Results 1 to 2 of 2
Thread: need vagcom in corona, mk4 1.8t
  1. Member teknoracing's Avatar
    Mar 31st, 2004
    corona, ca
    2004 VW GTI 1.8T, 1995 VW Jetta VR6 (SOLD), 2009 VW Jetta Wolfsburg
    08-17-2012 11:30 PM #1
    My car just hiccuped on the way home, high idle (1,200rpm) at stops and it almost shut off on me but clutch/gassed it away and into my apt complex. Fluids at correct level, no leaks, belts are fine. Didnt overheat even though weather is about 100 degrees
    After parking it in my spot, i shut off and then tried to restart but to no avail. It just cranks like it wants to start but just poops out. I am scratching my head because while driving there was no CEL or EPC light.
    After waiting about 45 minutes, tried again and it started up fine. Idle was fine, -20HG vacuum, voltage was good. No CEL, No EPC, all good. Let it idle for about 20 seconds. Shut it down. Waited a few seconds, tried again, fired up again. Repeat.
    Was it just an isolated incident or is a sign of things to come?
  2. Member teknoracing's Avatar
    Mar 31st, 2004
    corona, ca
    08-25-2012 04:39 PM #2
    Cleaned and regreased EVO MS DV
    Replaced fuel pump and filter
    Leaning towards crank position sensor. It begins to act funny after 30-40 minutes of driving and it dies as am coming to idle at a stop or light.
