Results 1 to 11 of 11
Thread: Car throwing p0171 code. Think I found out why
  1. Member 95jetta2.0's Avatar
    Dec 7th, 2001
    2006 GTI Stock for now
    08-19-2012 03:56 PM #1
    http://imageshack.us/photo/my-images/33/photocos.jpg/
    This is on the bottom of the Air Filter part. How would this even happen?
    Any idea cost of much is this to replace OEM? Or is it cheaper to just go aftermarket intake at this point?
  2. Member Tutti57's Avatar
    Jun 20th, 2011
    Rochester, NY
    2006 Passat 2.0T and 2008 Touareg VR6
    08-19-2012 08:10 PM #2
    http://www.ecstuning.com/Volkswagen-...Box/ES2090756/
    Factory style is about $210. The oem one is another $100.
    It could be cheaper to get a performance one depending on which one you go with.
    2006 Passat 2.0T Tiptronic | Unitronic Stage 1+ | Rokkor Coil Overs | White Line Control Arm Bushings | BFI Tranny Mount | Nuespeed P-Flo Intake | Newsouth Boost Gauge | Rev D Diverter Valve | BSH PCV fix | eBay Climate Knobs | Autotech Exhaust | DDM HIDs | Stereo Upgrades | Bentley Manual | VCDS
    2008 Touareg VR6
  3. 08-19-2012 09:12 PM #3
    This probably happened when they (dealer perhaps) tried to remove the cover/filter box and
    in the procedure it broke...
    They then simply "forgot" to mention it cause they'd have to pay for it....
    VW's idea of incorporating the air filter in the engine cover has to be one of the
    DUMBEST IDEAS they had....ever...
    P.S. No i'm sorry i take that back...Their dumbest idea was the cam follower....Yeah...
  4. Member 95jetta2.0's Avatar
    Dec 7th, 2001
    08-19-2012 10:06 PM #4
    Wow. That is more than I feared. Time to start looking for aftermarket ones.
  5. Member 95jetta2.0's Avatar
    Dec 7th, 2001
    08-20-2012 01:07 PM #5
    I found the Intake thread, with a bunch of people showing their off. But no one really saying which is the best, or at least better.
    I called VW, the replacement part is 311$. So, what is the best aftermarket intake for a stock, 2.0t FSI? The only real upgrades I might do is an exhaust and a ECU flash. But not now.
  6. Member Tutti57's Avatar
    Jun 20th, 2011
    Rochester, NY
    08-20-2012 01:24 PM #6
    They are all the same in my opinion (performance wise) unless you are looking to squeeze every tiny bit of power out. You won't feel a difference in power, just in sound and look.
    I bought the neuspeed one because it was the cheapest for my car.
    Good luck!
    2008 Touareg VR6
  7. Member BCinco's Avatar
    Dec 16th, 2006
    CT
    2008 Jetta WE
    08-20-2012 06:01 PM #7
    I have an OEM one sitting in my shed I'd be willing to part with.
    2008 Jetta WE * APR Stage II * EuroJet DP
    Dream Machine: Black on Waterproof Cornsilk Beige Bullet Proof Tiguan, Gator Tuned, Vegetable Oil Kit TDI Conversion, Haldex Upgraded 4Motion with an Air Ride Lift Kit and Steel Undercarriage Plate. Location: Central America
  8. Member azunderg's Avatar
    Apr 29th, 2009
    85006 | Garfield District
    MK5 GTI|Fixie|Light Rail
    08-21-2012 12:25 PM #8
    Cold Air Intake for M/T, P-Flo (65.10.97) $189 to your door.
    Pic of mine w/carbon engine cover.
    Love the sound. My car had the Evom intake when I bought it, changed it to the neuspeed = starts and runs better.
    Phoenix DMZ
    The Ghetto
    New South | Neuspeed | ECS | Optima
  9. Member Tutti57's Avatar
    Jun 20th, 2011
    Rochester, NY
    08-21-2012 10:15 PM #9
    ^ pick it up!
    2008 Touareg VR6
  10. 10-14-2012 11:08 PM #10
    Did that correct ur problem?
  11. 10-17-2012 10:53 AM #11
    hey just thought id weigh in.... i got the k&n intake and could not be happier, not a ton of ppl go with it but they come with the best filters are generally cheaper and sound deep never high pitched. take a look on youtube for different sounds, but at the end of the day they are all a filter on a stick, so the pipe with the least amount of couplings will provide better air flow. the k&n is one solid pipe with no breaks imo best deal, sound, filter, and a slight throttle response improvement....
    i also have a stock fsi airbox at the house with a middle of its life filter in it id be happy to let that go for 80 plus shipping
    hope this helps!!!
    btw ive had nuespeed, k&n, evoms, and that carbon one on a couple of different vdubs, best sound is between evoms and k&n, power difference between the 2 is negligible, price plays the biggest role and k&n is way better for the money
