Results 1 to 6 of 6
Thread: catch can install question
  1. Member cubano717's Avatar
    Aug 6th, 2010
    York, PA
    2003 silverstone gti
    08-18-2012 11:32 PM #1
    im preparing to install the 42dd ultimate catch can into my 1.8t. i just had the emissions written out of the software. While reading through the various DIYs for catch can installations, i noticed that people are setting up the cans diferently. Some people attach a hose to the valve cover where the problematic "Y pipe" is and the other hose connected under the intake manifold. Other people are attaching the hose to the TIP. Im confused which hose goes where, and can i use the eurojet pcv hoses.
  2. Member mk4boost's Avatar
    Jul 31st, 2010
    Long Island, NY
    BT Prius
    08-19-2012 03:36 AM #2
    plug the intake port where the pcv goes in... run the hose hose from the valve cover line, and
    the hose from the top of the oil cooler to the the 2 ports of the catch can
    F23 Frankenturbo ll Bosch 550cc ll Eurodyne Maestro ll 034 Motorsports High Flow Exhaust Manifold ll Eurojet street FMIC ll Cooling Mist Dual Nozzle W/M ll 287whp, 290ft/lbs (18psi) ll stock bottom end ll
    http://www.frankenturbo.com/
    http://www.usrallyteam.com
  3. Member cubano717's Avatar
    Aug 6th, 2010
    York, PA
    08-19-2012 07:54 AM #3
    Ok so then the pcv valve gets removed? Which port does the hose from the valve cover hose go to on the catch can, I would think the top port
  4. Member mk4boost's Avatar
    Jul 31st, 2010
    Long Island, NY
    BT Prius
    08-19-2012 09:53 AM #4
    yea throw that pcv valve onto the highway, it doesn't much matter, they're both just vents so however you want to put yhem
  5. 08-21-2012 01:42 AM #5
    Quote Originally Posted by mk4boost View Post
    NO.
    The 42DD catch can doesn't vent to atmosphere. if you run the hoses that way they are both pumping air into the can with no place for it to go.
    He has to T the block breather and the valve cover together to the lower port and run the output hose from the upper port to the hockey puck on the tip.
  6. Member cubano717's Avatar
    Aug 6th, 2010
    York, PA
    11-19-2012 10:14 PM #6
    Quote Originally Posted by Bora070 View Post
    NO.
    does it matter whether i use the top or bottom port for which hose as inlet/outlet?
