Ok. Here's the story. Cleared a DTC for Xenon self-leveling (headlamp was removed for fender repairs) and added the window open/close via remote in the Central Conv. module following this DIY for a friend's 2004 A4:
http://www.a4mods.com/index.php?page...tml&category=6
Original software coding in the Central Conv. module was 11788. Change the value to 11852.
Tested windows via remote and it worked.
Everything was fine for a few hours. Drove to one place, then another. Then the car started to run rough. Car eventually died and now will not refire. Below is the first auto scan (before anything was done; copied to notepad) and then the 2nd autoscan (output to log) when trying to resolve the no-run issue. We have since changed the 11852 coding back to 11788 as originally found. Car still will not run.
Could any of the Central Conv. coding or clearing of the EVAP DTC have anything to do with the new issues?
VCDS Version: Release 11.11.4
Data version: 20120807
Saturday,18,August,2012,10:36:23:60496
Chassis Type: 8E - Audi A4 B6/B7
Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67
69 75 76 77
VIN: WAULT68E84A177884
Address 01: Engine Labels: 06C-909-559-ASN.lbl
Part No SW: 8E0 909 559 L HW: 8E0 909 059
Component: 3.0L V6/5V G 0020
Coding: 0016711
Shop #: WSC 63351 000 00000
VCID: 3E78363A6A9BE5E8139
1 Fault Found:
16826 - EVAP Emission Control Sys
P0442 - 001 - Small Leak - Intermittent
Readiness: 0000 0000
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 AD
Component: A4 Klimaautomat 1323
Coding: 00000
Shop #: WSC 63351
VCID: 63CEA74EF1B9E8005C7
No fault code found.
Address 56: Radio Labels: 8E0-035-1xx-56.lbl
Part No: 8E0 035 195 H
Component: symphony II NP2 0460
Coding: 00201
Shop #: WSC 00003
VCID: 2C5C0C72DCE76778ADD
1 Fault Found:
00466 - Control Module for Steering Column Electronics (J527)
49-00 - No Communications
Saturday,18,August,2012,13:18:16:60496
69 75 76 77
VIN: WAULT68E84A177884 Mileage: 187370km/116426miles
Coding: 0016711
6 Faults Found:
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 001 -
16688 - Cylinder 4
P0304 - 001 - Misfire Detected
16689 - Cylinder 5
P0305 - 001 - Misfire Detected
16685 - Cylinder 1
P0301 - 001 - Misfire Detected
16690 - Cylinder 6
P0306 - 001 - Misfire Detected
16534 - Oxygen (Lambda) Sensor B2 S1
P0150 - 008 - Malfunction in Circuit
Readiness: 0000 1101
Address 03: ABS Brakes Labels: 8E0-614-517.lbl
Part No: 8E0 614 517 A
Component: ABS/ESP allrad 3429
Coding: 04495
Shop #: WSC 06435
VCID: 2648FE5AC20B5D287B9
Coding: 00000
Shop #: WSC 63351
Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.lbl
Part No: 8E0 907 279 F
Component: int. Lastmodul USA 0517
Coding: 01013
Shop #: WSC 63351
VCID: 356A29160FAD26B0C23
Address 15: Airbags Labels: 8E0-959-655-84.lbl
Part No: 8E0 959 655 K
Component: Airbag 8.4EP 1001
Coding: 0010607
VCID: 3F864B3E6D91ECE018F
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 N
Component: Lenksáulenmodul 0611
Coding: 02041
Shop #: WSC 63351
VCID: 3E78363A3A9BE5E8139
Address 17: Instruments Labels: 8E0-920-9xx-8E2.lbl
Part No: 8E0 920 950 P
Component: KOMBI+WEGFAHRS. RB4 D42
Coding: 01231
Shop #: WSC 07408
VCID: 36682E1A12AB2DA8CB9
WAULT68E84A177884 AUZ6Z0C0436581
1 Fault Found:
00779 - Outside Air Temp Sensor (G17)
29-10 - Short to Ground - Intermittent
Address 36: Seat Mem. Drvr Labels: 8E0-959-760.lbl
Part No: 8E0 959 760
Component: Sitzmemory R2 F 0305
Coding: 00002
Shop #: WSC 63351
VCID: F1E25D06BB45CA905EB
Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl
Part No: 8E0 959 433 BB
Component: Komfortgerát T7B 1512
Coding: 11852
Shop #: WSC 63351
VCID: 72E0D20A3E437188271
Subsystem 1 - Part No: 8E1959801
Component: Tõrsteuer.FS BRM 0004
Subsystem 2 - Part No: 8E1959802E
Component: Tõrsteuer.BF BRM 0004
Subsystem 3 - Part No: 8E0959801A
Component: Tõrsteuer.HL BRM 0004
Subsystem 4 - Part No: 8E0959802A
Component: Tõrsteuer.HR BRM 0004
6 Faults Found:
00962 - Alarm via. Tilt Sensor
35-00 - -
01374 - Alarm triggered by Terminal 15
35-00 - -
01572 - Alarm triggered by Door Contact Switch; Passenger Side
35-00 - -
01574 - Alarm triggered by Door Contact Switch; Right Rear
35-00 - -
01573 - Alarm triggered by Door Contact Switch; Left Rear
35-00 - -
01561 - Left Rear Door
59-10 - Can't Unlock - Intermittent
Address 55: Xenon Range Labels: 4Z7-907-357.lbl
Part No: 4Z7 907 357
Component: dynamische LWR D09
Coding: 00060
Shop #: WSC 63351
VCID: 040C84D214F74F3805D
Coding: 00201
Shop #: WSC 00003
1 Fault Found:
I agree different problem not caused by your coding. Check the exhaust system for wiring problems to the oxygen sensors. Shorted O2 wiring will cause a lot of ****. Kiddy exhaust install? Good luck
