VWVortex.com - BOOM! VR6 Coilpack. now stuttering...
    Results 1 to 7 of 7
    Thread: BOOM! VR6 Coilpack. now stuttering...
      Dec 29th, 2001
      Northern California
      1998 Jetta VR6, 2010 Audi S-line Avant
      08-19-2012 05:05 AM #1
      Some help please...
      I blew up the coilpack mashing the car pretty hard so i bought a $60 off amazon and replaced it. I also got some new NGK platinum dual spark plugs. Now when I hit about 3-4.5k RPM the car stutters or lags, then it catches up and back to normal. what could it be? the cheap coilpack? spark plugs? The car was driving fine before.i'm stumped
      Jul 10th, 2007
      Rutland, VT
      98 GTi
      08-19-2012 08:00 AM #2
      good to see you bought it back.
      fancy car hauler.
      sorry cant help, probably something minor.
      drop.
    3. 08-19-2012 01:37 PM #3
      Do the good 'ole spray bottle test. Could be arching.
      Check wiring, specifically, engine harness barrel connector and wires, to include engine grounds. Any wire could have take damage (small shrapnel) when it blew off, if so the plug wire may arch after. If no faults found, likely you are still arching somewhere. Pull all connectors, clean then dielectric grease it, reapply and be sure all wires are fitted tight. Spray bottle test if a no go after. Do it while the engine is hot so it evaporates quick.
      Very possible the 60 dollar amazon coil is a dud, but be sure the connectors going to it are clean and free of corrosion anyway. Check for damage to insulation here as well.
      NGK Plat? Why? Turbo? If you are naturally aspirated, you should run the regular copper core plugs. I use the vpower, good plugs. Gap to 38. Ebay link, but they are available almost anywhere.
      http://www.ebay.com/itm/250918770783?hlp=false
      Did you know that it's not pronounced Em Kay ? ALL OF THE CAR LOUNGE WILL BE HAPPY TO LET YOU KNOW THAT. SERIOUSLY. IT STANDS FOR MARK. DID YOU KNOW THAT? BEFORE THAT A1,A2, A3, ETC WAS USED. LIVE UP TO TCL STANDARDS BEFORE YOU GET ON MY ASS. THAT'S DISGUSTING.
      Example of TCL's standards
    4. Member VWJETTY's Avatar
      Jun 29th, 2006
      Dumfries, VA
      97 VW Jetta VR6 OEM+ // 05 Mitshubishi Evolution 8
      08-19-2012 04:18 PM #4
      put your old plus back in it and see if it does it again.
      https://reviewlinker.com/members?id=vwjetty
      Air&Water Specialists @ Bug Haus VW - 804.232.8989 || VRSociety #296 || GO LAKERS
      VCU RAMS
      Dec 29th, 2001
      Northern California
      08-20-2012 03:29 AM #5
      Quote Originally Posted by emkaytree View Post
      thanks, i'll give those a try
    6. Member
      Apr 5th, 2006
      NJ
      08-20-2012 05:20 AM #6
      enlighten me...
      Why would gettin on it kill a coil pack???
      Dec 29th, 2001
      Northern California
      08-21-2012 02:19 AM #7
      Quote Originally Posted by Blkwidow View Post
      enlighten me...
      beats me
