Results 1 to 19 of 19
Thread: 1.8t with rotella t6?
  1. 08-19-2012 01:09 PM #1
    I'm new to vw but I have had turbo cars in the past and have had great luck with running rotella t6 in all o them and my cbr1000rr, I'm just trying to figure out if anyone had ran it in a 1.8t and what kinda luck they had
  2. 08-19-2012 11:53 PM #2
    Also I am getting a cabrio next week I think an 01 2.0 does anyone have a good recommendation on an oil for that
  3. 08-20-2012 12:50 PM #3
    How about adding Lucas oil treatment anybody have any experience with this is a good idea or a bad idea? I'm currently running mobile 1 0-40. Full synthetic
    May 10th, 2010
    North Jersey
    08 Passat wagon 2.0T 6MT (current). Past: 02 Golf TDI, Dark Beige 88.5 Camry V6 5MT, AE82 Corolla
    08-20-2012 10:53 PM #4
    Rotella T6 is fine for both engines.
    Lucas Oil stablizer is a horrible idea. It has a tendency to aerate the oil, killing its properties.
    2008 Passat wagon, 2.0T 6MT with mods
    Other Rides:
    - 2013 Cannondale CAADX-6
    - 2010 Specialized Secteur Elite
    - 2009 Specialized Rockhopper Comp 29-er
  5. 08-21-2012 12:08 AM #5
    Ok no Lucas, I can't seem to find the infamous 502 spec on the rotella is my only concern
    May 10th, 2010
    North Jersey
    08-21-2012 12:16 AM #6
    Quote Originally Posted by Helcat17 View Post
    YOu're not going to find 502, 505.00/505/01,etc on Heavy Duty Diesel oils.
    If you're that concerned, There 's Mobil 1 0w40 European Car Formula
    Other Rides:
  7. 08-21-2012 12:22 AM #7
    No I'm not just want to make sure I'm not going to damage anything by running it like I said befor I'm new to vw im still learning the differences
  8. Junior Member
    Jan 26th, 2012
    Central NJ
    2011 Audi Q5 3.2; 2004 Subaru Forester XT; 2013 TTS Oolong Gray P+
    08-21-2012 03:36 PM #8
    You should be fine since RT6 also meets API SM specs. I agree to stay away from Lucas Oil Treatment. It's just an oil thickener with no beneficial additives.
    -Dennis
  9. 08-21-2012 08:52 PM #9
    Sweet that way all my vehicles with be running the same thing yea the only reason I was asking about Lucas is because it's kinda warm here and it seems on a hot day my oil press is a lil low when the oil is good an hot
  10. Member Neezy13's Avatar
    Jun 1st, 2011
    Greenville, NC
    2005 GTi 1.8T
    08-22-2012 02:55 PM #10
    +1 on the Rotella T6. been running it in my GTI with no complaints. It quieted everything down a little and its actually cheaper than most other synthetics.
    Quote Originally Posted by kerridwen View Post
    Either way, I doubt she is pregnant...
    But if she is, you're basically attached to another object by an incline plane wrapped helically around an axis.
  11. 08-22-2012 03:10 PM #11
    Yea I love it in my bike and the other vehicles I have ran it in
  12. Member Big_Tom's Avatar
    Aug 19th, 2007
    Orlando, FL
    01 Jetta Wolfsburg Ed, 92 Honda Prelude Si JDM H22 Swapped
    08-29-2012 03:57 PM #12
    I personally run mobil 1, but i have only heard good things about rotella t6
    My Thread Fk AK Coilovers, Full 3" Exhaust, Custom FMIC, Forge Evo14 BOV, Forge Unos MBC, Forge Throttle Body Hose, GodSpeed Aluminum Radiator, Prothane Dog Bone Mount, BFI STG 1 Eng/Trans Mounts, Sachs VR6 Clutch Kit, TT Short Shifter, Siemens 630s, Walbro 255, DBB Garrett 50 Trim Turbo Kit, Eurodyne 630cc MAFLESS PAGPARTS FTW -- STEVEBILT.COM -- Integrated Engineering -- FourSeasonTuning.com Don't Buy Anything From *ChunkyPeanuts*
  13. 08-29-2012 04:20 PM #13
    Awesome I'm going to be changing mine over maybe this weekend so we shall see
  14. Member c0r3y.af's Avatar
    Oct 8th, 2009
    Warwick, RI
    B5 A4 1.8BTQM
    08-29-2012 05:03 PM #14
    Used to run Mobil1 and it was good, but I recently switched to the Rotella 5w40 and I absolutely love it. Definitely quieted things down a bit and it's fairly inexpensive. I highly recommend it to anyone with a 1.8t.
    My B5 1.8BT Build Thread | Follow me on Instagram: @coreyfonseca
    Quote Originally Posted by ChampagneA4 View Post
    This isn't relevant to your problem, but you need more low.
  15. Junior Member wagonlove's Avatar
    Feb 16th, 2010
    Massachusetts
    B5 S4, B5 Passat
    09-04-2012 07:58 AM #15
    T6 is great! I run it in both my 1.8t Passat and my S4. Like others have said, it's pretty cheap...I think like $22 at walmart.
  16. 09-05-2012 07:56 PM #16
    Well it's taking me longer to switch than I anticipated but the change will happen by Sunday but I'm doing a seafoam oil treatment now trying to brake up what ever may be stoping up my timing chain tensioner so just maybe I won't have to change it but I shall see
  17. Member
    Nov 10th, 2010
    mid hudson valley
    02 jetta wagon 1.8t, 03 passat 1.8,06 jetta 20t
    09-06-2012 02:01 PM #17
    you're fine with the rotella t6 as well as vag 502 oils. it's most important to change it regularly in a 1.8t and use the upgraded oil filter as it adds oil capacity (esp on a longitudenal motor), they're tight on a jetta but do fit..
  18. Member
    Nov 10th, 2010
    mid hudson valley
    09-06-2012 02:03 PM #18
    go to the beach and watch the wave crash, it will do almost as much good and is far more therapudic
  19. 09-06-2012 02:05 PM #19
    Lol ok at the wave
