Also I am getting a cabrio next week I think an 01 2.0 does anyone have a good recommendation on an oil for that
#1
I'm new to vw but I have had turbo cars in the past and have had great luck with running rotella t6 in all o them and my cbr1000rr, I'm just trying to figure out if anyone had ran it in a 1.8t and what kinda luck they had
#2
#3
How about adding Lucas oil treatment anybody have any experience with this is a good idea or a bad idea? I'm currently running mobile 1 0-40. Full synthetic
#4
Rotella T6 is fine for both engines.
Lucas Oil stablizer is a horrible idea. It has a tendency to aerate the oil, killing its properties.
2008 Passat wagon, 2.0T 6MT with mods
Other Rides:
- 2013 Cannondale CAADX-6
- 2010 Specialized Secteur Elite
- 2009 Specialized Rockhopper Comp 29-er
#5
Ok no Lucas, I can't seem to find the infamous 502 spec on the rotella is my only concern
#6
Other Rides:
#7
No I'm not just want to make sure I'm not going to damage anything by running it like I said befor I'm new to vw im still learning the differences
#8
#9
Sweet that way all my vehicles with be running the same thing yea the only reason I was asking about Lucas is because it's kinda warm here and it seems on a hot day my oil press is a lil low when the oil is good an hot
#10
+1 on the Rotella T6. been running it in my GTI with no complaints. It quieted everything down a little and its actually cheaper than most other synthetics.
#11
Yea I love it in my bike and the other vehicles I have ran it in
#12
I personally run mobil 1, but i have only heard good things about rotella t6![]()
My Thread Fk AK Coilovers, Full 3" Exhaust, Custom FMIC, Forge Evo14 BOV, Forge Unos MBC, Forge Throttle Body Hose, GodSpeed Aluminum Radiator, Prothane Dog Bone Mount, BFI STG 1 Eng/Trans Mounts, Sachs VR6 Clutch Kit, TT Short Shifter, Siemens 630s, Walbro 255, DBB Garrett 50 Trim Turbo Kit, Eurodyne 630cc MAFLESSPAGPARTS FTW -- STEVEBILT.COM -- Integrated Engineering -- FourSeasonTuning.com Don't Buy Anything From *ChunkyPeanuts*
#13
Awesome I'm going to be changing mine over maybe this weekend so we shall see
#14
Used to run Mobil1 and it was good, but I recently switched to the Rotella 5w40 and I absolutely love it. Definitely quieted things down a bit and it's fairly inexpensive. I highly recommend it to anyone with a 1.8t.
#15
T6 is great! I run it in both my 1.8t Passat and my S4. Like others have said, it's pretty cheap...I think like $22 at walmart.
#16
Well it's taking me longer to switch than I anticipated but the change will happen by Sunday but I'm doing a seafoam oil treatment now trying to brake up what ever may be stoping up my timing chain tensioner so just maybe I won't have to change it but I shall see
#17
you're fine with the rotella t6 as well as vag 502 oils. it's most important to change it regularly in a 1.8t and use the upgraded oil filter as it adds oil capacity (esp on a longitudenal motor), they're tight on a jetta but do fit..![]()
#18
go to the beach and watch the wave crash, it will do almost as much good and is far more therapudic![]()
