Results 1 to 11 of 11
Thread: Any body know of a Greddy turbo timer DIY with pics?
  1. Banned Audiquattro337's Avatar
    Aug 16th, 2011
    Murrieta
    2001 Audi A4 Avant 1.8t 5spd Quattro
    08-19-2012 02:41 AM #1
    Dec 19th, 2011
    92646 (Orange County, CA)
    1998.5 Audi A4 1.8TM
    08-20-2012 11:07 AM #2
    That's the only one I know of, but when I used that DIY more than a year ago the pictures were still up. Pictures certainly helped too... hopefully somebody else will know of one.
    98.5 A4 1.8TM (FWD): VAG-COM, FrankenTurbo F4H-L, United Motorsport 630cc/3bar, 70mm ID MAF in stock airbox with aFE dry filter, CXRacing 28x7.5x2.5 FMIC, 3" HFC, custom 2.5" Magnaflow exhaust, ICM delete, 2.0TSI coilpacks, E-fan, catch can, relocated DV, Bilstein sport/Tein, Neuspeed F/R sway bars, A8/TT brakes, single mass flywheel, JHM short shifter/linkage upgrades, custom sound system, 2-pc. Depos w/ Bixenon projectors
  3. Member It's Big Ty's Avatar
    Feb 19th, 2011
    MD
    LG9R GTI VR6, '57 Ford Thunderbird
    08-20-2012 11:24 AM #3
    Why do you want a turbo timer?
    Tyler
    Instagram: @itsbigty
    SteeLow
  4. Member
    Dec 19th, 2011
    08-20-2012 11:37 AM #4
    Quote Originally Posted by ChampagneA4 View Post
    I can't speak for the OP, but for me the main reason was so that I could drive the card hard right before leaving the car, without worrying about the oil trapped in the turbo getting too hot and breaking down. Also helps if you're in a hurry and want to lock the car but keep the engine running.
    Over time my driving has mellowed out and so now I often hit the "off" button on the turbo timer maybe 20sec. after I finish driving/take the key out.
  5. Member poopie's Avatar
    Feb 21st, 2005
    Philadelphia, PA
    08-20-2012 11:52 AM #5
    audiworld has a few. just google it
  6. Banned Audiquattro337's Avatar
    Aug 16th, 2011
    Murrieta
    08-20-2012 03:49 PM #6
    Pretty much what he said above... Red hot turbo + shutting car down = insane turbo wear...
    When an engine is under load, any load, even if its 1st gear 2,500k RPMs, the friction in the engine produces more heat then if it were at say, an at idle, which is about 700 or so. When a car is at idle, after a long / hard drive, its actually cooling down quite a bit, to give you an example, let your car idle to fully warm up, this will demonstrate the lack of heat being produced when no load is present. i bet it would take close to 15 minutes.
    and thanks a for finding those man! my dumbass fails at searching
  7. Member GOODBYNAAIR's Avatar
    Oct 29th, 2011
    Bmore maryland
    01.5 A4 1.8T quattro, BB
    08-20-2012 04:02 PM #7
    GT2860 sitting waiting to go in..
  8. Banned Audiquattro337's Avatar
    Aug 16th, 2011
    Murrieta
    08-20-2012 04:07 PM #8
    Quote Originally Posted by GOODBYNAAIR View Post
    thank you good sir
  9. Banned Audiquattro337's Avatar
    Aug 16th, 2011
    Murrieta
    08-20-2012 05:35 PM #9
    http://www.audiworld.com/tech/eng.html is the one to be exact if anyone else was wondering...
    i swear i found this paged yesterday and scrolled through it twice, dont know how i didnt see it
  10. Banned Audiquattro337's Avatar
    Aug 16th, 2011
    Murrieta
    08-20-2012 05:35 PM #10
    i swear i found this page yesterday and scrolled through it twice, dont know how i didnt see it
  11. Member GOODBYNAAIR's Avatar
    Oct 29th, 2011
    Bmore maryland
    08-20-2012 07:34 PM #11
    let me know how that works I may look into to that timer at some point after I get a few other things done. glad to have helped
