0F Sat tuner not enabled/activated
http://wiki.ross-tech.com/wiki/index.php/02635
#1
Specifically with 19 and 0F:
VCDS Version: Release 11.11.4 (x64)
Data version: 20120807
Saturday,18,August,2012,14:13:49:14294
Chassis Type: 3C0
Scan: 01 02 03 08 09 0F 15 16 17 19 1C 25 42 44 46 52 53 56 62 72
VIN: WVWEK73CX6E046039
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
0F-Digital Radio -- Status: Not registered 0011
15-Airbags -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
1C-Position Sensing -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
Address 01: Engine Labels: 06F-907-115-AXX.lbl
Part No SW: 3C0 907 115 F HW: 3C0 907 115 G
Component: 2.0l R4/4V TFSI 0030
Revision: --H10--- Serial number: VWZCZ000000000
Coding: 0404010A19070160
Shop #: WSC 06811 444 58769
VCID: 236B3D19E2E22E001C7
No fault code found.
Readiness: 0110 0101
Address 02: Auto Trans Labels: 09G-927-750.lbl
Part No SW: 09G 927 750 CJ HW: 09G 927 750 CJ
Component: AQ 250 6F 1135
Revision: 00H38000 Serial number:
Coding: 0000000
Shop #: WSC 06105 444 84050
VCID: 7BDB25793AD2B6C0747
Address 03: ABS Brakes Labels: 3C0-614-095-C2.clb
Part No SW: 3C0 614 095 N HW: 3C0 614 095 N
Component: ESP 440 C2 H015 0001
Revision: H015 Serial number: 0657605065
Coding: 0000000
Shop #: WSC 06105 444 84665
VCID: 2D7FDB21B426E870BA3
1 Fault Found:
01044 - Control Module Incorrectly Coded
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 2
Mileage: 13141 km
Time Indication: 0
Date: 2001.14.03
Time: 01:50:08
Address 08: Auto HVAC Labels: 1K0-820-047.lbl
Part No: 1K0 820 047 DL
Component: Climatic PQ35 090 0505
Shop #: WSC 00000 000 00000
VCID: 71C70751689ECC90DEB
Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
Part No SW: 3C0 937 049 E HW: 3C0 937 049 E
Component: Bordnetz-SG H37 1002
Revision: 00H37000 Serial number: 00000001875468
Coding: 04048E1140041A00000A00000F0000000008724C5C
Shop #: WSC 05311 123 12345
VCID: 2B7BD5398A32E640A47
Subsystem 1 - Part No: 3C1 955 119 Labels: 1KX-955-119.CLB
Component: Wischer VW461 012 0503
Coding: 00065493
Shop #: WSC 05311
1 Fault Found:
02092 - Enabling Heated Seat
009 - Open or Short to Ground
Freeze Frame:
Fault Status: 01101001
Fault Priority: 5
Fault Frequency: 1
Reset counter: 4
Mileage: 13141 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 13.75 V
ON
ON
OFF
OFF
OFF
Address 0F: Digital Radio Labels: 8E0-035-593-SIR.lbl
Part No SW: 8E0 035 593 D HW: 8E0 035 593 D
Component: SDAR SIRIUS H03 0060
Revision: 00000000 Serial number: AUZ4Z7E2011049
VCID: 2A75D03D85C8FF485F1
1 Fault Found:
02635 - Tuner Not Enabled/Activated
000 - -
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 4
Mileage: 13141 km
Time Indication: 0
Date: 2001.14.03
Time: 01:53:21
Address 15: Airbags Labels: 3C0-909-605.lbl
Part No SW: 3C0 909 605 D HW: 3C0 909 605 D
Component: 0R AIRBAG VW8R 027 2421
Revision: 07027000 Serial number: 0038WS7RBK5C
Coding: 0012370
Shop #: WSC 05311 000 00000
VCID: 2773290996DAC22040F
Part No: 3C0 959 339
Component: BF-Gewichtsens. 006 0001
Address 16: Steering wheel Labels: 3C0-953-549-SW20.lbl
Part No SW: 3C0 953 549 E HW: 3C0 953 549 E
Component: J0527 0015
Revision: 00005000 Serial number: 3C5953507P
Coding: 0002311
VCID: 2E7DDC2DB9209368839
Part No: XXXXXXXXXXX
Component: E0221 006 0080
Address 17: Instruments (J285) Labels: 3C8-920-xxx-17.clb
Part No SW: 3C8 920 970 FX HW: 3C8 920 970 FX
Component: KOMBI H05 0110
Serial number: 00000000000000
Coding: 260D00
Shop #: WSC 08269 444 85928
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04040
ROD: EV_Kombi_UDS_VDD_RM09_VW46.rod
VCID: 8733C9893E1A6220E0F
Address 19: CAN Gateway Labels: 3C0-907-530-V3.clb
Part No SW: 3C0 907 530 Q HW: 3C0 907 951
Component: J533 Gateway H13 0172
Revision: H13 Serial number: 3620P10922008A
Coding: FD807F06001202001002
Shop #: WSC 12345 123 12345
VCID: 2F43C129BE2A9A6088F
1 Fault Found:
000 - -
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 4
Mileage: 13141 km
Time Indication: 0
Address 1C: Position Sensing Labels: 1Kx-919-xxx-1C.lbl
Part No SW: 3C0 919 965 HW: 3C0 919 965
Component: Kompass 005 0002
Revision: 00002000 Serial number: 1166279TN46B04
VCID: EDFF9B21F4A6A8707A3
Address 25: Immobilizer Labels: 3C0-959-433-25.clb
Part No SW: 3C0 959 433 Q HW: 3C0 959 433 Q
Component: IMMO 051 0383
Revision: 00051000 Serial number: VWZCZ000000000
Shop #: WSC 06402 785 00200
VCID: 3851FA754B645DD8D95
Part No: 3C0 905 861 J
Component: ELV 029 0380
3C0905861J ELV 029 0380
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN2.lbl
Part No: 1K0 959 701 K
Component: Tuer-SG 024 2359
Coding: 0001205
VCID: 364DF44D4170ABA8CB9
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K1 909 144 H
Component: EPS_ZFLS Kl.12 1502
VCID: 3041C255A3148598915
Address 46: Central Conv. Labels: 3C0-959-433-46.clb
Component: KSG PQ46 RDK 051 0218
Coding: 1A910F8801864E763C04141FF00A0F0E083800
Shop #: WSC 08224 211 56823
Component: Sounder n.mounted
Component: NGS n.mounted
Component: IRUE n.mounted
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN2.lbl
Part No: 1K0 959 702 K
Coding: 0001204
VCID: 3753F949467A52A0D0F
Address 53: Parking Brake Labels: 3C0-907-801-53.clb
Part No SW: 3C0 907 801 B HW: 3C0 907 801 B
Component: EPB VC8HC001 013 0001
Revision: 013
Coding: 0000013
Shop #: WSC 131071 1023 2097151
VCID: 21673711F8FE3C100EB
Address 56: Radio (J503) Labels: 5M0-035-1xx-56.clb
Part No SW: 1K0 035 180 AC HW: 1K0 035 180 AC
Component: Radio Prem-8 H10 0043
Revision: -----20S Serial number: VWZ4Z7J1134823
Coding: 0100000101
Shop #: WSC 01357 011 00200
VCID: 61E77711787E7C104EB
1 Fault Found:
00856 - Radio Antenna
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 4
Mileage: 13141 km
Time Indication: 0
Date: 2001.14.03
Time: 02:03:49
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN2.lbl
Part No: 1K0 959 703 D
Component: Tuer-SG 021 2417
Coding: 0000144
VCID: 3147C751A81E8C909EB
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN2.lbl
Part No: 1K0 959 704 D
Coding: 0000144
VCID: 3245C85DAD18B788E71
End ---------------------------------------------------------------------
#2
#3
