Originally Posted by
Mk1Racer
The only potential downside that I see to this, other than not liking who you're working with (but that could be the case w/ the original job as well), is that if the position they're actually offering you is a lower grade position than the one originally offered, and the salaries are the same, that you will be higher in the pay range for the grade of the job that you're in. This could impact future raises, as the closer to the upper end of the pay range for a given grade, the lower the percentage of your salary your raise will be. But even if the percentage is lower, the actual dollar amount may be the same (or possibly higher) than the raise you would have gotten if you were in the higher grade job.
But honestly, I don't think it's a significant issue. If it was a legit mistake on their part, take it at that. Work there for a while, and then try to move to the area / job that you originally wanted.
