Results 1 to 11 of 11
Thread: APR or Unitronic or RevoTeknik? Stage I or Stage II?? Why???
  1. Junior Member
    May 19th, 2012
    Fargo, ND
    2006 VW Passat 2.0T
    08-18-2012 07:58 PM #1
    I have a 2006 Passat 2.0T... I've added a Neuspeed ColdAir Intake and a Catback MagnaFlow exhaust. Car sounds great by the way!!
    My problem now is that i've noticed the vehicle fuel consumption has increased now and many have told me to "Flash the ECU"
    Some are telling me to do a stage I, some are telling me to do a Stage II... I've done some reading on my own and now my brain is all confused?!?!?
    Feedback is appreciated!
    2006 VW Passat 2.0T / 8k GT-R HID Headlight kit / Euro Side-Markers / K&N P-Flo Cold Air Intake / MagnaFlow DTM Cat-back Exhaust / Drivers Gear Lowering Springs / 18" ADR Tuning Wheels - 18x9.5 255/35 rear + 18x8.5 225/40 front running on Goodyear F1 tires / Forge Diverter Valve Spacer / Trunk Lip Spoiler / Monster Mat Set + Gorilla Trunk Mat / OEM Roof Racks
  2. Junior Member
    Mar 24th, 2012
    New Jersey
    2008 GTI
    08-25-2012 08:27 AM #2
    The only reason not to go Stage II is because you need a bunch of hardware to run that program. You have all that hardware so just get a Stage II program. From what I hear, APR is the more conservative of the programs. It really doesn't matter what you do, but you should really get the reflashed ECU. You are holding back a ton of power.
    2008 GTI 6spd 2 DR Tornado Red- APR Stage II+, koni coils, clutchmasters fx350 clutch (steel flywheel), APR subframe mount, SS brake lines, brake stiffening kit, shift linkage/ shifter bushings, 2DIN Panasonic head unit, Alpine R speakers, JL 5 channel amp
    RIP 2002 WRX Wagon
  3. Member Castaño86's Avatar
    Aug 3rd, 2012
    Atlanta
    2010 vw gti
    09-15-2012 12:17 PM #3
    Quote Originally Posted by KosovarVW View Post
    Im currently running stage 1 from APR with 93, let me begin buy telling you that its well worth the money.I would choose APR simply because they are the most recognized tuner for our cars and have also spent many hours of research and trial and error to give you the best tune posible without compromising other things.Im currently rasing the money for my downpipe so that i can up grade to stage 2. I dont know about the other tuners, but with APR If you are a previous customer(meaning that you already own stage 1 from them) they will reflash your car at NO COST to stage 2 once you get your down pipe , but know that if you are at a APR authorized dealer , its likely they will charge you a labor fee to flash your ecu which usually takes about 45 min to a hour. To answer your question, yes once your tuned your fuel mileage will get better, also keep in mind that your getting more power from this flash and that it is tempting to get in and stomp it... So if your always in the BOOOST!!! dont expect much MPG increase.... Hope this helps
    2010 Gti Carbon steel,Apr flash stage 1, ST coilovers Apr Carbonio intake stage 1&2 , Borla catback
  4. Member
    May 8th, 2012
    New York City
    Passat 08 jetta 01 jetta 98 240sx
    09-17-2012 12:42 PM #4
    Check locations sometims the closest one ours the one you want in case of needing support or anything in the long run
    Sent from my DROID4 using Tapatalk
    DO YOU SPEAK DAS AUTO?
  5. n00b
    Jan 4th, 2010
    Wichita, KS
    2010 VW Golf TDI
    09-19-2012 09:14 PM #5
    HI, just got the TDI flashed by APR affilate in KC. Been looking and reseaching the TDI re-mapping companies from REVO, to Upsolute, to APR. I finally found on in KC. It was there first TDI, they have done a few GTI's two hours later I was ready to roll. I was going to have REVO do it but have not been out to Denver lately to do so I checked out APR in KC. I had the ECU flashed this past weekend. The unit has to removed from the car to unlock the codes and then flashed and put back in. I notice a bit more power in acceleration and lot more torque. If one can keep off of the gas one might see an improvement in MPG which is not to hard in city and close in highway driving but get it on the open road and it wants to rev up and fly. My first checks on MPG are about 45 MPG and not racing and keeping it in the speed limits as much as I can on the highway. Drove home to Wichita from KC at about 80+ and two runs to 100 in passing and got about 38 mpg but I did not have to fill up the entire weekend, a Plus for diesel. Worth the cost, perhaps but once in a lifetime is fun to play with. I will hook it up to a Dyno later and see if the cost lives up to the HP and Torque Hype.
    Later..
  6. Junior Member TnDubber's Avatar
    Feb 21st, 2012
    Cleveland
    2012 GLI
    09-25-2012 11:59 PM #6
    I would reccomend APR seeing as how VW uses their tunes in alot of their sponsored cars. I've also heard that there are several "saftey" codes that their tunes won't over write, keeping their tunes more conservative, but also keeping your engine more reliable. Ive heard this from several shops in my area so dont flame, I have no way of proving, its just what I've heard.
    Sent from my MB886 using Tapatalk 2
  7. 09-26-2012 02:41 PM #7
    Is this even a legitimate question? I thought APR was the best, hands down?
  8. Member Waterfan's Avatar
    Aug 9th, 2012
    84 Jetta 2.0L 8V Conversion (sold); 99 Passat 1.8t APR S1, Suspension, 17's (current)
    10-25-2012 07:39 PM #8
    Quote Originally Posted by JamesGang29 View Post
    There are many legitimate tuners.
    If there was no APR, I wouldn't hesitate to go with GIAC.
    Unitronic, Revo, etc.
    One of the key factors is to find a reputable tuner near you and use whichever tuning vendor(s) they support.
  9. Banned
    Oct 4th, 2012
    10-26-2012 11:22 AM #9
    UNITRONIC hands down !
  10. 11-02-2012 04:40 PM #10
    GIAC doesn't really have hardware though. Seems like APR sells a way more integrated package and has a much bigger variety of products. What are the knocks against them?
  11. Member blueski12's Avatar
    Jun 28th, 2005
    northern nj
    2005 Jetta GLI 1.8T
    11-04-2012 07:34 PM #11
    love my unitronic
    gli PG 2005 1.8T
    unitronic stage 2
    42DD 3" downpipe and 2.5"cb
    forge DV 007
