storage place isnt on 273 its right where 13/1 south come together. My father is the manager and we have an apartment above the office.
    I have a "garage" unit from my car to work on and keep it out of the weather.
    Im no master mechanic but I would help a fellow R owner out anytime.
    let me know if youre going to dubs on the boards.
  21. Member foreverblue's Avatar
    Mar 2nd, 2011
    Palisades Park, NJ
    08 .:R32 #2048
    08-23-2012 06:27 AM #21
    Wei haha..
    This coming Friday? i can come by and say hi before work.
    My Build Thread
  22. 08-24-2012 02:39 PM #22
    Wei haha..
    Ive also booked an appt with Dennis at Linden VW. Heard about them being very accommodating and helpful.
  23. Member foreverblue's Avatar
    Mar 2nd, 2011
    Palisades Park, NJ
    08 .:R32 #2048
    08-24-2012 03:40 PM #23
    Quote Originally Posted by mach gti View Post
    They are great.
    My Build Thread
