Results 1 to 19 of 19
Thread: what to use to drain.
  1. Member Bierce IV's Avatar
    Apr 5th, 2010
    NY
    Bagged Blueberry
    08-19-2012 02:14 PM #1
    I am buying a complete new tank setup and on my last one i just pulled out a plug to drain the water out when my water trap faulted out. (after i drained the air of course) but what do you guys run on the bottom of the tank to drain water if needed? I am buying the 5 gallon chubby fyi which has the 1/2" ports.
    Quote Originally Posted by mk4boost View Post
    If you don't want to break the bank you have the wrong hobby
    My Thread
  2. Member rgarjr's Avatar
    May 19th, 2012
    Los Angeles area
    1998 Lexus GS300
    08-19-2012 02:33 PM #2
    http://bagriders.com/modlab/products...ION-VALVE.html
    This seems like a nice way to drain.
  3. Member GolfL's Avatar
    Apr 7th, 2012
    MKV GTI Edition 30 DSG
    08-19-2012 04:56 PM #3
    I am using a radiator plug:
    I connected an airline on the bottom of the tank, to the radiator plug. And it works perfectly!
  4. Member bryangb's Avatar
    Jun 16th, 2010
    Hanover, PA
    '08 GTI, '12 Beetle, '91 Passat
    08-19-2012 06:20 PM #4
    // DROP // DRAG // DESTROY // beer
    // Open Road Tuning
    Instagram: @bryangb
    bags and wheels = build thread
  5. Member Bierce IV's Avatar
    Apr 5th, 2010
    NY
    Bagged Blueberry
    08-19-2012 06:47 PM #5
    sweet thanks guys. also dumb question but does the front of the compressor get hot? the side without the filter or anything. Only because my airlines are touching it and i dont want them to melt
    My Thread
  6. Member bryangb's Avatar
    Jun 16th, 2010
    Hanover, PA
    08-19-2012 07:22 PM #6
    Quote Originally Posted by Bierce IV View Post
    It can get hot. I wouldn't want my lines touching any part of my compressor
    // Open Road Tuning
    Instagram: @bryangb
  7. Member Bierce IV's Avatar
    Apr 5th, 2010
    NY
    Bagged Blueberry
    08-19-2012 07:24 PM #7
    Quote Originally Posted by bryangb View Post
    ok ill have to staple the lines to the side of the spare tire well. No big deal. thanks guys
    My Thread
  8. Member keeganhartman's Avatar
    Jan 24th, 2005
    b5 a4 with switches
    08-19-2012 08:08 PM #8
    Definitely draincock
  9. Member MechEngg's Avatar
    Jan 12th, 2009
    Calgary, AB
    08-19-2012 10:53 PM #9
    I'm using a 1/4" ball valve. Best pic i could find
  10. Member Squirrel Nuts's Avatar
    Aug 25th, 2010
    Miami, FL
    2007 GLI (SOLD) / 2010 Pressurized GTI
    08-20-2012 12:30 PM #10
  11. Member najob08's Avatar
    Apr 28th, 2008
    Vancouver, BC
    IY4
    08-20-2012 01:07 PM #11
    Quote Originally Posted by Squirrel Nuts View Post
    +1
    I just drain into a rag I have in my trunk.
  12. 08-20-2012 01:12 PM #12
    sorry this is another dumb question: all these drain valves are if you don't use a water trap between each compressor and the tank right? Orient the tank so that an unused port is facing downwards and attach a drain plug/valve to it?
  13. Member najob08's Avatar
    Apr 28th, 2008
    Vancouver, BC
    IY4
    08-20-2012 05:27 PM #13
    You still need a drain even if you run water traps.
  14. Member bryangb's Avatar
    Jun 16th, 2010
    Hanover, PA
    08-20-2012 08:31 PM #14
    Quote Originally Posted by jonpwn View Post
    Water can still get in the tank even with a water trap(s). A drain **** is still recommended. And yes - position he tank so a port is on the bottom. Hold a rag under there and drain the water out
    // Open Road Tuning
    Instagram: @bryangb
  15. 08-20-2012 10:16 PM #15
    thanks.. if that's the case is it worth it to run water traps at all? if i don't i'd just be draining the tank more often right? how often do you guys drain your tanks and how often for traps?
  16. Member Niagara_V_Dub's Avatar
    Sep 25th, 2007
    Las Vegas, NV / Lemoore, CA
    hoopty on air
    08-21-2012 12:24 AM #16
    I use a remote drain setup like so....
    1/4"npt - 1/8" ptc then a few feet of 1/8" line.... connected to a 1/8"ptc - 1/8" female npt with a inflation valve screwed in.
    That was I can coil up the line easily, unlike using the 1/4" line one that bagriders recently started stocking, and drain it out of the car. Plus its fun shooting the water.
    I can show you my set up on Saturday if you come to the GTG.
    Insert witty quote
  17. Semi-n00b
    Dec 14th, 2010
    Minneapolis
    2001 Audi allroad 2.7T 6MT
    08-21-2012 12:44 AM #17
    Quote Originally Posted by MechEngg View Post
    +1
    I'm running a ball valve setup as well. I dont have a picture but i ran a hardline out the bottom of the tank and into the spare tire well. The valve is positioned in the spare tire well. Past the valve i have a PTC to 3/8 flexible air hose ran to the outside.
    I drain mine a few times a week.
  18. Member Bierce IV's Avatar
    Apr 5th, 2010
    NY
    Bagged Blueberry
    08-21-2012 01:08 AM #18
    Quote Originally Posted by Niagara_V_Dub View Post
    new tank and fitting should be here tomorrow!!! so as long as i can finish the setup tomorrow or so i shall b there with some locals
    My Thread
  19. Member Niagara_V_Dub's Avatar
    Sep 25th, 2007
    hoopty on air
    08-21-2012 01:28 AM #19
    better be there
    Insert witty quote
