Results 1 to 3 of 3
Thread: Golf mk4 bolt Pattern and off set
  1. Member VwBoy2.0L's Avatar
    Sep 30th, 2008
    Colorado Springs
    2002 Volkswagen Golf 4 dr 2.0L
    08-18-2012 12:15 PM #1
    Hello I am in the market for ESM WHEELS the model is the white 001s. The website has you choose what bolt pattern Center bore and the offset of your car is. I only know what the center bore is. With those wheels I am trying to keep the stock look. I want those rims because they look like my hubcaps, the only difference is that I cannot put a VW in the center of the wheels like my hubcaps. What would you guys prefer my off set to be 20 or 35?
  2. Member Airy32's Avatar
    Nov 14th, 2007
    NC
    MkIV R
    08-18-2012 02:13 PM #2
    35 for offset, bolt pattern is 5x100. Unless you're looking at some width much wider?? then your offset should be lower. Or if you're planning on dumping the car and stretching the tires??
    In other words, your question is simple to answer unless you are leaving out any important details.
  3. Member VwBoy2.0L's Avatar
    Sep 30th, 2008
    Colorado Springs
    08-21-2012 12:24 AM #3
    Thanks
