The thread you put this in originally gave you the answer. This can't be done. Many have tried to figure it out .
#1
I asked this earlier attached to a 2007 thread but I guess no one saw it.
I need to figure out a way to change the speed the car will allow the air suspension to begin lowering to the loading level. Here are the logs I took this morning:
Wednesday,15,August,2012,12:36:14:29383
VCDS Version: Release 10.6.3
Data version: 20101206
Chassis Type: 7L - VW Touareg
Scan: 01 02 03 05 06 08 09 11 13 15 16 17 18 19 1C 22 29 32 34 36
37 39 3C 46 47 55 56 57 64 65 68 69 6C 6D 6E 75 76 77
Mileage: 149680km/93006miles
Address 02: Auto Trans Labels: 09D-927-750.lbl
Part No: 09D 927 750 AN
Component: AL 750 6A 0589
Coding: 0004200
Shop #: WSC 08220 444 58805
VCID: 7AF53BCD4C59
No fault code found.
Address 03: ABS Brakes Labels: 7L0-907-379-MK25.lbl
Part No: 7L0 907 379 G
Component: ESP ALLRAD MK25 0203
Coding: 0022786
Shop #: WSC 31414 000 00000
VCID: 3D7FF0D11DF7
Address 05: Acc/Start Auth. Labels: 3D0-909-13x-05.lbl
Part No SW: 3D0 909 135 R HW: 5WK 470 26
Component: 0V Kessy 6610
Revision: 66105312 Serial number: VWZ3Z0D7261137
Coding: 0131304
VCID: 3469D5F52EBD
Part No: XXXXXXXXXXX
Component: ELV XXXX
1 Fault Found:
00830 - Convertible Top Control Module (J256)
004 - No Signal/Communication
Address 06: Seat Mem. Pass Labels: None
Part No: 7L0 959 760
Component: Sitzverstellung 0701
Shop #: WSC 00000 000 00000
VCID: F7F3A2F9FF4B
Address 08: Auto HVAC Labels: None
Part No: 7L6 907 040 H
Component: CLIMAtronic R/L X 3716
Coding: 0020030
VCID: 356FE8F125C7
2 Faults Found:
01596 - Motor for Outside/Recirculated Air Flap (V154)
000 - - - Intermittent
Freeze Frame:
00353 - Function Return Message from Fresh Air Blower Regulator
001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Voltage: 13.90 V
Voltage: 9.83 V
Voltage: 12.04 V
Voltage: 14.00 V
Address 09: Cent. Elect. Labels: 7L6-937-049.lbl
Part No: 7L6 937 049 L
Component: 2703
Coding: 0111836
VCID: 458F98317527
2 Faults Found:
00907 - Intervention load Management
000 - -
01299 - Diagnostic Interface for Data Bus (J533)
013 - Check DTC Memory - Intermittent
Address 11: Engine II Labels: None
Part No SW: 070 997 016 R HW: 028 101 172 9
Component: V10 5,0L EDCG000AGSª2813
Revision: 5KO3 Serial number: VWZ3Z0D7261137
Coding: 0060575
Shop #: WSC 66565 257 00032
VCID: 29573481F97F
Address 15: Airbags Labels: 3D0-909-601.lbl
Part No: 3D0 909 601 C
Component: 05 Airbag 8.4E++H01 0352
Revision: BB36963 Serial number: 0000301;
Coding: 0012341
VCID: 234B26A99B53
Part No: 7L0 959 339 D
Component: BF-Gewichtsens. 005 0007
1 Fault Found:
01217 - Side Airbag Igniter; Driver Side (N199)
001 - Upper Limit Exceeded - Intermittent - MIL ON
Freeze Frame:
Fault Status: 10100001
Fault Priority: 1
Fault Frequency: 17
Time Indication: 0
Date: 2127.15.31
Time: 31:60:00
Address 16: Steering wheel Labels: 7L6-953-549.lbl
Part No: 7L6 953 549 E
Component: Lenksäulenmodul 3301
Coding: 0000232
VCID: 41878C21610F
Address 17: Instruments Labels: 7L6-920-xxx-17-7LA.lbl
Part No: 7L6 920 980 P
Component: KOMBIINSTRUMENT RB8 2935
Coding: 0021231
Shop #: WSC 22592 444 68068
VCID: 458F98317527
Address 18: Aux. Heat Labels: None
Part No: 7L6 819 008 B
Component: Standheizung E1MAC 0235
Coding: 0000030
VCID: 356FE8F125C7
2 Faults Found:
01126 - Engine Speed Signal
008 - Implausible Signal
00664 - Fuel gauge
002 - Lower Limit Exceeded
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway K<>CAN 0101
Coding: 0000006
VCID: F0E199E59A25
Address 1C: Position Sensing Labels: 7L6-919-879.lbl
Part No: 7L6 919 879 A
Component: JCI PathPoint 2200
VCID: 458F98317527
Address 22: AWD Labels: None
Part No: 0AD 927 755 L
Component: TRANSFERCASE 0076
VCID: 448985357E1D
1 Fault Found:
01314 - Engine Control Module
Address 29: Left Light Labels: 3D0-909-157.lbl
Part No: 3D0 909 157
Component: EVG GDL+AutoLWR(l) 0001
Coding: 0000003
VCID: E6CDFFBDA8E1
1 Fault Found:
00003 - Control Module
014 - Defective - Intermittent
Address 32: Differential Locks Labels: None
Part No: 0AC 927 771 C
Component: SG-Quersperre 5020
VCID: 3871E1C532D5
Address 34: Level Control Labels: None
Part No: 7L0 907 553 F
Component: LUFTFDR.-CDC- 3C3P1 3081
Coding: 0015521
VCID: 366DEFFD38C1
Address 36: Seat Mem. Drvr Labels: None
VCID: F7F3A2F9FF4B
Address 37: Navigation Labels: 7L6-919-887-CD.lbl
Part No: 7L6 919 887 D
Component: Navigation 0635
Coding: 0000002
VCID: 479392394F2B
Address 39: Right Light Labels: 3D0-909-158.lbl
Part No: 3D0 909 158
Component: EVG GDL+AutoLWR(r) 0001
Coding: 0000003
VCID: E7D3F2B9AFEB
Address 46: Central Conv. Labels: 7L0-959-933.lbl
Part No: 7L0 959 933 E
Component: B3 HSG 0201
Coding: 0000085
VCID: 3E7DF7DD10F1
Part No: 7L0 959 701 B
Component: Tuersteuergeraet FS 0201
Part No: 7L0 959 702 B
Component: Tuersteuergeraet BF 0201
Part No: 7L0 959 703 B
Component: Tuersteuergeraet HL 0201
Part No: 7L0 959 704 B
Component: Tuersteuergeraet HR 0201
2 Faults Found:
01134 - Alarm Horn (H12)
000 - -
00931 - Locking Module for Central Locking; Rear Right (F223)
008 - Implausible Signal - Intermittent
Address 47: Sound System Labels: 7Lx-035-4xx-47.lbl
Part No: 7L6 035 466
Component: 12K-AUDIOVERST 0108
VCID: F1E79CE1912F
Address 56: Radio Labels: 7L6-035-186-CD.lbl
Part No: 7L6 035 186 A
Component: Radio 0635
Coding: 0007055
VCID: 3167DCE1D1AF
1 Fault Found:
01303 - Telephone Transceiver (R36)
Address 68: Wiper Electr. Labels: None
Part No: 7L0 955 119 F
Component: Front Wiper 2416
Coding: 0000004
VCID: 3773E2F93FCB
Address 69: Trailer Labels: Redir Fail!
Part No SW: 7L0 907 383 G HW: 7L0 907 383 G
Component: ANHAENGERELEKTRONIK 8854
Coding: 0000002
VCID: 3871E1C532D5
Address 6E: Ctrl Head Roof Labels: 7L6-919-044.lbl
Part No: 7L6 919 044 L
Component: DACHDISPLAY 0538
Revision: 00800538 Serial number: 2009268.07
VCID: 408189256A05
Address 75: Telematics Labels: 3D0-035-617.lbl
Part No SW: 3D0 035 617 A HW: 3D0 035 617 A
Component: Telematik NAR1 0106
Coding: 0076510
Shop #: WSC 08261 444 53300
VCID: 1E3D175DB031
Address 76: Park Assist Labels: 3D0-919-283.lbl
Part No: 7L0 919 283 F
Component: 0E Einparkhilfe 1107
VCID: 3977E4C109DF
End ---------------------------------------------------------------------
Address 15: DTCs cleared
I have noted that the proximity warning system/lights turn on/off at about 10 mph. I would like to make the load level begin at the same speed or a little higher.
1) is there a proximity warning system component/section/address I could go to and copy the speed coded there - and paste the same value into a similar location in the module that controls the loading level?
If so, how do I go about doing that?
Thanks,
Fourdiesel
#2
#3
I'm not sure "can't be done" is precisely equal to 'nobody knows how yet'. I got the can't be done from my original search.
I'd appreciate any tips from the Ross Tech folks as to which control modules to look at - first the fact that the parking proximity warning system turns on at abt 10mpg and thus must contain coding triggering action below that speed - , and second - there also must be a place in the level control system on the air ride vehicles that tells it 'lowering may begin if speed reading is below value X'. It would also be helpful to know where this bit of code (X) is located.
Thanks
