Results 1 to 4 of 4
Thread: Cleared DTCs and Added Window via Remote Convienice Feature and Car Stopped Running
  1. Member OddJobb's Avatar
    Nov 6th, 2004
    Greenville SC
    2004.5 Jetta GLI, 1995 Golf III City
    08-18-2012 03:41 PM #1
    Ok. Here's the story. Cleared a DTC for Xenon self-leveling (headlamp was removed for fender repairs) and added the window open/close via remote in the Central Conv. module following this DIY for a friend's 2004 A4:
    http://www.a4mods.com/index.php?page...tml&category=6
    Original software coding in the Central Conv. module was 11788. Change the value to 11852.
    Tested windows via remote and it worked.
    Everything was fine for a few hours. Drove to one place, then another. Then the car started to run rough. Car eventually died and now will not refire. Below is the first auto scan (before anything was done; copied to notepad) and then the 2nd autoscan (output to log) when trying to resolve the no-run issue. We have since changed the 11852 coding back to 11788 as originally found. Car still will not run.
    Could any of the Central Conv. coding or clearing of the EVAP DTC have anything to do with the new issues?
    VCDS Version: Release 11.11.4
    Data version: 20120807
    Saturday,18,August,2012,10:36:23:60496
    Chassis Type: 8E - Audi A4 B6/B7
    Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67
    69 75 76 77
    VIN: WAULT68E84A177884
    Address 01: Engine Labels: 06C-909-559-ASN.lbl
    Part No SW: 8E0 909 559 L HW: 8E0 909 059
    Component: 3.0L V6/5V G 0020
    Coding: 0016711
    Shop #: WSC 63351 000 00000
    VCID: 3E78363A6A9BE5E8139
    1 Fault Found:
    16826 - EVAP Emission Control Sys
    P0442 - 001 - Small Leak - Intermittent
    Readiness: 0000 0000
    Address 08: Auto HVAC Labels: 8E0-820-043.lbl
    Part No: 8E0 820 043 AD
    Component: A4 Klimaautomat 1323
    Coding: 00000
    Shop #: WSC 63351
    VCID: 63CEA74EF1B9E8005C7
    No fault code found.
    Address 56: Radio Labels: 8E0-035-1xx-56.lbl
    Part No: 8E0 035 195 H
    Component: symphony II NP2 0460
    Coding: 00201
    Shop #: WSC 00003
    VCID: 2C5C0C72DCE76778ADD
    1 Fault Found:
    00466 - Control Module for Steering Column Electronics (J527)
    49-00 - No Communications
    End ---------------------------------------------------------------------
    Saturday,18,August,2012,13:18:16:60496
    69 75 76 77
    VIN: WAULT68E84A177884 Mileage: 187370km/116426miles
    Coding: 0016711
    6 Faults Found:
    16684 - Random/Multiple Cylinder Misfire Detected
    P0300 - 001 -
    16688 - Cylinder 4
    P0304 - 001 - Misfire Detected
    16689 - Cylinder 5
    P0305 - 001 - Misfire Detected
    16685 - Cylinder 1
    P0301 - 001 - Misfire Detected
    16690 - Cylinder 6
    P0306 - 001 - Misfire Detected
    16534 - Oxygen (Lambda) Sensor B2 S1
    P0150 - 008 - Malfunction in Circuit
    Readiness: 0000 1101
    Address 03: ABS Brakes Labels: 8E0-614-517.lbl
    Part No: 8E0 614 517 A
    Component: ABS/ESP allrad 3429
    Coding: 04495
    Shop #: WSC 06435
    VCID: 2648FE5AC20B5D287B9
    Coding: 00000
    Shop #: WSC 63351
    Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.lbl
    Part No: 8E0 907 279 F
    Component: int. Lastmodul USA 0517
    Coding: 01013
    Shop #: WSC 63351
    VCID: 356A29160FAD26B0C23
    Address 15: Airbags Labels: 8E0-959-655-84.lbl
    Part No: 8E0 959 655 K
    Component: Airbag 8.4EP 1001
    Coding: 0010607
    VCID: 3F864B3E6D91ECE018F
    Address 16: Steering wheel Labels: 8E0-953-549.lbl
    Part No: 8E0 953 549 N
    Component: Lenksáulenmodul 0611
    Coding: 02041
    Shop #: WSC 63351
    VCID: 3E78363A3A9BE5E8139
    Address 17: Instruments Labels: 8E0-920-9xx-8E2.lbl
    Part No: 8E0 920 950 P
    Component: KOMBI+WEGFAHRS. RB4 D42
    Coding: 01231
    Shop #: WSC 07408
    VCID: 36682E1A12AB2DA8CB9
    WAULT68E84A177884 AUZ6Z0C0436581
    1 Fault Found:
    00779 - Outside Air Temp Sensor (G17)
    29-10 - Short to Ground - Intermittent
    Address 36: Seat Mem. Drvr Labels: 8E0-959-760.lbl
    Part No: 8E0 959 760
    Component: Sitzmemory R2 F 0305
    Coding: 00002
    Shop #: WSC 63351
    VCID: F1E25D06BB45CA905EB
    Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl
    Part No: 8E0 959 433 BB
    Component: Komfortgerát T7B 1512
    Coding: 11852
    Shop #: WSC 63351
    VCID: 72E0D20A3E437188271
    Subsystem 1 - Part No: 8E1959801
    Component: Tõrsteuer.FS BRM 0004
    Subsystem 2 - Part No: 8E1959802E
    Component: Tõrsteuer.BF BRM 0004
    Subsystem 3 - Part No: 8E0959801A
    Component: Tõrsteuer.HL BRM 0004
    Subsystem 4 - Part No: 8E0959802A
    Component: Tõrsteuer.HR BRM 0004
    6 Faults Found:
    00962 - Alarm via. Tilt Sensor
    35-00 - -
    01374 - Alarm triggered by Terminal 15
    35-00 - -
    01572 - Alarm triggered by Door Contact Switch; Passenger Side
    35-00 - -
    01574 - Alarm triggered by Door Contact Switch; Right Rear
    35-00 - -
    01573 - Alarm triggered by Door Contact Switch; Left Rear
    35-00 - -
    01561 - Left Rear Door
    59-10 - Can't Unlock - Intermittent
    Address 55: Xenon Range Labels: 4Z7-907-357.lbl
    Part No: 4Z7 907 357
    Component: dynamische LWR D09
    Coding: 00060
    Shop #: WSC 63351
    VCID: 040C84D214F74F3805D
    Coding: 00201
    Shop #: WSC 00003
    1 Fault Found:
  2. Member jetta ,97's Avatar
    Jul 25th, 2009
    Dallas (Plano),TX
    Jetta TDI 97 & 99.5
    08-18-2012 08:53 PM #2
    Quote Originally Posted by OddJobb View Post
    That has nothing to do with your car not running, you can put coding back to have windows up/ down with remote.
    It mat be coincidence but you have other problem.
  3. 08-20-2012 10:34 AM #3
    I also agree that you have another problem
  4. Member
    Feb 25th, 2010
    Wilkes-Barre, PA
    08-21-2012 09:40 AM #4
    I agree different problem not caused by your coding. Check the exhaust system for wiring problems to the oxygen sensors. Shorted O2 wiring will cause a lot of ****. Kiddy exhaust install? Good luck
