Results 1 to 3 of 3
Thread: WTB: misc. parts to mate mk2 1.6td engine into mk1 chasis and vice versa
    Jun 18th, 2010
    sacramento,ca
    1982 vw truck diesel, 79 rabbit 2 door diesel
    08-18-2012 02:33 PM #1
    I have an 85 jetta td car that I want to yank the turbo setup from. I have a na motors intake so I put that on. What I need is to know and buy is an exhaust manifold that will bolt up and exhaust with whatever the stock toilet bowl/gasket this car has?
    And putting these engines into mk1 shells I have never done before. I have extra pump brackets with the motor mount to swap, but wonder what do I do for the timing belt covers since the mk2 stuff won't mate up? I will need to buy 2 of those setups.
    Then I am wondering about an alternator bracket for a non ac setup in the mk1 shell. Do I use mk2 or mk1 system?
    Jun 18th, 2010
    sacramento,ca
    08-20-2012 08:56 PM #2
    bumper
  3. Member burn_your_money's Avatar
    Oct 4th, 2004
    Bright, Ontario Canada
    6.9L F250
    08-20-2012 09:42 PM #3
    You need a mk1 diesel exhaust manifold and a mk1 passenger side motor mount. Use whatever non-ac setup you have, they should both fit.
